Old 01-22-2008, 01:23 PM   #10546
ShaunMac's Avatar
Originally Posted by LOSI123 View Post
So will reducing the inboard front toe out make the steering less agressive even if the actual front toe is readjusted to say 0 degrees with both cases.
Yes. It's very common to see 0 and 1.5 blocks used when running rubber on carpet to calm the front steering a bit.
ShaunMac is offline   Reply With Quote
Old 01-22-2008, 02:04 PM   #10547
SammyZ's Avatar
Trader Rating: 138 (100%+)
Ok, so what if I dont want in-board toe-out? I ordered a 0 degree pivot block for the front, that will make it like most touring cars right?
if i wanted outboard toe out, I would need to make adjustments to the steering turnbuckles, im quite certain.
Also...has anybody assembled the layshaft in a cyclone....holy f--- what a $hitty design.
SammyZ is offline   Reply With Quote
Old 01-22-2008, 02:23 PM   #10548
RC MARKET's Avatar
On another note, Has anyone tryed the 3 racing pivot blocks or alum diff?
do they fit ok?
Yes fit !
RC MARKET is offline   Reply With Quote
Old 01-22-2008, 03:00 PM   #10549
ShaunMac's Avatar
0 degree blocks will give you no arm sweep(toe) in the front.
Old 01-22-2008, 05:40 PM   #10550
mangoman's Avatar
Whats wrong with it? Just make sure you put it in the right way. Spur goes on the left side of the holder when its mounted. It may not line up with the hole underneath it in the chassis.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 01-22-2008, 06:01 PM   #10551
mangoman's Avatar
Originally Posted by Marcos.J View Post
well it will give you inboard toe out , makes the car have more agressive steering.
look at the attachment
It also makes the wheelbase slightly shorter
Is that from the pro 4 manual
That guide is the best, i dont know why they dont add it to the current manuals.
www.smaracing.org
Old 01-22-2008, 07:36 PM   #10552
SammyZ's Avatar
i just dont like hwo unclear the insutrctions are during the layshaft assembly. I mean after your done building it you have gaps in between the pulley's and the spur gear on both pulley's. its like you need to align everything up, its wicked stupid, if you built any other TC you would see why.
Most newer TC's have pins and everything is pre-setup with tolerances already set. With the cyclone your basically setting the tolerance by pushing the pulley against the bearing into the bulkhead, you dont know if its binding or if its too loose.
Old 01-22-2008, 08:20 PM   #10553
Drifter73's Avatar
Where is a good place to buy parts. My HobbyTown does not carry HB parts, and the website doesn't seem to offer them either. I want to sell my Losi Type-R and buy a Moore Speed Cyclone, but I want to research the parts first. I would like to have the car ready for the Roar carpet Nat's in March....
Drifter73 is offline   Reply With Quote
Old 01-22-2008, 08:49 PM   #10554
Essnowyt's Avatar
Send a message via AIM to Essnowyt
If you have built any other TC, you should know if/when the the drive line is binding or not! Its is very simple to adjust the position of the pulleys. No need for pins that mushroom and get stuck in the shaft. No need for shimming washers, that will get lost.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 01-22-2008, 09:29 PM   #10555
SammyZ's Avatar
Snowy.
well with my xray car everything was set very well, it uses pins to set the pulley's and its impossible to mess up. I could see a nubcake racer screw this thing up with the unclear instructions and then there sno finished pictures of it, it easy to get the shaft to have play in it, but its also easy to tighten it up. I dunno I just think it could have been thought out a little better.
I mean why drill holes into the shaft if there not going to be used?
Also I am happy to see a stockfull of parts from stormerhobbies and towerhobbies, also eBay for the cyclone!
Old 01-22-2008, 09:50 PM   #10556
SammyZ's Avatar
my kit was missing 1 rebound foam for the shock. I decided to skip the foams in the rear shocks, what will this do?
Old 01-22-2008, 11:44 PM   #10557
padailey's Avatar
Your LHS has quite a bit of the parts but they are HPI... shocks, arms, c hubs, knuckles, diff screws, servo saver. They also have a top plate, shock end balls, blades, pivot balls, belts, FR pivot blocks, ver 2 bones, and I just bought a spool from them. TowerHobbies has a good selection of parts which means they can get them at HT. Just tell them what you want and they can get it. Otherwise if out of stock you can look at the HK shops, RC Champ, Speedtech, tower... they all have Cyclone parts.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 01-23-2008, 12:19 AM   #10558
2-Bad's Avatar
Trader Rating: 24 (100%+)
It should provide more rear grip... less rebound = more grip, less reactive.
2-Bad is offline   Reply With Quote
Old 01-23-2008, 05:44 AM   #10559
Drifter73's Avatar
Thanks Paul, so what I'm hearing is that a lot of the old HPI Pro-4 parts will work on the new Cyclones! Is this true?
Old 01-23-2008, 08:39 AM   #10560
padailey's Avatar
Yes ... most of the suspension parts are the same as the Pro 4.
Tamiya TRF416X
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
