Old 01-19-2008, 11:03 AM   #10516
trickd122's Avatar
Default ?????
Are these just motor caps on the ESC?
trickd122 is offline   Reply With Quote
Old 01-19-2008, 11:56 AM   #10517
Hey guys nice Surikarn edition and also a parts lot in the for sale section.
jeremymoemorris is offline   Reply With Quote
Old 01-19-2008, 12:55 PM   #10518
rosko's Avatar
on the camber link positions near shock tower whats the difference between the two inner holes closest to center line/longer position one make link angle toward the shock tower and the other is away or straight. more camber gain or maybe just one lets u run the link slightly longer
rosko is offline   Reply With Quote
Old 01-19-2008, 01:04 PM   #10519
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
sure look like it
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-19-2008, 02:28 PM   #10520
Trader Rating: 22 (100%+)
Originally Posted by B18C Turbo View Post
3.6mm chassis will be $90 and released in just 3 weeks
in stock at stormer hobbies now
bjspinner is offline   Reply With Quote
Old 01-19-2008, 04:29 PM   #10521
CHRIS CHAVEZ's Avatar
Hey guys, I just bought some ceramic diff balls for my Moore speed cyclone. I was wondering if anybody has any tips for building/breaking in a diff with ceramic balls.
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 01-19-2008, 07:46 PM   #10522
SammyZ's Avatar
Trader Rating: 138 (100%+)
unbelievable! stormer has 3 of the chassis and there only $79!
I like to use 3 racing titanium ball studs, no breaks! I also use ceramic nitride diff balls from wallawalla on eBay. The nitride ceramic balls are only .56 cents each and come in both 2mm and 2.4mm. Use HPI d rings and HPI thrust washers. Use the titanium HB diff screw/t-nut.
You can also find lots and lots of cheap hop ups from 3 racing on eBay from the seller HKS hobby. ALl aluminum hop ups in purple anodizing and lots of graphite parts. They even have the 18t pulleys that come with 16, 17, and 18t pulleys for just $7.50 each 3 pulley's.
I bet you don't even need the longer front belt, it will be slackless and you may not even need the tensioner. Im gonna buy the belts anyways just in case. They are the 170t front belt and 63t rear belt.
SammyZ is offline   Reply With Quote
Old 01-19-2008, 08:33 PM   #10523
tc3 racer sc's Avatar
where can u find more info on the chassis
tc3 racer sc is offline   Reply With Quote
Old 01-20-2008, 05:50 AM   #10524
Ballsie's Avatar
Here mate - http://press.hotbodiesonline.net/piw.php?partNo=61285
Cheers.
Ballsie is offline   Reply With Quote
Old 01-20-2008, 09:48 AM   #10525
SammyZ's Avatar
awsome, didnt know they made a 2.5mm upper deck too. Is it worth buying for carpet if its just .5mm thicker than the stock peice?
Old 01-20-2008, 09:54 AM   #10526
Ballsie's Avatar
It might only be .5 mm but remember that's about 25%.
Old 01-20-2008, 07:04 PM   #10527
SammyZ's Avatar
thats true man. Does anybody here run their cyclone on indoor carpet with foam tires? I need a good starting point for a 75'x45' ozite medium grip carpet with foams.
Car is a moore-speed cyclone. Car has a front ball diff.
Old 01-20-2008, 07:20 PM   #10528
Originally Posted by Ballsie View Post
thxs for info
Old 01-20-2008, 07:22 PM   #10529
inotice when i was at the snowbird last yr hara ran a thick carpet chassis it was not the bmi chassis very sweet nice and clean
Old 01-20-2008, 08:47 PM   #10530
SammyZ's Avatar
whats the craziest gearing you've ran on your cyclone without using a brushless motor mount set?
Im thinking about a 96t spur mated to a 47t pinion gear. Will it fit? (64pitch of course)
What about bigger pinions and the same spur?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
