Old 01-18-2008, 08:37 AM   #10501
Ballsie's Avatar
Hi Guys,
Does anyone know when the new carpet racing chassis is being released?
Cheers.
Ballsie is offline   Reply With Quote
Old 01-18-2008, 09:04 AM   #10502
SammyZ's Avatar
Trader Rating: 138 (100%+)
3.6mm chassis will be $90 and released in just 3 weeks
SammyZ is offline   Reply With Quote
Old 01-18-2008, 09:06 AM   #10503
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by B18C Turbo View Post
show me where you got the 18t pulley's, shortened belts, a rediculous 88t spur and where the heck did you find apinion that size.
18T pulleys and belts came from Horizon, spur from my LHS, pinions from Stormer's i think.
pcar951 is offline   Reply With Quote
Old 01-18-2008, 09:06 AM   #10504
pcar951's Avatar
Originally Posted by Ballsie View Post
Hi Guys,
Cheers.
I heard late February...
Old 01-18-2008, 11:49 AM   #10505
Ballsie's Avatar
Re: carpet chassis - thanks guys
Old 01-18-2008, 02:00 PM   #10506
LOSI123's Avatar
Trader Rating: 63 (100%+)
Originally Posted by STLNLST View Post
that set up station will help you measure the throw but if you're at max and only getting 17 then like someone stated previously you may want to check your ackerman, or radio settings, etc......... What are you try to accomplish by getting 20 to the outside wheel?
I have checked ackerman, toe , all linkage positions, its all as per the standard asphelt setup on the hb website. And the epa on transmitter is set to maxium phisicaly posible (ie the steering hub/knuckle is hitting its limit....
I was told that i should set it up with about 20 degrees throw on the outside wheel, and that the maxium posible is around 28 degrees....
LOSI123 is offline   Reply With Quote
Old 01-18-2008, 04:05 PM   #10507
Vicko's Avatar
Trader Rating: 14 (100%+)
do is the chassie for carpet Foam or Rubber????
Vicko is offline   Reply With Quote
Old 01-18-2008, 10:25 PM   #10508
STLNLST's Avatar
If 17 is the max you can get then maybe the info you received was a bit off. Have you tried running the car at 17 yet? You might find what you were looking for.
STLNLST is offline   Reply With Quote
Old 01-19-2008, 01:02 AM   #10509
SammyZ's Avatar
how do you strap down a li-po pack to the chassis? Theres no battery strap or holding gaurds for the batteries.
Old 01-19-2008, 07:00 AM   #10510
Is anybody braking HPI ball studs ??? They seem to brake off way to easy !! Are titanium ball studs any stronger ??
Lazer Guy is offline   Reply With Quote
Old 01-19-2008, 07:01 AM   #10511
rosko's Avatar
the new chassis has to be for foam tires the stock chassis is plenty for rubber tire on carpet. me personally i wouldnt even get the chassis unless you plan on running foam tires for a while i would not get that thick of a chassis for rubber tire on carpet or anywhere
rosko is offline   Reply With Quote
Old 01-19-2008, 07:05 AM   #10512
rosko's Avatar
im breaking ball stubs just by screwing or un screwing , the ball studs are very brittle
Old 01-19-2008, 08:06 AM   #10513
predrill the holes; especially the ballstuds in the uprights can break easily if you don't predrill the holes.
omoser is offline   Reply With Quote
Old 01-19-2008, 08:18 AM   #10514
go to nexus racing and get the battery tape works very well has not come out over 10 runs on it
iceman76 is offline   Reply With Quote
Old 01-19-2008, 08:44 AM   #10515
CRASH's Avatar
Trader Rating: 26 (100%+)
Does anyone make aluminum spring mounts in black? I do not want blue or purple.
Thanks,
CRASH is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
