Hot Bodies Cyclone
I recently did the pulley / belt upgrade to 18T. the front belt is baggy like grampa's shorts even when adjusted to the max. the 2.16 ratio is nice for brushless though. also had pretty good luck with 88T spur gear, looked stupid with a 48 pinion but it was really quiet.
I have a setup station and i want to measure steering throw on the out side wheel (as i heard this is where to measure it)
can any one tell me in detail how to get 20 degrees throw on the outside wheel, as even at maximum throw mine is at about 17 degrees?
You may want to check the ackerman.
Those are the shims under the ball studs which connect the steering links to the servo saver. (2 x 2mm shims ie 4mm total) is usually common under each ball stud.
Does that make sense?
Hi Guys,
Does anyone know when the new carpet racing chassis is being released?
Cheers.
Cheers.
3.6mm chassis will be $90 and released in just 3 weeks
Re: carpet chassis - thanks guys
I was told that i should set it up with about 20 degrees throw on the outside wheel, and that the maxium posible is around 28 degrees....
do is the chassie for carpet Foam or Rubber????
