Old 01-10-2008, 01:17 AM   #10426
Default 18T PULLEY AND REAR BELT QUESTION
Im not sure if this has already been qsked but im thinking about fitting the new 18t pulley for the rear belt only. Now my question is what will my new internal ratio be as ive increased the pulled size by 2 teeth. Also how do I work this out. Thanks for any help
RAPID RACER is offline   Reply With Quote
Old 01-10-2008, 07:42 AM   #10427
39T(Diff Pulley)/18T(Drive Pulley)=2.166
Thanks!
Hi-LowBlow is offline   Reply With Quote
Old 01-10-2008, 01:25 PM   #10428
Thanks!
Nice one Thanks for that
Old 01-10-2008, 05:09 PM   #10429
Thanks!
Something doesn't sound right Is the front going ta be 2.4 and the back 2.1 ??? Thats a big over drive isn't it
Lazer Guy is offline   Reply With Quote
Old 01-10-2008, 06:11 PM   #10430
mangoman's Avatar
Both pulleys on the layshaft should have the same number of teeth.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 01-10-2008, 09:04 PM   #10431
otter pop's Avatar
if the pullies on the layshaft are not the same the front and back tires will be rotating at diffrent speeds
otter pop is offline   Reply With Quote
Old 01-12-2008, 02:36 AM   #10432
Default 16t front pulley 18t rear pulley ?
Thanks for the imput guys, I know what your saying ref having different sized pulleys on the lay shaft. Has any one tried this with the cyclone ? and what was the result. Also im sure I read on the hotbodies website that if you run just the 18t pulley to the rear it gives increased traction, so im guessing that they have tried it. Last question is if I run the 16t /18t pulley on the lay shaft
what will my internal ratio be so i can gear my motors, I know its 2.166 to the rear but is that the ratio i use to gear my motors.
Thanks every one keep the info comming
Old 01-12-2008, 07:46 AM   #10433
Are you drift racing ????? That might work if you are.
Old 01-12-2008, 09:10 AM   #10434
Sean T Guy's Avatar
Rapid Racer,
I strongly reccommend you use a 1 way diff in the front and a spool in the back. You could also try square wheels and then I might out qualify you 2moro.
Seriously though I'm sure there will be a few people waiting to see how you find overdrive to the rear especially on carpet , I'll let you know how it looks after the qualifiers 2moro
Sean T Guy is offline   Reply With Quote
Old 01-12-2008, 05:18 PM   #10435
Woz
can someone confirm what Li-Po batteries fit the Cyclone without modification, or with Slight Modification to the top deck brace.
Woz is offline   Reply With Quote
Old 01-13-2008, 11:09 AM   #10436
otter pop's Avatar
my orion 4800 fits right in
Old 01-13-2008, 11:14 AM   #10437
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
orion/peak 3200,orion/peak 3600,core r/c 5000,
Old 01-13-2008, 03:08 PM   #10438
rbalint's Avatar
Hi!
Does anyone has any information of the new diff which was used at DHI this weekend?
http://events.redrc.net/wp-content/g...ark/HaraHB.jpg
rbalint is offline   Reply With Quote
Old 01-13-2008, 04:20 PM   #10439
Woz
has anyone tried fittin the trakpower li-po packs?
Old 01-13-2008, 04:23 PM   #10440
Super Moderator
Marcos.J's Avatar
as long as the lipo pack is not taller than 23mm you should be ok
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
