Old 12-28-2007, 03:45 AM   #10351
2-Bad's Avatar
Trader Rating: 24 (100%+)
HB73524 - Shock Pistons 3x1.1mm
Originally Posted by LOSI123 View Post
Anyone know if there is a hb or hpi original part that is a 3 hole shock piston to fit in the cyclone?
2-Bad is offline   Reply With Quote
Old 12-28-2007, 09:41 AM   #10352
FARBES's Avatar
Send a message via AIM to FARBES
Default Whoa! Let me step back, I notice something
Cyclone parts and HPI pro 4 parts are the exact similars, isnt it? But i aware of pro4 and cyclone 's towers are different. some parts are same to me. If so, Cyclone S chassis can be replaced with some HPI pro 4 parts, I am right?
What Cyclone "S" stand for?
FARBES is offline   Reply With Quote
Old 12-28-2007, 10:19 AM   #10353
RC MARKET's Avatar
Hara testing new Cyclone main chassis ,
the main chassis was install like Cyclone D4 battery holder !
www.rcmarket.com.hk
RC MARKET is offline   Reply With Quote
Old 12-28-2007, 02:39 PM   #10354
LOSI123's Avatar
Trader Rating: 63 (100%+)
thanks
LOSI123 is offline   Reply With Quote
Old 12-28-2007, 02:57 PM   #10355
Hugh Jazz's Avatar
THe S stands for Sport
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 12-28-2007, 09:42 PM   #10356
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Originally Posted by bmmer701 View Post
yup it will fit with no modification.
Thanks for the help!!
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 12-28-2007, 10:37 PM   #10357
Send a message via AIM to joey
Originally Posted by yzf-r1 View Post
anyone know if rdx or t2 alum caster blocks and knuckles will fit cyclone?
your breaking them also? i was last time i was at 360..
you gonna be there this Sunday?
=Joe Wright=
joey is offline   Reply With Quote
Old 12-29-2007, 10:18 PM   #10358
pcar951's Avatar
Trader Rating: 19 (100%+)
Default Cyclone carpet monster??
OK, I've seen the pics and I've gotta have one! Anybody know where and when the carpet chassis set is going to be available from hot bodies? The Cyclone will be the schizz on the rug with that bad boy!
pcar951 is offline   Reply With Quote
Old 12-29-2007, 11:09 PM   #10359
tandman's Avatar
Send a message via Yahoo to tandman
Jim....your Cyclone is already fast enough.......looks real smooth
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist Fantom Racing
Team Sweepracing
tandman is offline   Reply With Quote
Old 12-30-2007, 04:16 AM   #10360
LOSI123's Avatar
Anyone know where these are available??? online???
cant find them anywhere....
Old 12-30-2007, 05:00 AM   #10361
2-Bad's Avatar
Try RC Champ or locally from Frontline Hobbies
Old 12-30-2007, 10:20 AM   #10362
POOKYT's Avatar
OK-OK!
Peter point me to the "it" set-up for asphalt like we had for the JRXS. Also which titanium screw set is the choice for this car?
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 12-30-2007, 06:10 PM   #10363
2-Bad's Avatar
Howdy Brant...
Let me firstly assure you.. I am in no way a setup guru, so please take this setup with that understanding...
Front:
Camber: 1.5 deg
Castor: 4 deg
Ride Height: 5.0mm
Droop: 5.0mm
Front Drive: Spool
Stabiliser: 1.4mm
Toe Angle: 1 deg
Top Shock Location: 3
Bottom Shock Location: 1
Inner Camber Link location: 1
Inner Camber Link Spacers: 2.0mm
Front Bottom Roll Centre Spacers: 1.5mm
Rear Bottom Roll Centre Spacers: 1.5mm
Pivot Block: 2.5
Ackerman: 4.0mm
Shock Piston: 3 x 1.1mm
Shock Oil: 40wt
Shock Spring: Pink
Shock Foam: none
Shock Rebound: none
Rear:
Camber: 1.5 deg
Ride Height: 5.5mm
Droop: 5.0mm
Stabiliser: 1.2mm
Toe Angle: 1 deg
Bottom Shock Location: 2
Inner Camber Link Spacers: 1.5mm
Outer Camber Link Spacers: 0.0mm
Pivot Block: 3.0
Shock Oil: 40wt
Shock Spring: Silver
Shock Foam: none
Shock Rebound: none
Bolt on whatever tyre/insert/rim that works locally and usually use the Mazda 6 or Speed 6. I usually take this setup with me everywhere and start tuning the car in with the shocks first by changing the piston and fluid, eg. Tamiya 3 x 1.0mm or HB 2 x 1.2mm and fluid by 30wt up to 45wt. Then juggle the Droop, and Ride Height before going to anything else on the car.
For the Titanium Screws; the "Square RC" screws have been very tough and reliable for me... Part #: SHB-52 for about 3,780Yen.
Hope this helps...
Regards,
Peter
Originally Posted by POOKYT View Post
OK-OK!
Brant
Old 12-30-2007, 09:41 PM   #10364
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I cant find it, but I know I saw something about using a 2.6 mm (I think) screw from HB
What was the screw? And what thrust washers, balls do I use?
Also, do xray knuckles, and or c hubs fit the cyclone? Are they any stronger?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 12-30-2007, 10:48 PM   #10365
LOSI123's Avatar
I still cant find them hb 3 x 1.1mm pistons anywhere?????
can some one give me a direct link, please........
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
