Old 12-25-2007, 07:21 AM   #10336
RaceAce701's Avatar
Trader Rating: 83 (99%+)
Originally Posted by JL View Post
Thanks RaceAce701. I'll try the softer front tyres.... this is actually the car I bought second hand from you a few months ago. Cheers
i also found out that on a short tight track shortning the wheelbase 1mm in the rear will help the car rotate more
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 12-25-2007, 11:33 PM   #10337
Wouldn't shortening the front wheelbase offer better rotation since by moving your rear arms forward you are actually increasing rear mechanical traction since weight transfer is greater under acceleration when you bring the rear arms forward? By moving the front arms closer to the rear you are shortening the wheelbase - thus increasing rotation at lower speed-to-mid speeds without effecting rear traction.
duckman996 is offline   Reply With Quote
Old 12-26-2007, 07:49 AM   #10338
RaceAce701's Avatar
yes moving the front arms back helps transfer more weight to the front
but in general a shorter wheelbase will rotate faster no matter which end you shorten
i have a stock chassi car and a bmi
my stock chassis car is 1mm shorter in the rear and rotates much faster that the bmi but the bmi is smoother and carries more corner speed
Alex "ACE" Kubilus
ACE design works
Old 12-26-2007, 10:07 AM   #10339
RC MARKET's Avatar
Jan release New carpet chassis & upper deck...
http://www.hpiracing.co.jp/
RC MARKET is offline   Reply With Quote
Old 12-26-2007, 03:06 PM   #10340
Originally Posted by Joehwee View Post
Forget about the AE screw, just get the following parts and you shouldn't be breaking the diff screw. Just make sure that you run a 2.6mm drill bit thru the centre of the diff outdrives.
http://www.hotbodiesonline.net/searc...=61535&lang=en
http://www.hbeurope.com/piw.php?lang=en&partNo=61544
Hay !!!! I just built a diff using the parts Joehwee suggested this is my first diff using all HPI parts that dose not slip and is still very, very smooth !!! man am I ever happy I got the parts from RC MARKET.
Thank you Joehwee
Lazer Guy is offline   Reply With Quote
Old 12-26-2007, 10:02 PM   #10341
SpeedySST's Avatar
Cool Brushless motor mount
Hi! I dont know if this has been covered before but I saw a "brushless motor mount" for the Cyclone. Is this necessary or will the stock motor mount work? Thanks!
SpeedySST is offline   Reply With Quote
Old 12-27-2007, 12:37 AM   #10342
Joehwee's Avatar
The brushless motor mount raised the centre lay shaft 2mm higher so you are able to use bigger spur to get the gearing you want when running 3.5t brushless.
Joehwee is offline   Reply With Quote
Old 12-27-2007, 01:38 AM   #10343
Hi, This post of mine is very knowledgable and may enhance the information of the viewers , however I would like some specific information for myself. If someone can help me then please send me a private message. Best Regards,
Property Directory | Wholesale Billiards
Wholesale Batteries |Stock Brokers Directory
Muaz is offline   Reply With Quote
Old 12-27-2007, 12:37 PM   #10344
http://www.redrc.net/2007/12/hot-bod...e-carpet-spec/
carpet chassis
C_Suzuki is offline   Reply With Quote
Old 12-27-2007, 07:39 PM   #10345
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
I have a WCE edition and I thought I had read that a 3200 lipo will fit with no modifications, is this correct? What about a 4800 which is what I really want to run.
I thought I had read somewhere that there were optional bulkhead pieces that were made for lipo use....
Any help would be appreciated. Thanks!
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 12-27-2007, 07:42 PM   #10346
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
The 4800, as well as the TrakPower 4900 fit no mods, there close, but they fit
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 12-27-2007, 07:54 PM   #10347
ASM
ASM's Avatar
So a hard cased 4800 will fit?
Scott Meeks
USVTA Member #116
Old 12-27-2007, 08:43 PM   #10348
bmmer701's Avatar
yup it will fit with no modification.
bmmer701 is offline   Reply With Quote
Old 12-27-2007, 11:53 PM   #10349
yzf-r1's Avatar
anyone know if rdx or t2 alum caster blocks and knuckles will fit cyclone?
RLM, LRP, Thunderpower, Ko propo, Checkpoint, Hacker, Muchmore, FFE
Cyclone, Sf501, KP09e, 25.5 mono, 26 mono no step, GPV-1,HOR, teamwalbern promods, 5Bss...list goes on
yzf-r1 is offline   Reply With Quote
Old 12-28-2007, 12:53 AM   #10350
LOSI123's Avatar
Trader Rating: 63 (100%+)
Anyone know if there is a hb or hpi original part that is a 3 hole shock piston to fit in the cyclone?
as almost all of the setup sheets from the hb website say 3 hole piston and the car comes with a 2 hole?
also if you put 30wt oil with 2 hole 1.2mm pistons, would that be simillar to 40wt oil with 3 hole 1.1mm pistons?
as i dont have a 1mm drill bit.
LOSI123 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
