Old 12-17-2007, 02:23 AM   #10321
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Also just noticed your running stiffer springs in the rear. It appears as if your setup is so far off its just not going to work. Start completly over! You are way off track right now.
Good luck.
Kave is online now   Reply With Quote
Old 12-17-2007, 05:00 AM   #10322
mangoman's Avatar
yeah whats with the super stiff springs on the car?
I havent raced on proper carpet with foams but i found that when i was racing the cyclone didnt seem to like stiff springs, although most people say to stiffen up the car.
1 degree rear block ive never seen anyone run one that small. Id stick with about 2.5
Also i personally find 4 degrees castor is standard on almost everycar, not sure who runs 6, but i guess that could be a carpet thing **SHRUG**
Also what are you running up front, ball-diff and what motor are you running?
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-17-2007, 06:16 AM   #10323
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Originally Posted by Skill View Post
Yes, the Core R/C pack will also fit.
thank you!!
Old 12-20-2007, 04:35 PM   #10324
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi, may i knw how u guys make d left n right weight is even ?how u guys weight d left n right ?
thanks
kschu is offline   Reply With Quote
Old 12-21-2007, 01:12 PM   #10325
thanks
There are many ways to do that.... I have seen people drill a hole in the middle of two quarters (coins) and solder a nail in them and round off the tip. Your car has holes in the front and back just sit you car on the tip of the nails and that will work OK, I use digital cooking scales under all 4 tires.
I hope you under stand me and this helps you
Russ
Lazer Guy is offline   Reply With Quote
Old 12-21-2007, 01:31 PM   #10326
ShaunMac's Avatar
thanks
IRS Balance Buttons
The Cyclone already has 2 holes drilled on center. Just put these on and let the balancing fun begin!
ShaunMac is offline   Reply With Quote
Old 12-22-2007, 06:11 PM   #10327
2-Bad's Avatar
Trader Rating: 24 (100%+)
Some Gossip.....
Hara was testing 3 Clones this week at RCS; one virtually standard, one with a new chassis, one with a new upper deck and middle brace. All were running the new diff. No update on the release date of the new car... still due around the Worlds....
Sorry, no photo's... (I asked, but he wouldn't let me )
PS> Adachi Shinosuke, Neils Keonekoop, and Oscar were also there this week practicing with there Kyosho's .
2-Bad is offline   Reply With Quote
Old 12-22-2007, 07:07 PM   #10328
RaceAce701's Avatar
Trader Rating: 83 (99%+)
Originally Posted by JL View Post
Hi Guys I've been running the cyclone for a year now and have really struggled with a set up. I've tried a few and have made my own changes with no success. I got the Cyclone initially as I thought I'd gotten the best out my old faithful TC3 but since getting the Cyclone i think I've lost nearly 1/2 a second a lap!
I had the original chassis to begin with but moved to the BMI one a few months ago.
No matter what I do the car either just doesn't turn in or it just seems to almost stop mid corner (no traction compound as it's not allowed at my club). At least with this set up I seem to have Ok mid corner steering and it's easy to drive.
here's my set up:
Front:
- camber 2
- castor 6
- ride height 5
- droop 7
- toe angle 1
- toe block 2.5
- 2.5mm under camber link -
- inside cmber position 4
- no roll bars
- position 2 on shock tower
- 25lb spring (associated)
- 50wt oil
- 2 hole 1.1mm piston
- diff
- no roll bars all round
- GRP 42 Shore 59mm
rear:
- camber 1.5
- ride height 5.5
- droop 5
- toe block 1
- 2mm under camber lonk
- position 4 on shock tower
- 35lb spring (associated)
- 40wt oil
- GRp 37 Shore (59mm)
ackerman 3
Mazda Speed 6 shell
I've done everything I can to get more steering and the set up looks a bit extreme now. I hope someone can help as I've tried a few set ups including one's from Hara, Andy Moore and Marcos' without success.
Cheers,
Jason
you might want to try softer tires
alot of guys around here are running duble pink all around which is a 35 shore
the fronts you are running now are way to hard
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 12-22-2007, 08:02 PM   #10329
Trader Rating: 26 (100%+)
..ahhhh RCS Thailand. I went there every Saturday for two years. Well, maybe now "every" Saturday. But yea....
JoeyE is offline   Reply With Quote
Old 12-23-2007, 07:50 AM   #10330
JL
Thanks RaceAce701. I'll try the softer front tyres.... this is actually the car I bought second hand from you a few months ago. Cheers
JL is offline   Reply With Quote
Old 12-23-2007, 05:28 PM   #10331
kschu's Avatar
Originally Posted by LOSI123 View Post
that setup is like super crap man
Originally Posted by ShaunMac View Post
IRS Balance Buttons
Russ
thanks for your tips...any1 here ever DIY d Balance Button ?? 4 digital scales is quite expensive for a budget driver like me....does tweak station works?
Old 12-23-2007, 08:30 PM   #10332
pcar951's Avatar
Trader Rating: 19 (100%+)
You know the plastic buttons that are often nailed to the bottom of wooden chair legs. you can buy them at most hardware stores, home depot ect. it's a round plastic disc with a nail sticking out of it. that's what i use for balancing, works great, costs almost nothing.
pcar951 is offline   Reply With Quote
Old 12-24-2007, 03:12 AM   #10333
tomracing's Avatar
besides that 4scales will give you to much information not just weight balance.
the springs(preload) and swaybars will influence what you see on the scales.
you could be shifting weight wrongly when it was actually spring tweak.
therefore start with pins that will just show weight distribution on the car then go to scales at a later stage.
tomracing is offline   Reply With Quote
Old 12-24-2007, 06:26 AM   #10334
I do agree with you all the way. When using scales you have to tighten the springs down so your car is on the droop screws. I start with 3 points first, one in the middle ( point on the scale in the hole ) and set up wheels on the other two scales. I know it takes longer this way You can find new digital cooking scales for $20 and most of the time you only do this one time. When that is done you can set you sway bars and springs on all 4 scales. With LIPO's you have lots of wight to move so front to back is something you can look at. Most people have everything but the scales already and you can do all this with two scales.
Old 12-25-2007, 07:09 AM   #10335
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Atsushi Hara's kit during practise at Thailand.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
