Hot Bodies Cyclone
Well, if my info on spring rates is correct, I'm using 19 (HPI gold) up front and 17 (HPI silver) in the rear. Sway bars on both ends. Jack the Gripper compound on Sorex 28R tires. Traction and handling is excellent for stock, just as fast as any other car out there. Still trying to work the kinks out of the 10.5 setup.
Super Moderator
Would it be the same for a small technical track ( diff or one way ) and it looks like 20lbs front 15lbs back is a good place to start. My Cyclone has never flipped but it's not very good ether. It's sweet on asphalt but I just cant seem to be able to make it work for me on the rug, I run MM4600 with a BMI chassis................. Thank you very much for the help
Russ
Russ
Hey guys, I'm really glad to see so much discussion going on in here. It looks like there are a lot of questions regarding carpet setup (it is the season afterall). It seems like it would do a lot of good for me to take a weekend and hit up the carpet track out in AZ to try and gather some info to discuss on here. I'll try to get out there sometime in the next 3 weeks and then get back to you with findings.
*Now where does HB keep the keys to the company van?*
Super Moderator
Rubber
Super Moderator
I will put that set up on my car and try it Sunday!!!!!!!!!! I do not have a spool right now but I will get one, should I use a one way diff till I get the spool ??? Are you using a center one way with the spool ??
Thanks again
Thanks again
I know it's been posted before but I don't have all day to reread this whole thread, Can someone please post the part numbers for the new 18t pullies and any related parts needed for the gear change. Also will these fit the Cyclone S?
one way pulley
http://rcmarket.com.hk/product_info....oducts_id=1886
Direct pulley
http://rcmarket.com.hk/product_info....oducts_id=1793
Front belt
http://rcmarket.com.hk/product_info....oducts_id=1794
Rear belt
http://rcmarket.com.hk/product_info....oducts_id=1795
theres part numbers there if your buying from your lhs.... I ordered from them though...
Thanks Revo!!!
Well I have links lol...
one way pulley
Direct pulley
Front belt
Rear belt
one way pulley
Direct pulley
Front belt
Rear belt
Super Moderator
what size lipos will fit the cyclone? (hard case)
The Orion/Peak 3200 fits just fine, no mods required. Haven't tried any of the others.
