Old 12-04-2007, 10:27 AM   #10231
rcarmchl's Avatar
Trader Rating: 15 (100%+)
WOW - I had to add a ton to GET mine to 1525....even running NiMh...
Blizzard Concepts ~Big-Dog Graphics
Cyclone ~ Orion ~ LRP Sphere ~ S9550
M03 ~ Orion ~ LRP QC3 ~ S9550
RC18R ~ Castle Creations ~ Hi-tec
Slash ~ 9550 ~ SMC Power
8ight-T~9550~V-Spec
rcarmchl is offline   Reply With Quote
Old 12-04-2007, 10:32 AM   #10232
Woz
i've got a brushless 13.5 & Nosram ISTC motor/speedo combination, i have a low profile servo to put in to save a few more grams. I'm coming to the point where 50g is a lot of weight to have and im noticing performance differences compared to a mate thats running the same as i am but bang on the weight he's faster than iam.
Woz is offline   Reply With Quote
Old 12-04-2007, 10:34 AM   #10233
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by Woz View Post
can someone tell me what your using to get your brushless powered cars down to 1500g weight? im currently on 1549g with titanium screws and LW bodyshell.
thanks
Warren
micro receiver lrp speedo , futaba 9550 servo, orion vortex motor
Old 12-04-2007, 10:44 AM   #10234
Woz
my micro spektrum reciever is on its way, low profile servo is ready to go in, might remove the heatsink for the speedo. don't think there's anything else i can do but drill holes...
Old 12-04-2007, 12:00 PM   #10235
Super Moderator
Marcos.J's Avatar
not sure why i had to add a lot of weight to my cyclone to get it to the minimum weight, the cyclone is pretty light
Old 12-04-2007, 12:10 PM   #10236
slammin's Avatar
Trader Rating: 88 (100%+)
Send a message via Yahoo to slammin
Originally Posted by BillyCaldwell View Post
Are you using the aluminum outdrives? I found that when I had my car the hole the diff screw went through wasnt big enough and the diff screw was actually threading into the outdrive. I switched to ae diff screws soon after getting my car, and once I found that the screw was threading into the outdrive and fixed that, I never broke another one.
I am using aluminum outdrives.I will try the ae diff screw.Thanks for the info.
RC Addicts AR
Agama A8t
Agama A215e
Agama A215
Agama A215T
slammin is offline   Reply With Quote
Old 12-04-2007, 12:15 PM   #10237
Super Moderator
Marcos.J's Avatar
try also the hinge pins
Old 12-04-2007, 03:03 PM   #10238
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hey all...I hate to ask this question is its already been address, but...
Does anyone know what HPI Pro4 parts are compatible with the Cyclone?
Thanks!
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-04-2007, 03:09 PM   #10239
Woz
wishbones, "c" hubs, hub carriers. thats all i use tbh.
Old 12-04-2007, 04:27 PM   #10240
ShaunMac's Avatar
These are all I could think of right now.
steering blocks
hub carriers
c-hubs
front bumper assembly
pivot blocks
a-arms
outer hinge pins
shocks, springs
misc. hardware(screws, nuts, washers, ballstuds, etc.)
ShaunMac is offline   Reply With Quote
Old 12-04-2007, 06:28 PM   #10241
mangoman's Avatar
steering blocks
hub carriers
c-hubs
pivot blocks
a-arms
hinge pins
shocks, springs
That should be outer hinge pins and not inner hinge pins
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-04-2007, 07:09 PM   #10242
Joehwee's Avatar
Originally Posted by Lazer Guy View Post
Hi .... It's me again ........ The 2MM trust bearings and washers for my Cyclone will not fit when you use a bigger diff screw in the aluminum diff, so I would just like to know what some of you might be using.
Thank you
Forget about the AE screw, just get the following parts and you shouldn't be breaking the diff screw. Just make sure that you run a 2.6mm drill bit thru the centre of the diff outdrives.
http://www.hotbodiesonline.net/searc...=61535&lang=en
http://www.hbeurope.com/piw.php?lang=en&partNo=61544
Joehwee is offline   Reply With Quote
Old 12-05-2007, 06:38 AM   #10243
slammin's Avatar
I ordered the d4 slipper screw last night.I hope that will fix the problem.
RC Addicts AR
Agama A8t
Agama A215e
Agama A215
Agama A215T
Old 12-05-2007, 06:48 AM   #10244
Thank you..... JOEHWEE !!! I do drill them out to 2.6
After looking at all the post on here the only complaint's about the Cyclone have been about the diff. In mod to keep the diff from slipping I have to run it very tight and that is hard on the trust bearings and the screw. I have melted 4 diff's until I started running them tight. It's way cheaper to break the screw then to melt the diff. The stock diff is fine with stock up to 19 turn but for hi KV motors it just takes to much work keeping it smooth and not slipping. The aluminum diff helps but I have to bottom out the spring to keep it from slipping. I had the same thing with my PRO4 .
It looks like I have to have both the 61332 and 61544, I will get them!!!
Thank you very much
Lazer Guy is offline   Reply With Quote
Old 12-05-2007, 07:25 PM   #10245
mangoman's Avatar
Heya Joehwee,
With those two kits of diff screws, which parts do i need to use to get it going?
Or is it a case of use one or the other?
www.smaracing.org
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
