Old 11-27-2007, 03:47 PM   #10171
pcar951's Avatar
Trader Rating: 19 (100%+)
Default carpet setup
BTW: lower shock mounts = front - inside hole / rear - middle hole
pcar951 is offline   Reply With Quote
Old 11-27-2007, 04:02 PM   #10172
LOSI123's Avatar
Trader Rating: 63 (100%+)
I have the ver 3 spool up front & the derlin diff at the back.
and i have the mip purple cvd's that come with the WCE edition.
everything fits sort of.....
the only thing that bugs me is i have to take on and off the plastic ring on the derlin outdrives to get the dog bone in and out,
is this normal?
as to get them on and off on the car is a real pain in the.......
Team Durango - Speed Passion - Gens Ace
LOSI123 is offline   Reply With Quote
Old 11-27-2007, 04:44 PM   #10173
mangoman's Avatar
On the pro 4 it was never that hard to get those rings off, mine are usually mangled on the cyclone.
If you are really lucky you can pull the wheels and hex hubs off and slide out the uni and at the right angle i think you can get then take the uni out without taking the ring off. But thats quite a pain to do as well.
From a performance perspective the aluminium outdrives should be better but the blades are expensive. Just make sure you change the blades aka. the plastic C thingys aka. i think HB refer to them as diff adapters (or reverse them) before they wear out. Once you get wear on the aluminium outdrives the blades wear out faster (and unfortunately they are not cheap and sometimes very hard to get).
XRay blades will apparently fit as well if you are looking for something.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-27-2007, 08:25 PM   #10174
LOSI123's Avatar
on my old losi xxx-s one way it had a piece of paper with instructions that came with it, and it said to slightly grind down or file the pins on the dogbone so that it would fit in the outdrive expansion rings with out needing to be put on an angle.
I was concidering doing this and making sure i only take off a very small amount.
I had the alum diff halfs (outdrives) but they weared out very fast i thought.
i even had 2 sets and ran one with greese and one with out, but they both weared very fast, another racer at my track reckons that the derlin outdrives last heaps longer, so i am going to give that a go.
Old 11-28-2007, 01:55 AM   #10175
mangoman's Avatar
Are you sure you put the little plastic blades on the universals so that the metal on the universals wasnt rubbing on the aluminium outdrives?
www.smaracing.org
Old 11-28-2007, 02:17 AM   #10176
LOSI123's Avatar
yeah i did put them on, lol
Old 11-28-2007, 02:59 AM   #10177
Skill's Avatar
It is possible to get the driveshafts out of the delrin diff without taking the rings off. You just have to compress the suspension fully with the driveshaft pin pointing vertical. I never had to take the rings off except to get the bearings off the outdrives!
Skill is offline   Reply With Quote
Old 11-28-2007, 09:08 AM   #10178
rcarmchl's Avatar
Trader Rating: 15 (100%+)
For those of you running a platinum 4800 - how are you secureing the battery in the chasis?
I tape mine in and am having some spillage issues, I am sure that if I stay off the pipes that it would stay just fine with tape alone but I am not that good.
I am going to try the nexus weights. Do you guys have suggestions for a more dense weight to balance the car out?
Blizzard Concepts ~Big-Dog Graphics
Cyclone ~ Orion ~ LRP Sphere ~ S9550
M03 ~ Orion ~ LRP QC3 ~ S9550
RC18R ~ Castle Creations ~ Hi-tec
Slash ~ 9550 ~ SMC Power
8ight-T~9550~V-Spec
rcarmchl is offline   Reply With Quote
Old 11-28-2007, 01:12 PM   #10179
slammin's Avatar
Trader Rating: 83 (100%+)
Send a message via Yahoo to slammin
Duct tape, or wire ties,Works for full sale.
You could making some velcro straps.
RC Addicts AR
Serpent srx4
Serpent srx8
slammin is offline   Reply With Quote
Old 11-28-2007, 01:34 PM   #10180
LOSI123's Avatar
tryed this out, & sweet it works..
thanks..
Old 11-28-2007, 04:02 PM   #10181
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I use the TrakPower, so pretty much same size
I double tape my batts in (meaning I get one thing of tape on, and then another) and it REALLY keeps in the batts, they dont even move at all, and since its doubled up, it wont rip You just need good tape
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 11-28-2007, 05:25 PM   #10182
Is there anyone out there using the Associated diff screw??? What are you using for thrust balls and washers with that screw ???
Any help would be appreciated ......Thank you
Lazer Guy is offline   Reply With Quote
Old 11-28-2007, 06:39 PM   #10183
Use some spare plastic servo posts, put 2 down the centre where the exiting holes are to keep the pack straight, and drill a hole for a 3rd on infront of the battery pack. These will stop the pack from moving around and relieve the stress on the tape in a crash, worked a treat for me.
Besercoe is offline   Reply With Quote
Old 11-28-2007, 06:40 PM   #10184
Stew Noble's Avatar
Originally Posted by RC MARKET View Post
Andy Moore & Hara in Jmrca used new type rear ball diff & large diff ring
Exciting new diff soon!
// S N F //
Stew Noble is offline   Reply With Quote
Old 11-28-2007, 06:52 PM   #10185
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi, may i know wat the best setting for bearing holder position for stock race 23t ??
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
