Old 11-26-2007, 06:45 AM   #10156
padailey's Avatar
Originally Posted by mangoman View Post
Just get a hinge pin setup the pivot blocks then measure the height of the hinge pin at each block. Use a ride height gauge, i assume you have one of those?
Ok maybe I'm being totally dense here and these setups probably make perfect sense to others but I'm confused. Lets look at the front... to get the hinge pin level (3racing blocks) I have to raise the front about 1.25mm. No spacer in the back. So on a setup sheet if someone says to raise both blocks say 1.5mm are the arms level? On mine the front of the pin would be lower than the back.
padailey is offline   Reply With Quote
Old 11-26-2007, 08:20 AM   #10157
mangoman's Avatar
Originally Posted by LOSI123 View Post
Its only titanium coated im prety sure, which is just for looks in my opinion.
Personally ive never had problems with the diff screw. I had one snap once in a pro 4 but that was only because my mate said to tighten i up to the max because we were on carpet and i didnt have a spool.
There are two different thoughts with regards to the diff screw.
The first is to get an Asoociated diff screw which is some fat a$$ diff screw.
The second one and i think this is to help with the snapping problem but not sure (but ive always done it since i saw it and ive been running mod/19T) is to pop a shim in under the head of the diff screw when you build it.
Having said that im terrible with rebuilding diffs and only do it every few months or when the car suddenly is undrivable. When i rebuild the diff i usually just put in new diff rings (ive got about 20 sets of diff rings at home that i keep meaning to sand back) and replace the diff screw if it looks like its got some scoring on it, youll know what i mean if you look at the diff screw it will have scoring from where it looks like its been rubbing on the diff halves.
Also having said that i am currently running the delrin diff outdrives, although if you are running mod you should run the aluminium out drives as they are a lot more precise.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-26-2007, 09:35 AM   #10158
When you use the Associated diff screw what do you use for thrust balls and washers ??? I use Yokomo in mine, I also use aluminum out drives (Diff halves)
I run mod and I like my pro4 and my Cyclone but the diffs should be more like the XRAY I think. They have wave washers instead of a spring. I have made all the changes that have been suggested and I have a hard time keeping them from slipping.
Lazer Guy is offline   Reply With Quote
Old 11-26-2007, 01:26 PM   #10159
LOSI123's Avatar
Trader Rating: 63 (100%+)
mangoman:
do you know why there are some hd drive shafts that say front ans some are rear?
and when i looked up the specs of them they both apear the same length etc...??
LOSI123 is offline   Reply With Quote
Old 11-26-2007, 02:54 PM   #10160
slammin's Avatar
Trader Rating: 88 (100%+)
Send a message via Yahoo to slammin
Help I need a foam tire set up?Can some one help?
RC Addicts AR
Agama A8t
Agama A215e
slammin is offline   Reply With Quote
Old 11-26-2007, 03:04 PM   #10161
CHRIS CHAVEZ's Avatar
Does anybody know what the internal ratio with the original pulleys is as well as the ratio with the new 18 tooth pulleys. Thanks
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 11-26-2007, 03:17 PM   #10162
padailey's Avatar
Original 39\16 = 2.4375
new 18T 39\18 = 2.1667
Old 11-26-2007, 03:36 PM   #10163
Thank you very much.
TQ RC Racing
Old 11-26-2007, 06:09 PM   #10164
barber's Avatar
you are right it is coated and it breaks the same way.
BARBER SHOP RACING.
Hara Cyclone Edition,MAMBA 7700KV,Spectrum,
Mazdaspeed 6 Painted By McGoo Creations,
JR Z1,Orion 4300Mah,Ib 4200Mah,Ice,Rp,Trinity.
Race Prepaired & Driven By TEAM DRIVER (BARBER)
barber is offline   Reply With Quote
Old 11-27-2007, 05:23 AM   #10165
mangoman:
The fronts have a larger diameter shaft then the rear, they both work in the front or the back.
Old 11-27-2007, 07:09 AM   #10166
Barry White's Avatar
We'll see.
Barry White is offline   Reply With Quote
Old 11-27-2007, 07:20 AM   #10167
mangoman's Avatar
mangoman:
Actually im not too sure about that. I use the v2 HD Unis. However you need to use v2 oneway or v2/v3 spool to use them.
If you run a spool then the v3 spool is the best one around, the one-piece aluminium ones wear pretty quickly.
It might be the ball on the end is a different size (the bit with the pin through it that fits into the drive cups). Thats the difference between the v2 unis and the standard ones, or perhaps it could be the fronts unis are thicker to take more shock from a spool or oneway???? But only guessing
www.smaracing.org
Old 11-27-2007, 09:03 AM   #10168
pcar951's Avatar
Trader Rating: 19 (100%+)
Here's my stetup from last Friday's club race. Car was 3 tenths quicker with lilac fronts but was a little harder to drive.
Hope this helps.
Thanks to others on this thread for contributing to the setup!
pcar951 is offline   Reply With Quote
Old 11-27-2007, 11:14 AM   #10169
mangoman:
If you now have the 70710 drive shafts...... Then the 61043HD(larger in the middle) and 61044HD(smaller in the middle) steel, They both will fit the one way 70713 and diff 70715, They also fit the aluminum replacement diff half's 61332 if you use the plastic C thingys ( is that a word ) Thats whats on my car.
Hope that helps you.
Old 11-27-2007, 02:17 PM   #10170
slammin's Avatar
Hope this helps.
Thanks a bunch never ran foam on carpart so this help
RC Addicts AR
Agama A8t
Agama A215e
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
