Old 11-19-2007, 10:44 AM   #10126
RC MARKET's Avatar
Originally Posted by barber View Post
what about timing.
STD only fit many track ,only change gear ratio & keep check your motor temp
don't move the endbell angle change more faster ,
the motor will hoter .
RC MARKET is offline   Reply With Quote
Old 11-19-2007, 12:37 PM   #10127
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
my 10.5 is set at 1mm advanced timing geared at a 4.78FDR and after 8 minutes my motor comes off the track around 170-174 degrees, if you set your power and drag brake on the esc the motor will not get that much hotter than at zero degrees timing
Old 11-20-2007, 10:26 AM   #10128
RC MARKET's Avatar
under 80 deg C will ok !
Old 11-20-2007, 10:37 AM   #10129
barber's Avatar
marcos what esc do you run
BARBER SHOP RACING.
Hara Cyclone Edition,MAMBA 7700KV,Spectrum,
Mazdaspeed 6 Painted By McGoo Creations,
JR Z1,Orion 4300Mah,Ib 4200Mah,Ice,Rp,Trinity.
Race Prepaired & Driven By TEAM DRIVER (BARBER)
barber is offline   Reply With Quote
Old 11-20-2007, 11:05 AM   #10130
Super Moderator
Marcos.J's Avatar
lrp sphere tc
Old 11-20-2007, 11:09 AM   #10131
RC MARKET's Avatar
Andy Moore & Hara in Jmrca used new type rear ball diff & large diff ring
Old 11-20-2007, 03:10 PM   #10132
barber's Avatar
is this new type of diff available
BARBER SHOP RACING.
Old 11-21-2007, 06:29 AM   #10133
slammin's Avatar
Trader Rating: 86 (100%+)
Send a message via Yahoo to slammin
I just like to have a heavy duty diff screw one that want brake.The diff want stay tight and when I try to tighten it down the screw brakes.
I am impressed with the amount of steering this car as,I going to install the 6 degree c hubs to take some out.Other than my diff problems I am pleased with the car.
RC Addicts AR
Serpent srx4
Serpent srx8
Agama A215e
slammin is offline   Reply With Quote
Old 11-21-2007, 11:56 AM   #10134
2-Bad's Avatar
Trader Rating: 24 (100%+)
Put a 0.5mm washer under the diff nut and you shouldn't break anymore diff screws . Used a drop of "Lockite" in the diff nut thread during assembly and tighten diff screw and it should not loosen .
2-Bad is offline   Reply With Quote
Old 11-21-2007, 12:05 PM   #10135
RC MARKET's Avatar
& Some driver used D4 buggy 2.6mm Diff screw !
but need some edit your diff cup.
Old 11-21-2007, 01:13 PM   #10136
andyh's Avatar
Default ...
Originally Posted by JEMCIV View Post
quick question, does the HPi part #75168 (spool) work for the cyclone? The diff on my S is shot (even has those pretty aluminum housings too...sucks).
Not stock (ie.some people may have modified it to fit, but not recommended). You need (same part # in the US):
http://www.hbeurope.com/piw.php?partNo=61086&lang=en
Also to all Cyclone drivers...did you guys see:
HPI HB Challenge 08
The HPI HB Challenge races are on for 08....additionally we also have an HB Cyclone only series starting up in So Cal...
HB CHALLENGE
Thanks,
AH
Last edited by andyh; 11-21-2007 at 01:18 PM. Reason: Added more info...more again
andyh is offline   Reply With Quote
Old 11-21-2007, 06:34 PM   #10137
nitro rat's Avatar
Trader Rating: 5 (86%+)
can someone pm me a website where i can buy the cyclone cars please
thanks
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 11-21-2007, 09:06 PM   #10138
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Are you using the HB # 61089 Titanium diff screws? (Gold in color?)
Jaz406 is offline   Reply With Quote
Old 11-21-2007, 09:24 PM   #10139
I am hoping to get some help from you guys about a Cyclone setup on cs27's and 13.5 BL on Carpet.
I am loving the low speed steering but it carries no corner speed it's more of a point and shoot car at the moment.
Std chassis towers and top deck.
I like this car but I need a good starting point.
There is no stock rubber carpet setups on the HB E.U. site that I can find.
Any help is appreciated.
Old 11-21-2007, 10:19 PM   #10140
I just picked-up a Cyclone for some carpet rubber-tire racing - and eventually for some outdoor racing as well. What are the common parts that I should keep in my pit box. Someone mentioned that c-hubs tend to break a little easier then with some of the other chassis' out there... aside from having a couple arms and hubs, anything else?
Looking forward to trying to car out. Looks like there is tons of support out there for this car.
duckman996 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
