Old 11-09-2007, 06:58 AM   #10036
padailey's Avatar
Originally Posted by JonnySocko View Post
Padailey,
You must have your arms more than 1mm off the chassis. On my car you would need a ridiculous amount of spacers under the arm mount to hit the bulkhead. Double check the spacers under the arms, it simply shouldn't be touching if it's set like my setup. Maybe post a pic if you can, then we could help more.
Socko
I'm waiting on some parts so I haven't tried it again... but if I remember correctly I was trying to raise the blocks 1.5mm. Maybe 1mm would work...When I get the chance if it does not work I'll try some pics. Not sure my camera is good enough for a decent detailed pic but I'll try. Thanks.
padailey is offline   Reply With Quote
Old 11-09-2007, 07:30 AM   #10037
rc-zombies's Avatar
Originally Posted by Skill View Post
You shouldn't need the new belt unless you have the new pullies. The stock belt should be fine (it should loosen up a bit after running anyway).
NO!.. the new 18T pulleys will not fit with the old belts.
Old 11-09-2007, 08:17 AM   #10038
Skill's Avatar
Sorry I should have clarified that a bit better, what I meant to say was that if you are using the stock pullies then the stock belt should be fine and you shouldn't have to use the new belts. If the stock belts are too tight with the stock pullies then either it's because they are new and will loosen up or there is something wrong somewhere else.
Skill is offline   Reply With Quote
Old 11-09-2007, 11:39 AM   #10039
RC MARKET's Avatar
18T pulley Japan HPI no stock
RC MARKET is offline   Reply With Quote
Old 11-09-2007, 01:26 PM   #10040
LOSI123's Avatar
Trader Rating: 63 (100%+)
hi, anyone happen to know if a 80t spur and a 25t pinion will fit in a cyclone,
48pitch
LOSI123 is offline   Reply With Quote
Old 11-09-2007, 02:58 PM   #10041
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
What does that mean?
Im still waiting for them to get in stock! And then our fans also lol
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 11-10-2007, 08:40 AM   #10042
mangoman's Avatar
48pitch
81T Spur and 22T pinion fits fine so its pretty safe to assume that should be good
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-10-2007, 06:23 PM   #10043
We HB USA have them in stock. Please order at your local hobby shop.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 11-10-2007, 06:51 PM   #10044
Thanks,
We already spent the cash at rc market, and my track still hasnt gotten them..... And since we buy tires overseas, we threw them in
Old 11-10-2007, 10:55 PM   #10045
Trader Rating: 37 (100%+)
Send a message via MSN to slyts6
hey guys.
im getting a cyclone within the next few weeks and have a couple of quick questions about it.
first, how hard are the belts to remove? i had a Spint2
(i know its different) and both belts where an absolute pain to remove. do you have to bassically pull the whole car apart to remove them on the Cyclone?
second, i was looking at getting the Special Edition Drift version only because it comes with a bit of alloy bits and the fact that my bugdet doesnt quite allow for the Hara or Moore atm what ally bits does it come with and from the looks of the pics, does it come with CVD's?
http://www.rcmart.com/catalog/produc...ducts_id=24478
slyts6 is offline   Reply With Quote
Old 11-11-2007, 07:47 PM   #10046
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi, i need a advise for low traction track. My car now keep on slipping out during corner.
Tyre - HB Gumball - (suck tyre!)
caster - +1
camber front L/R - -0.05
Camber rear L/R - -0.05
Front / Rear Shock Oil - 25wt
Front shock piston - 1 hole
rear shock piston - 2 hole
Front hard spring
rear soft spring
front medium hard stabiliser
rear no stabiliser
Ride height front - 5
Ride height rear - 5.5
Droop Front - 5
Droop Rear - 6
Motor 23T stock
my video
please help me...thanks in advances
kschu is offline   Reply With Quote
Old 11-11-2007, 11:24 PM   #10047
LOSI123's Avatar
that setup is like super crap man
Old 11-12-2007, 12:58 AM   #10048
LOSI123's Avatar
caster - +1
Front hard spring
rear soft spring
rear no stabiliser
Droop Front - 5
Droop Rear - 6
Motor 23T stock
my video
You should copy Ronald Völker setup from the Hot Bodies Europe website.
its prety dialed for outdoor rubber tyre racing
http://www.hbeurope.com/setups.php?partNo=66450&lang=en
Old 11-12-2007, 01:23 AM   #10049
Skill's Avatar
First of all change the tyres. If the tyres are not giving enough grip then any setup changes cannot compensate for it, they are the only point of contact between the car and the ground.
Old 11-12-2007, 03:09 AM   #10050
AngryAsian's Avatar
caster - +1
Front hard spring
rear soft spring
rear no stabiliser
Droop Front - 5
Droop Rear - 6
Motor 23T stock
my video
I have no idea which car in the video was yours. But I can still have a guess at what's wrong with the setup.
Tires: Change them! Anything from Take-off/RP/Sorex. Check with the local fast drivers to see what their using. If the track is bumpy, then use a softer insert with more airgap.
Castor: 1 deg is probably too direct for such a large high speed track. Change to 4deg. This gives you much more stability.
Camber - check your tire wear. If the outer portion of the tire is getting worn, then use more camber. I'd try around -1. No more.
Roll centers - which blocks are you using on the car? Use a SMALL or very thin spacer under the blocks. Good for low traction tracks as the car rolls more to generate grip.
Maybe try heavier weight oil to calm the car down. Esp with the above changes.
Rear Toe: Use more toe if the rear kicks out. For MOD I never run anything less than 2.5, even more regularly 3.0deg
That's just a general observation. Hope that helps you on your way.
AngryAsian is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
