Old 09-15-2005, 04:29 PM   #991
ngo8's Avatar
Send a message via ICQ to ngo8
Originally Posted by rc-zombies
I've never had any problems with the 3yrs of ordering from them..
i never had any problems either they are very good they save you lots of money aspecially for me i am in canada we pay 14% tax here and duty so they help you that way .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 09-15-2005, 04:55 PM   #992
couple of dumb questions for you guys.Firstly has the Cyclone got the low friction shocks like the 2005 spec pro4 as the caps are shaped like the original ones's ? also surely these chassis are capable of fitting the larger 3700 / 3800 cells. Thanks guys
jim beam is offline   Reply With Quote
Old 09-16-2005, 03:24 AM   #993
Is anyone building one? First impressions?
Rick Draper is offline   Reply With Quote
Old 09-16-2005, 04:26 AM   #994
tcdrvr's Avatar
Mine is built, all that is left to do is put it on the setup guages and adjust everthing to be exact. Everything went together well (except the mispackaged bulkheads and the parts that I had to use from other manufacturer). I did drive the car on my street and it seemed very fast, however most cars I've had seemed fast on the street and turned out to be slow on the track. So I am looking forward to putting it out on a real track this Sunday.
There was one problem with the belt tensioner, if you read the instruction manual it says your are supposed to put a .75mm shim in between the two bearings, this is wrong. While I was working on the shocks last night my friend was looking at the car and the pic of the car from the box and noticed that the shim that was in between the bearings was the 2mm shim.
Also, the shocks are different from the Hara shocks. The bottom seal uses a thicker piece of plastic and only one o-ring. Also the adjusting collars don't have o-rings in them either.
tcdrvr is offline   Reply With Quote
Old 09-16-2005, 04:37 AM   #995
What parts from other manufacturer's have you had to use? That does not sound good.
Old 09-16-2005, 04:56 AM   #996
V12
V12's Avatar
tcdrvr
I see youīre having a Pro4 already. Does the Cyclone have the same position for the front and rear bodyposts as the Pro4 so you can use the same holes in the body or do you need drilling different holes?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-16-2005, 05:25 AM   #997
tcdrvr's Avatar
The parts that I used were a Tamiya center pulley and a pair of Tamiya diff outdrives to make a solid front diff. As I mentioned before I don't like one-ways and where I race a one-way is not competitive.
Bodies drilled for the Pro 4 will fit the Cyclone
Old 09-16-2005, 06:05 AM   #998
Does anyone run a KO servo? If so any pointers on which one i am best going for for 1/10 on road? I want one of the ones with the alloy heatsink.
Old 09-16-2005, 06:48 AM   #999
The one you are looknig for is the PDS 2363 ICS, im running one and i really like it.
you may also look at the new JR 9000 series servos they are supoesed to have something like .06 seconds transition time.
ATXPro4 is offline   Reply With Quote
Old 09-16-2005, 07:37 AM   #1000
Hollowman's Avatar
Send a message via MSN to Hollowman
I am still waiting on my cyclone from speedtech but i already bought alu servo mounts and a truspin spur gear plate. and i don't have to drill extra holes in my body
and tcdrvr is there a bar included or not, and are the shocks the new flourine coated ultra smooth shocks
greetings hollowman
Hollowman is offline   Reply With Quote
Old 09-16-2005, 08:18 AM   #1001
tcdrvr's Avatar
The car comes with a graphite plate for the Spur gear that looks like the True spin
I don't really know what you mean by "bar" the car includes all three thicknesses of sway bar for the front and rear. If you mean Battery bar then no . I made one from my one of my Pro 4's work with some drilling and dremel work. Hopefully this answers your question
Old 09-16-2005, 09:03 AM   #1002
V12
V12's Avatar
Is it possible adjusting the rear diff from the outside without removing the driveshaft/universal as itīs with the Pro4?
Old 09-16-2005, 09:06 AM   #1003
rc-zombies's Avatar
most likely you'll have to adjust from inside the outdrives... the design is on
majority of the diffs on any car.
Old 09-16-2005, 09:16 AM   #1004
andyh's Avatar
Default Cyclone bodies
The Cyclone rear bodyposts are a few mm behind (further back) of the Pro4 body posts.
andyh is offline   Reply With Quote
Old 09-16-2005, 09:22 AM   #1005
V12
V12's Avatar
Yes and thatīs one point I donīt like with my current Tamiya cars.
I heard the HPI Pro3 and Pro4 diffs could be adjusted from the outside and I think I have seen this also in the manuals. I just hope they have this with the Cyclone also as itīs a semi-HPI.
I know the diffs from the Losi XXX-S and the Xray cars also could be adjusted from the outside.
As difference to a conventional diff you just need a diffscrew made for this and a hole in the outdrive so itīs not much work for a manufacturer. But if you want to convert this afterwards itīs more of a problem.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
