Old 11-05-2007, 01:51 PM   #9991
TheCoolCanFanMan's Avatar
Originally Posted by TFR View Post
Not sure about others but here is mine. I don't know, I think I needed 100g more weights.
Hi
Where did you get those carbon looking weights please, or are they sticky back plastic? if so where can I purchase some please.Cheers
Malc TCCFM
TheCoolCanFanMan is offline   Reply With Quote
Old 11-05-2007, 01:56 PM   #9992
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Just get some carbon tape from parma or from you local auto zone....wrapem up!!!
rcarmchl is offline   Reply With Quote
Old 11-05-2007, 02:07 PM   #9993
nobody succeeds to help me?
daniel bongi is offline   Reply With Quote
Old 11-05-2007, 02:49 PM   #9994
Rick Vessell's Avatar
Hello,
I've been running the Cyclone for a while now on carpet. Here's what I ran this weekend in Omaha:
No front toe out in the blocks
2.0 mm front sway bar
25lb spring, Dk. blue Xray
600 wt. oil, 50 wt. equiv.
3.75mm spacer under camber link
3rd hole in on shock tower
inner hole on arm
4' caster
stock ackerman
1' toe out in tie rods
1mm spacers under blocks
longest camber link location on bulkhead
4mm ride height
2' camber
1mm droop over ride height
2.5' rear toe in the blocks
no sway bar
17.5 spring, White Xray
500 wt. oil, 40-45 wt. equiv.
1.5mm spacer under camber link
2nd hole in on shock tower
inner hole on arm
1mm spacer under blocks
4.5mm ride height
2.5-3' camber
Arms all the way back
.75 spacer behind rear hub
2mm droop over ride height
Magenta tires F/R
3/4 sauce front, full rear
Protoform DNA1 body
This is all with a box stock chassis. On anything except the highest traction this will work pretty good.
Good luck!
Socko
Rick Vessell is offline   Reply With Quote
Old 11-05-2007, 03:56 PM   #9995
Stew Noble's Avatar
Originally Posted by TheCoolCanFanMan View Post
Hi
Malc TCCFM
Dinky Speed produce cf look weights. I got some from Rainbow Ten a while back, they're also sold on RC Market.
Excellent meeting yesterday btw, thanks! :)
// S N F //
Stew Noble is offline   Reply With Quote
Old 11-05-2007, 04:27 PM   #9996
Thanks, we aim to please
Malc
Old 11-05-2007, 04:29 PM   #9997
Er Stew, how do I translate that site please?
Malc
Old 11-05-2007, 04:33 PM   #9998
sorted
Malc
Old 11-05-2007, 05:51 PM   #9999
padailey's Avatar
Originally Posted by JonnySocko View Post
Hello,
inner hole on arm
4' caster
stock ackerman
4mm ride height
2' camber
no sway bar
inner hole on arm
4.5mm ride height
2.5-3' camber
Magenta tires F/R
Protoform DNA1 body
Good luck!
Socko
ok I've wondered something for awhile about spacers under the pivot blocks. I have an "S" upgraded with 3 racing parts so that almost all the plastic is gone. You said you used a 0 degree block on the front with 1 mm spacers under the blocks. I've tried that with my Cyclone and it just won't work. The arms rub against the bulkheads.... not to mention the steering turnbuckles hitting the FR pivot. Most setups I've seen that have raised the front blocks are using the 2.5 degree. That I could possibly see because it would move the arms a little away from the bulkhead. How did you get yours to work.... any modifications?
I'm from the Omaha area but unfortunately couldn't race last weekend. Wish I could have seen your Cyclone run... unfortunately I'm about the only Cyclone guy around running TC anymore. Hope you enjoyed our facility!!
padailey is offline   Reply With Quote
Old 11-05-2007, 10:37 PM   #10000
Has anyone heard any rumors about a new HB touring car?
Colin F. is offline   Reply With Quote
Old 11-05-2007, 10:58 PM   #10001
mac853's Avatar
Not yet.
Only the newer Cyclone WCE, with 18T center pulley and longer belts.
If somebody could find evidence to confirm the release of new HB chassis, maybe i will take decision among coming TRF416.
mac853 is offline   Reply With Quote
Old 11-05-2007, 11:21 PM   #10002
Originally Posted by mac853 View Post
Not yet.
What kind of racing are you planning on using the trf416 for?
Old 11-05-2007, 11:44 PM   #10003
mac853's Avatar
I just want racing in 540 silver can class, in the case of Modified class has lack of drivers and 23T Sportsman class (my favourite) it's banned in my zone.
As Tamiya said it's for BL and control tire, in my eyesight it's just image promotion and pretext to release a car design copied from Xray. We must understand even in Japan it's not (yet) legally using BL system, i think should be good too in big turn motor races, due 23T is hugely famous to race on technical and narrow tracks of that country.
Of course 1 of my choice it's also Cyclone, because it's famous around me, then a lots of 540 clubman races in Japan are dominated by Cyclone of any versions.
Old 11-06-2007, 07:10 AM   #10004
Padailey,
You got PM sir.
Socko
Old 11-06-2007, 08:31 AM   #10005
barber's Avatar
everybody is hitting on a new cyclone but could some one from hotbodies confirm this.
BARBER SHOP RACING.
Hara Cyclone Edition,MAMBA 7700KV,Spectrum,
Mazdaspeed 6 Painted By McGoo Creations,
JR Z1,Orion 4300Mah,Ib 4200Mah,Ice,Rp,Trinity.
Race Prepaired & Driven By TEAM DRIVER (BARBER)
barber is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
