Old 09-15-2005, 05:06 AM   #961
tcdrvr's Avatar
It includes a front and center one-way. There is no spool in the kit for either the center shaft or the front diff. Mine came with all right side bulkheads so before you build yours make sure to check that you've got the right parts in your kit. Luckily I called Hot Bodies and they are sending the correct parts out to me immediately. I also was able to get a 415 pulley for the center shaft and with some creative shimming the 415 diff outdrives will work on the front.
tcdrvr is offline   Reply With Quote
Old 09-15-2005, 05:45 AM   #962
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Someone said you get all the roll bars and front hubs?
Is that correct tcdrvr?
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 09-15-2005, 06:02 AM   #963
Hollowman's Avatar
Send a message via MSN to Hollowman
tcdrvr you ordered from speed tech right i ordered form speed tech olso, so there is a big chance that i have not al the parts in the box, and the 415 pulley is that better than the orginal HB pulley ? I hope my kit wil arrive tomorrow
greetings hollowman
Hollowman is offline   Reply With Quote
Old 09-15-2005, 06:06 AM   #964
tcdrvr's Avatar
Andrew - You do get all of the sway bars in the kit but only the 4 deg. hubs.
Hollowman - Mine did come from Speedtech. The Tamiya pulley isn't better it's just a solid pulley for the front drive rather than the included one-way pulley. I forgot to mention that the car includes both center shafts for use of the center one-way and for using the fixed pulley. It just doesn't have the fixed pulley
Old 09-15-2005, 06:38 AM   #965
V12
V12's Avatar
What size is the spur gear?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-15-2005, 06:57 AM   #966
tcdrvr's Avatar
100 tooth Xenon Spur
Old 09-15-2005, 07:04 AM   #967
Skill's Avatar
Does anyone know if the Pro 4 outdrives will fit on the Cylone yet? And the CVD's?
Skill is offline   Reply With Quote
Old 09-15-2005, 07:10 AM   #968
fire929's Avatar
Default Cyclone
Will this chassis be allowed at HPI Challenges
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 09-15-2005, 07:14 AM   #969
tcdrvr's Avatar
I didn't try to fit the Pro 4 outdrives in the Cyclone since they are a lot shorter than the ones on the Cyclone. I thought I might be able to use the Spool from my Yokomo BD (which is wider than the spool from the Pro 4 by about 2mm) and it was about 4mm too short to work on the Cyclone so the Pro 4's would be about 6mm too narrow.
Old 09-15-2005, 07:25 AM   #970
Skill's Avatar
Is it the slot which the bearing goes onto which is too narrow? I was just wondering if it was possible to run the Pro 4 outdrives and CVD's together instead...
Old 09-15-2005, 07:28 AM   #971
tcdrvr's Avatar
No, it's the actual length of the outdrives that's too short. I compared the axles to the pro4's and oddly they seemed to be the same length.
Old 09-15-2005, 07:29 AM   #972
Does the car use the same bearings as the Pro 4?? i.e the 10*15*4 and the 5*10*4? Thanks. Jonathan
jonny69 is offline   Reply With Quote
Old 09-15-2005, 08:22 AM   #973
rc-zombies's Avatar
Originally Posted by jamescam
You may want to check the RC Model thread before ordering from them. They have screwed around more than one RC Tech.net member.
I've never had any problems with the 3yrs of ordering from them..
Old 09-15-2005, 08:23 AM   #974
Skill's Avatar
So theoretically you could use Pro 4 outdrives and CVD's (as the Pro 4 CVD's will be longer than the Cyclones universals)?
Old 09-15-2005, 08:26 AM   #975
rc-zombies's Avatar
I think the cyclone cvd's are like 44mm long.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
