Old 09-21-2007, 09:52 AM   #9676
mangoman's Avatar
Just run the Cyclone S as it is, as mentioned dont bother trying to hop it up it would be easier and cheaper to buy the moorespeed kit.
For the S replace the C hubs with the proper carbon graphite ones (like on the full moorespeed/pro 4, the ones in the kit will literally break in your first or second race meet.
When building the shocks make sure the shafts dont bind in the ends of the shock caps, if they do ream them out slightly.
The only other thing to look out for is if you upgrade to a spool or oneway you have to upgrade the entire centre pulley system so that the front belt uses a proper metal centre pulley, the plastic ones will strip otherwise.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 09-21-2007, 11:41 AM   #9677
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
the reason why i wanted the the RTR version is because she doesnt have any radio equipment!! At least the low end stuff will get the car going...so what's the chassis i need for the RTR to at least get it going?
badKarma is offline   Reply With Quote
Old 09-21-2007, 03:35 PM   #9678
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
For the money put into upgrades
You could do the cyclone, and a cheap radio, used if you want it really cheap...
I would shoot for the cyclone, and then theres no upgrades needed, well maybe some things you think, but it has all the al and graphite parts
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-21-2007, 06:16 PM   #9679
RMF-888's Avatar
Send a message via Yahoo to RMF-888
hi guys anyone try to convert the 39T pulley to a ta05MS like pulley?
RMF-888 is offline   Reply With Quote
Old 09-22-2007, 12:05 AM   #9680
mangoman's Avatar
Just use the standard chassis, some people have had them snap at the rear, but if you end up upgrading the decks i would suggest replacing the upper and lower decks at the same time. When you only replace the lower deck the upper deck sits really funny.
Replacing the decks has the added advantage of lowering the weight of the car significantly!
www.smaracing.org
Old 09-22-2007, 12:36 AM   #9681
RC MARKET's Avatar
can't
RC MARKET is offline   Reply With Quote
Old 09-23-2007, 05:22 PM   #9682
Vicko's Avatar
Trader Rating: 14 (100%+)
so RC MARKEY when are u goin to have the
18t center pullys and belts from Hot Bodies for the cyclone in stock
Vicko is offline   Reply With Quote
Old 09-23-2007, 06:23 PM   #9683
barber's Avatar
how good is the tread lock from hpi for using it in a rear diff,my rear diff is slacking up to regular.
BARBER SHOP RACING.
Hara Cyclone Edition,MAMBA 7700KV,Spectrum,
Mazdaspeed 6 Painted By McGoo Creations,
JR Z1,Orion 4300Mah,Ib 4200Mah,Ice,Rp,Trinity.
Race Prepaired & Driven By TEAM DRIVER (BARBER)
barber is offline   Reply With Quote
Old 09-23-2007, 07:02 PM   #9684
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
anyone know if hot bodies making a new touring car soon?
Roberto Falcon is offline   Reply With Quote
Old 09-23-2007, 08:29 PM   #9685
I sure hope not......
Old 09-24-2007, 06:12 AM   #9686
JL
Does anyone know what has happened to "hara build tips" webpage. I tried clicking on the link but it seems to have gone!
JL is offline   Reply With Quote
Old 09-24-2007, 06:24 AM   #9687
Stew Noble's Avatar
Mirage Japan recently moved their website.
http://www.miragejapan.co.jp/AH/setting/cyclone01.htm
// S N F //
Stew Noble is offline   Reply With Quote
Old 09-24-2007, 06:32 AM   #9688
JL
Thanks for the quick reply Stew.
Also, I've just sent you a pm about your Stonehaven (MuchMore UK GP) set up. Need some advice! Hope you can help.
Cheers,
Jason
Old 09-24-2007, 06:42 AM   #9689
Trader Rating: 27 (100%+)
Originally Posted by RC MARKET View Post
yes instock !
Do you have a blue one in stock?
JoeyE is offline   Reply With Quote
Old 09-24-2007, 08:58 AM   #9690
Anyone that race foam on carpet tried using the sway bars with the cyclone?
I notice that with most of the setup they don't include the use of the sway bars with carpet, but most of the Losi racers use the sway bars is it because the cars are different or just a matter of preference? thank you.
Ramyuras is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
