Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 08-30-2007, 05:47 AM
  #9541
LOSI123's Avatar
Trader Rating: 63 (100%+)
Is a diff to tight or to loose when you hold the spur gear and one back wheel fixed, and try to turn the other back wheel and it turns but is reasonably hard to turn........
or is this just right???
i specificaly wanted to know how it should feel when the diff is in a totally assembled car..
thanks......
LOSI123 is offline
Old 08-30-2007, 06:31 AM
  #9542
TheCoolCanFanMan's Avatar
Originally Posted by 2-Bad
Bout time you updated your avatar isn't it mate...
Yea but everyone knows its me dude then
TheCoolCanFanMan is offline
Old 08-30-2007, 08:11 AM
  #9543
Skill's Avatar
thanks......
That's exactly how I have my diff set and it runs fine.
Skill is offline
Old 08-30-2007, 11:04 AM
  #9544
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
thats how i was alwast told 2 set them
you can adjust from there a little tighter or loosed depending on how the car reacts or ur driving style I light a little tighter front diff
RaceAce701 is offline
Old 08-30-2007, 11:31 AM
  #9545
barber's Avatar
Default spacers under pivot blocks
now my hara cyclone did not come with any pivot blocks spacers. but when i check hara and andy setup sheets i see they are using them what effect do they have on the handling and what is a good starting point for asphalt.thanks
barber is offline
Old 08-30-2007, 11:54 AM
  #9546
rc-zombies's Avatar
the spacers effect the roll center..
try Hara's base asphalt setup.
rc-zombies is offline
Old 08-30-2007, 12:22 PM
  #9547
barber's Avatar
anybody has the part # for the center shaft not the one way.
barber is offline
Old 08-31-2007, 12:33 AM
  #9548
70743 Cyclone Center Layshaft (Direct pulley)
mek_rath is offline
Old 08-31-2007, 03:08 AM
  #9549
Phil C's Avatar
thanks......
Try to build it so the diff action is super smooth and free but its nearly impossible to get it to slip. I run mine so it slips right before the rear belt skips
Phil C is offline
Old 08-31-2007, 06:05 PM
  #9550
barber's Avatar
thanks.
barber is offline
Old 08-31-2007, 06:32 PM
  #9551
Vicko's Avatar
Trader Rating: 14 (100%+)
hey are takeoff rubber tires like 63mm?
Vicko is offline
Old 09-01-2007, 02:02 PM
  #9552
Trader Rating: 17 (100%+)
Hey Guys, I have a post in the wanted section for a Hot Bodies Cyclone. If any body has one for sale, please post in my ad in the wanted section, or email me at [email protected]
Thanks Chico.
Chico is offline
Old 09-01-2007, 02:21 PM
  #9553
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
yes
Marcos.J is offline
Old 09-01-2007, 03:12 PM
  #9554
RC MARKET's Avatar
Take Off & RP tire is 63mm
RC MARKET is offline
Old 09-03-2007, 05:30 PM
  #9555
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Help me out guys
I am going to race brushed 19turn (not BL and 5 cell yet) And I used to race stock
What from my set up should I change? I was running BL stock, Cant afford a 10.5 yet
BlackedOutREVO is offline
