Old 08-28-2007, 09:00 AM   #9526
Core Creations's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to Core Creations
I'm assuming this is with foams....I've used as much as 3-3.5 negative on the camber to keep the tires square.
Originally Posted by Ramyuras View Post
Cyclone racers I have a quick question, I am having problems with my rear tires wearing on the outside even with a 2.5 neg camber the tires still wear faster on the outside than the inside, on most of the TC cars I have race the wear is on the inside but the Cyclone wear on the outside, is there anyone that is having this wear problem? and if so what did you do to get it wearing on the inside? thank you.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 08-28-2007, 09:07 AM   #9527
I was thinking the same but with all that camber what do you think will happen to the handling of the car? I am using the BMI chassis I am thinking if that has anything to do with the issue at hand because before I went to the BMI chassis I didn't have that problem.
Ramyuras is offline   Reply With Quote
Old 08-28-2007, 09:32 AM   #9528
TheCoolCanFanMan's Avatar
Hi Guys
I ran the Clone for the 1st time at the weekend in the KO in the UK. What a car, it goes exactly where you want it to go. I made 7th in the A, and came 8th overall 'AWSOME CAR'. Thanks to Stew Knoble, Elliott Harper and Paul Upton for the setup.
Cheers Malc TCCFM
TheCoolCanFanMan is offline   Reply With Quote
Old 08-28-2007, 09:32 AM   #9529
No it doesn't hinder the performance at all. In fact the tires coning hinders the car much more.
Uusally you get that type of wear beacuse there is some play in the bearings (Normal). When you set the car up statically the camber is 2 or 2.5...but when the car is running and the play in the bearings comes into play you can have as little as maybe 1-1.5 neg camber.
Old 08-28-2007, 09:54 AM   #9530
RaceAce701's Avatar
Trader Rating: 83 (99%+)
mine cone slighthy at 2.5 camber but our track is super tight and the rear is sliding around most of the corners I just retrue the tires after every 2 runs to keep them square
I thind it matters more on the track surface and layout more that anything else. because when i ran on a bigger track there was more coning but there was alot of high speed sweepers putting alot of side load on the tires and makin them roll over and compress
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-28-2007, 11:18 AM   #9531
Default Carpet/Foam
Does anyone know or have a good starting point setup for carpet/foam tires ?
I just got a used Cyclone with the BMI chassis..
John Q is offline   Reply With Quote
Old 08-28-2007, 11:58 AM   #9532
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by TheCoolCanFanMan View Post
Hi Guys
Cheers Malc TCCFM
Big difference from our previous car eh Malc???? It's staggering how much simpler it is to our old cars and yet it performs soo much better .
2-Bad is offline   Reply With Quote
Old 08-28-2007, 12:24 PM   #9533
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Hi Guys
Cheers Malc TCCFM
I thought you drove a Losi Type R or an Mi3 a few months back? Why the change to the Cyclone?
yyhayyim is offline   Reply With Quote
Old 08-28-2007, 01:02 PM   #9534
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
here you go!!
Old 08-29-2007, 02:01 AM   #9535
Hi 2-bad
Yea a mahusive difference in every way shape and form. The Losi Type 'R' is NOT a bad car, it just works more on foams on tarmac than it does with rubber in my eyes, but the Clone has everything I want, steering, mid corner, and out of a corner speed if my Q2 hadn't gone off (I should have reset it on the day) as they tend to wander off its settings, I reckon I could have gone around 5-6 seconds quicker. Very very happy with the new car.
Cheers Malc
Old 08-29-2007, 06:24 AM   #9536
John_S's Avatar
Did you wander much from the kit setup with your car mr fan man
John_S is offline   Reply With Quote
Old 08-29-2007, 06:35 AM   #9537
Hi
To honest I didn't even look at the kit setup, and used the what Stew Noble's set-up and it was awsome, but I do know that they changed the set-up over the weekend and the car look real good. The only thing I changed on the car was the rear upper deck from the purple ali part to the carbon fibre part which made the car feel more consistant and planted on the rear deck when I pushed the car harder. I am waiting on the set-up the Clone camp ended up on, bearing in mind they run brushless 5 cell mod as I run 19t brushed
Cheers Malc TheCanMan
Old 08-29-2007, 08:21 AM   #9538
John_S's Avatar
ye i was at the gp at the weekend but struggled a bit all weekend and only ended up in the d final. That was with my mi2ec and think i need a bit of an upgrade and i always liked my freinds cyclone so i have got one to try and im just setting it up as the worlds kit basic setup but it would be nice if i could have a look at yours also to see any differences.
Old 08-29-2007, 08:36 AM   #9539
Hi
Look at post #9475 thats the setup what I used
Malc
Old 08-29-2007, 09:08 AM   #9540
Super Moderator
Marcos.J's Avatar
here is a great set up to start!!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
