Old 07-25-2007, 12:19 AM   #9211
TFR
TFR's Avatar
Originally Posted by rc-zombies View Post
I run a 106/48 5.07fdr.
Does this combo even mesh correctly on the normal motor mount?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 07-25-2007, 03:36 AM   #9212
BrainTeased's Avatar
Originally Posted by ICEMAN View Post
BMI outdoor kit is a AWESOME upgrade for a Cyclone.
who stocks the BMI asphalt kits? anyone got pics of what it looks like? or is it just the chassis and top deck that is replaced?
BrainTeased is offline   Reply With Quote
Old 07-25-2007, 06:23 AM   #9213
Rogier's Avatar
I just looked at those..and you're right.. I may have to get a full set of the looser version but in aluminum from 3Racing:
std. setup
looser adjusters:
How sure are you that the red ones are looser?? I actually don't really see a difference except the color.....
Dodgeguy-> I just ordered the set of the Cyclone S. I assume they will also fit in the Hara edition... ?
Rogier is offline   Reply With Quote
Old 07-25-2007, 06:50 AM   #9214
John Doucakis's Avatar
Getting ready for the European Champs in one week.
John Doucakis is offline   Reply With Quote
Old 07-25-2007, 07:51 AM   #9215
SammyZ's Avatar
Trader Rating: 138 (100%+)
anybody know if the price of the Andy moore WCE kit will drop since its like almost 3 years old?
SammyZ is offline   Reply With Quote
Old 07-25-2007, 08:17 AM   #9216
bxpitbull's Avatar
The Andy Moore cant be that old, it just came out like a year and a half ago. Maybe Hara's is that old, Sukiharn, but not Moore's. Heck, Atsushi Hara won the on-road worlds asphalt in 2004 with the Pro4....
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 07-25-2007, 08:35 AM   #9217
rc-zombies's Avatar
look at the thickness at it's thinnest section..
the red ones are a little thinner than the purples...
not sure... I have the BL motor mounts..
Looks good! how'd you get it to be so purple? I know stock turnbuckles are more blue..
and wouldn't it be better to have the transponder closer to the front? especially if the race is decided by milliseconds..?
Old 07-25-2007, 09:27 AM   #9218
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Originally Posted by Vicko View Post
hey so has anyone tryed the BMI asphat chassie or is the stock 1 ok?
also is the andy moor kit have an different chassie then the old blue kit?
The BMI outdoor chassis setup sells for about 125 dollars.
Anyone use the stock plastic Cyclone S chassis for outdoor racing? It sells for about 20 dollars US? My asphalt track is rather bumpy and unprepared. I have a feeling that I will ruin the carbon fiber chassis and may break it. Is this a good replacement without losing any performance?
cpatel529 is offline   Reply With Quote
Old 07-25-2007, 11:57 AM   #9219
mangoman's Avatar
As long as the other car aint a cyclone, if its that close its probably easier to accidentally hack the other guy
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 07-25-2007, 12:05 PM   #9220
mangoman's Avatar
With the tub chassis from the Cyclone S i would suggest not using it if you have a proper kit.
I had a Cyclone S buts its been upgraded. The chassis snapped at the back between the rear pivot blocks and a few other people have had this problem with the tub chassis. I personally suspect the cause had something to do with the aluminium pivot blocks which i upgraded on the car.
You may find that the top deck will have to get shimmed strange if you add a tub chassis to the car (although im not sure about this).
The tub chassis is also a lot heavier.
The chassis is gunna get scratched anyway and id be surprised if everyone at the track was using a tub chassis on their car.
Round the edges well (the outside one) with a dremel and then seal with CA glue to help the chassis edges getting hacked up and then raise the ride height.
Ask the more senior racers at the track to help you with a good ride height to use.
www.smaracing.org
Old 07-25-2007, 02:23 PM   #9221
Anyone have a picture of Hara's car that is referred to in this setup?
http://www.hpiracing.co.jp/contents/...ara070121C.pdf
the note on the bottom of the pages say:
"Using the main chassis of cyclone S"
Want to see what the rest of the car looked like with this chassis.
Also, since I am running lipos, wouldnt having a little heavier chassis be not that bad of an idea.
Old 07-25-2007, 02:34 PM   #9222
well if you mean the IFMAR ISTC Worlds 2004, it was 19 year old Marc Rheinard taking the crown.
omoser is offline   Reply With Quote
Old 07-25-2007, 02:36 PM   #9223
i head serious glitches mounting the transponder onto the receiver and would not recommend it
Old 07-25-2007, 02:39 PM   #9224
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Originally Posted by cpatel529 View Post
Anyone have a picture of Hara's car from the SWR 06 Nats last year? Here is a setup that was suggested for stock asphalt/rubber and he uses the Cyclone S chassis. Want to see what the rest of the car looked like.
Also, since I am running lipos, wouldnt having a little heavier chassiss not that bad of an idea.
that does not open to set up.
bigb11 is offline   Reply With Quote
Old 07-25-2007, 02:40 PM   #9225
fixed problem with link....
Chirag
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
