Old 07-18-2007, 08:53 AM   #9151
so basically if i want to run a 7700, i need to do some dremeling? :-) this could be dangerous
nc racer is offline   Reply With Quote
Old 07-18-2007, 02:22 PM   #9152
There isn't much to dremel, put the motor in and slide it back all the way and look at the can screws. My motor is mounted so the wires come out on top. No dremeling needed for the 110, just a file. If you run the 7700 with 110-25 it's going to run the coolest, I have used 110-25 & 26 & 27 It will get to hot with 27. You can get a brushless bulkhead for the Cyclone if you like. ..........Start with..... Punch at 40, timing at lowest , brake at 30, drag brake at 10 or less.
Good luck and let us know how it go's
Lazer Guy is offline   Reply With Quote
Old 07-18-2007, 03:08 PM   #9153
Trader Rating: 22 (100%+)
Originally Posted by mangoman View Post
I dont think they are actually lighter. I was looking at them from a durability point of view.
They are over 1 gram lighter I think each.
bjspinner is offline   Reply With Quote
Old 07-18-2007, 03:38 PM   #9154
Originally Posted by fast-ho-cars View Post
you will not be able to use Kimbrough gears, they have 6 inner holes and only line up for TC's that use 3 screws to mount the spur.
Yes you can.. you just use 2 screws instead of 4. It's also a good idea to run the carbon plate on the spur when only using 2 screws to help prevent any chance of a wobbly spur...
Serzoni is offline   Reply With Quote
Old 07-18-2007, 04:26 PM   #9155
thanks for the help lazer!one more thing, speaking of wobbly. my rear pulley has a slight wobble/play in it from side to side, is this normal or am i missing a washer or two?
Old 07-18-2007, 04:31 PM   #9156
rc-zombies's Avatar
diff pulley wobble is normal.
Old 07-18-2007, 07:36 PM   #9157
http://www.redrc.net/2007/06/hb-gumb...-diff-upgrade/
Has anyone tried running the new D4 diff bolt in the Cyclone?
I would say you will need to drill out the diff centres a little to accomodate the larger bolt, however i would think the peace of mind would be worth it.
Besercoe is offline   Reply With Quote
Old 07-18-2007, 09:57 PM   #9158
rc-zombies's Avatar
yes it will work with some drilling...but only problem I see is that the T-nut is longer..
Old 07-19-2007, 12:15 AM   #9159
Trader Rating: 28 (100%+)
What are peoples findings when it comes to CVD's and Universals when it comes to steering deflection or turning radius? I have been running the original Aluminum Hara bones in my Andy Moore edition car with excellent results.I change to the Steel version 2 bones today and it seemed to have developed a little chatter where the Alums had none.I haven't run the CVD's that came with the kit yet and was wondering what you thoughts are on this.
My car is really fast ,but this kind of bothers me about running the steel bones.Any hints or suggestions? Btw the car was obscenely fast in the main tonight but I changed back to the Aluminum bones.Could it be the fact that the steel bones weigh alot more in rotating mass?
racenut123 is offline   Reply With Quote
Old 07-19-2007, 07:05 AM   #9160
Get back to work Xray man!
Tony Vega is offline   Reply With Quote
Old 07-19-2007, 08:18 AM   #9161
nice!
Old 07-19-2007, 10:59 AM   #9162
linger's Avatar
nice!
racebutt,
This isn't the dirt oval thread. Get out.
If you want to make the chatter completely disappear with your Hotbodies car...come see me.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 07-19-2007, 11:42 AM   #9163
Hey, Ling...did your dog have his own cartoon series once?
DOTMAN is offline   Reply With Quote
Old 07-19-2007, 11:42 AM   #9164
rc-zombies's Avatar
Originally Posted by linger View Post
racebutt,
oh..Ling..
show me the way..
Old 07-19-2007, 08:49 PM   #9165
Trader Rating: 27 (100%+)
The aluminum take vibrations better than the steel bone so the chatter is not as much when running spool. The rotation of steel bones rotate better because of spinning dead metal weight(sometime makes you push). The aluminum is lighter and quicker but will ware out faster when running a spool.
Just my thought.
JoeyE is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
