Hot Bodies Cyclone
#9136
Thanks. I wanted to get the tit axles to pair up with the steel dogbones to lighten them a little.
#9137
#9138
I have the black Cyclone with a 7700 mm and use 110-25, 100 will not work..You will have to put a small notch in the bulkhead for one of the Mamba max can screws to get the 25 to work right. Also a little notch to get the 110 in but not much.
My motor runs around 165, speedo 135 with rubber tires.
Now go woop some 3.5's
#9141
i dont really wan to modify the mounting plate to get gearing. is there any way you could run A 48P spur, say maybe a associated or something, they look like they would mount the same?
#9143
You can run 48dp gears but they will pose the same gearing problem as the diameters of the gears will be the same they'd just have less teeth.
#9144
so basically if i want to run a 7700, i need to do some dremeling? :-) this could be dangerous
#9145
Good luck and let us know how it go's
#9148
thanks for the help lazer!one more thing, speaking of wobbly. my rear pulley has a slight wobble/play in it from side to side, is this normal or am i missing a washer or two?
#9150
http://www.redrc.net/2007/06/hb-gumb...-diff-upgrade/
Has anyone tried running the new D4 diff bolt in the Cyclone?
I would say you will need to drill out the diff centres a little to accomodate the larger bolt, however i would think the peace of mind would be worth it.
