Old 07-16-2007, 11:43 AM   #9121
RC MARKET's Avatar
Originally Posted by bjspinner View Post
I have been using them for 12 months they are good
the 18 tooth pulleys your rear belt wil be to tight
Yes !
RC MARKET is offline   Reply With Quote
Old 07-16-2007, 12:47 PM   #9122
Where did you find those?
Originally Posted by mangoman View Post
Just wondering, has anyone used the square titanium axles and cross joints?
I have a set of the square titanium universals for my pro 4 and they were pretty solid. At the time i couldnt afford to buy the axles and the cross joints.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 07-16-2007, 01:07 PM   #9123
rc-zombies's Avatar
yes! 18T way too tight! the 17T is a little tight even with the main pulley at it's loosest position.. I think eventually with the 17t.. the belts should start to loosen up after several runs..
with the 17T the transmission ratio changes to 2.2941 : 1
I will try the 18T with a smaller 36T pulley from my old Pro3 and will have a 2.0:1 ratio.
If HB does release a 18T pulley..hope they have new belts to go with them.
Old 07-16-2007, 01:28 PM   #9124
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
I am looking for a place that has the P-Dub bumper and the hardened V2 universals and V3 spool in stock. Anyone know of a place. The sites that I have gone to have one or the other or do not say what their stock status is.
Chirag
cpatel529 is offline   Reply With Quote
Old 07-16-2007, 01:29 PM   #9125
afaik HB will release both a new front and rear belt, also saw them on thomas pumplers cyclone
omoser is offline   Reply With Quote
Old 07-16-2007, 03:23 PM   #9126
stuey's Avatar
you may find yokomo bd belts may fit as they wrap around a 20t centre pully and 40t diff pully i havent tried this but it would sound about right also a had cyclone belts on my 415 with an 18t center pully and 36t diff pullys that was spot on then i saw the light and bought the rest of the car
stuey is offline   Reply With Quote
Old 07-16-2007, 05:07 PM   #9127
Default Front arm sweep
Wondering what other Cyclone owners think about front arm sweep. Overall, it's felt to me like the 2.5 degree block the kit comes with provides a lot of steering, almost to the point of destabilizing the car. I usually seem to end up running with 1 or 0 degrees (either with the spool or one way). Of course, I've seen others run successfully with the 2.5 degree block. Thoughts? Thanks.
Andy
adavid is offline   Reply With Quote
Old 07-16-2007, 11:47 PM   #9128
Rogier's Avatar
Andy
The 2.5 degree suspension block was the first thing I changed on my HB. Steering was way too aggresive. I now have 1.0 degree block mounted and it's running much smoother! You could also try a 1.5 degree block. I have the one way installed because I run stock class. (19t element with 5 cells)
Rogier is offline   Reply With Quote
Old 07-17-2007, 08:07 AM   #9129
mangoman's Avatar
Thanks for the feedback bjspinner
porschejim911, i havent seen them around much. I think rc-champ get them in occasionally.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 07-17-2007, 09:42 AM   #9130
SammyZ's Avatar
Trader Rating: 138 (100%+)
the cyclone black kit went back up to $376 at tower! and Stormer doesn;t eve have them?
Where is the best place to buy one cheap?
SammyZ is offline   Reply With Quote
Old 07-17-2007, 09:50 AM   #9131
Trader Rating: 28 (100%+)
Back to full price I guess.
racenut123 is offline   Reply With Quote
Old 07-17-2007, 10:18 AM   #9132
ok guys, just got my black edition in (thanks dodgeguy!) and need to know what to buy to get this thing set up for some parking lot racing. also what pinion should i use on a 100t spur running a mamba max 7700?
nc racer is offline   Reply With Quote
Old 07-17-2007, 11:58 AM   #9133
rc-zombies's Avatar
I found a source for the OEM belts that HB uses..
I'm getting prices and availability for longer belts to
fit the 18T Pulley/39T diffs.
might be awhile before we see HB parts in the US. and I do not
want to wait..
I know the Pro3 172T Low friction belt will fit the front.
it's the rear belt I can't find..stock is 62T. need like a 65T
soon as I find out more on the belts.. let you all know.
Old 07-17-2007, 12:16 PM   #9134
thanks zombies, also will ask Thomas whether he knows specifics regarding release date
Old 07-17-2007, 01:09 PM   #9135
TFR
TFR's Avatar
I'm building my Cyclone with SS10.5 Novak combo and was wondering what spur and pinion do you guys would recommand for rubber carpet, large track.
Thanks.
EDIT: Would a 108T and 48T mesh correctly on the black Cyclone with original bulkheads?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
