Old 07-04-2007, 08:24 PM   #9001
tc3 racer sc's Avatar
Default shock pistons
what different going from stock piston on the cyclone to a harder piston like a number 3. hpi piston in the front shock when running carpet or should i keep it at stock setting just trying to prepare for carpet agin thxs try different things thxs reggie
tc3 racer sc is offline   Reply With Quote
Old 07-05-2007, 09:45 AM   #9002
Originally Posted by porschejim911 View Post
I have a 108 in mine that looks like the max.
Now we have the option parts called "Low gear unit" that allow you to use bigger spur gear for the brush less motor.
#61298 Low Gear Unit (Black)
#61329 Low Gear Unit (Purple)
#61360 Low Gear unit (Blue)
when you use these units, you will be able to have smoother drive train too,due to the less angle belt mounts. Even if you're not brush less system user, these parts are still good for you guys.
in addition, we will soon have 18T drive pulley that is 2 tooth bigger than the original one. This will make the drive train way more free!!
Hi-LowBlow is offline   Reply With Quote
Old 07-05-2007, 09:49 AM   #9003
Originally Posted by turtle View Post
I see you can buy a special motor mount for brushless motors. Do you need to use one these when using a brushless motor (eg Novak 13.5SS), or can you just use the original motor mounts?
You can still use the original one. the brush less motor mont allow you to use lower gear ratio than the original one. (max 110T spur gear with the brush less motor mount)
Thanks,
Old 07-05-2007, 10:01 AM   #9004
Originally Posted by WogBoy View Post
Hi Guys
I used to be an Xray Man and now I just switched over to Hot Boddies
I just baught th Cylone Moore-speed edition. What a fantastic looking car
I have one problem that I am sure came up before.
The 27T pinion gear on the motor simply can not reach the spur of 100T.
I am going to run this car on an outdoor asphalt track where they race 1/10, 1/8 and 1/5 scale cars (Both Nitro and Electric)
I am running the LRP Sphere Competition TC ESC and a 3.5Turn brushless motor powered by Team Orion 4800 Platinum 2S LIPO.
I need to get to a final drive ratio of 8.9 for large track for the 3.5Turn motor
I am not sure what the maximum Spur you can have on the Cyclone.
Cyclone IDR = 2.4375 [(Spur/Pinion)* IDR = FDR]
I think a 106T spur and 30T pinion would get me that ratio but I m not sure if they will still reach or even worse fall below the chassis line
Anyone can make any recomendations from experiance?
Thanks very much
I downloaded one of Andy Moore's setups and it has on there that he used a 107/29 combo to get to 8.994
DOTMAN is offline   Reply With Quote
Old 07-05-2007, 10:25 AM   #9005
rc-zombies's Avatar
with I knew about the 18T pulley before I ordered the 3racing 17/18t pulleys..
Old 07-05-2007, 10:56 AM   #9006
When you use those pulleys, you will also need to have the belt that is particularly made for the pulleys. We HB will release them soon.
Thanks,
Old 07-05-2007, 11:03 AM   #9007
Thanks,
For sure...my belts are already fairly tight with the 16T pulleys
Old 07-05-2007, 03:34 PM   #9008
Deves's Avatar
Dotman, Are you wheeling a cyclone now?
Deves is offline   Reply With Quote
Old 07-05-2007, 03:38 PM   #9009
I have one, but this is the heart of Tamiya Season so I'm running my Tamiya cars right now.
Old 07-05-2007, 04:04 PM   #9010
mangoman's Avatar
Thanks,
I noticed a pic the other day where Hara had a belt tensioner mounted on his rear belt (i think at the reedys). Maybe its something to do with that? **SHRUG**
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 07-05-2007, 04:32 PM   #9011
Stew Noble's Avatar
The rear belt is usually run slightly tighter than the front using the cams.
Andy's been using the new pulleys and belts here in the UK for a while, i was impressed buy how smooth they made the drivetrain and the extra range of gearing is perfect for modified.
// S N F //
Stew Noble is offline   Reply With Quote
Old 07-05-2007, 05:10 PM   #9012
I have been running the tensioner in the rear for the last couple of months, i was finding that even with the belt set tight i was getting belt skip, with the tensioner there the belt can be set overall looser and still not skip, i love the idea of the bigger pullies, i have been looking at the 3 racing ones, but have been out of stock every time i tried to order.
Besercoe is offline   Reply With Quote
Old 07-05-2007, 09:05 PM   #9013
LOSI123's Avatar
Trader Rating: 63 (100%+)
Not to do with the cyclone sorry...
Anyone know what brand of corrally style conectors are not super tight and stiff to plug in and out.
and where you can get them from...
as i got some that are supposed to be "corrally style"
and they are so tight i have to use pliers & i almost pulled the wires out of my speedie.
thanks...
LOSI123 is offline   Reply With Quote
Old 07-05-2007, 09:07 PM   #9014
rc-zombies's Avatar
thanks...
I use the smaller 3.5mm Euro Plugs.. available overseas or at Integy..
Old 07-05-2007, 09:16 PM   #9015
thanks...
It has a lot to do with using the same brand male and female plug. I have only ever had issues when trying to combine 2 different brands.
The LRP Silver ones are quite nice.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
