Old 07-03-2007, 03:15 AM   #8971
Trader Rating: 22 (100%+)
Yes you can I run on a bumpy track at 6mm ride height
Just unscrew the shock ballends about 2 turns and make sure the shocks are same length.
bjspinner is offline   Reply With Quote
Old 07-03-2007, 06:37 AM   #8972
Marcos, how did you get your foams to fit?
Yub, yub, cmdr! is offline   Reply With Quote
Old 07-03-2007, 10:33 AM   #8973
Originally Posted by Deves View Post
What gear combo do you run for a large track? I'll be using a stock 27t motor
Deves,
I personally run mod, I'll ask next time on track some of the stock guys (they run 19T).
Z
rcpoint is offline   Reply With Quote
Old 07-03-2007, 11:03 AM   #8974
rc-zombies's Avatar
around 6 - 6.2fdr...
Old 07-03-2007, 02:47 PM   #8975
g_mabry's Avatar
Originally Posted by turtle View Post
What is the part number of the spur-gear holder that you use with this shaft?
I have a cyclone S and want to put the direct centre shanft and pulley's in it, but cant find the number for the spur holder?
Part# 70711 Spur gear hub
g_mabry is offline   Reply With Quote
Old 07-03-2007, 03:04 PM   #8976
Default 39 tooth pulley
I bought a diff kit from Tower so that I would have a spare.
http://www2.towerhobbies.com/cgi-bin...?&I=LXNZG1&P=7
It came with the 39 tooth pulley part 61050. I noticed that the teeth themselves are much thinner than the pulleys on the car now. Are there different ones? The manual lists the pulley as part A495. Little confused here.
Also do you adjust the diff like you would an xray? When the diff is tighter the head of the screw is down too deep to adjust it that way...
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 07-03-2007, 03:49 PM   #8977
Hi Guys
I used to be an Xray Man and now I just switched over to Hot Boddies
I just baught th Cylone Moore-speed edition. What a fantastic looking car
I have one problem that I am sure came up before.
The 27T pinion gear on the motor simply can not reach the spur of 100T.
I am going to run this car on an outdoor asphalt track where they race 1/10, 1/8 and 1/5 scale cars (Both Nitro and Electric)
I am running the LRP Sphere Competition TC ESC and a 3.5Turn brushless motor powered by Team Orion 4800 Platinum 2S LIPO.
I need to get to a final drive ratio of 8.9 for large track for the 3.5Turn motor
I am not sure what the maximum Spur you can have on the Cyclone.
Cyclone IDR = 2.4375 [(Spur/Pinion)* IDR = FDR]
I think a 106T spur and 30T pinion would get me that ratio but I m not sure if they will still reach or even worse fall below the chassis line
Anyone can make any recomendations from experiance?
Thanks very much
WogBoy is offline   Reply With Quote
Old 07-03-2007, 04:49 PM   #8978
fjm9898's Avatar
the spur most of the HB guys run is the 108t in 64
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 07-03-2007, 05:08 PM   #8979
I have a 108 in mine that looks like the max.
Originally Posted by WogBoy View Post
Hi Guys
Thanks very much
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 07-03-2007, 05:52 PM   #8980
ShaunMac's Avatar
Some have run a 110T spur with no problems. The 108T will give you a little more clearance.
Anybody know where I could get a set of HOT61088 WC Ed. MIP CVDs? I can't find them IN STOCK anywhere in the US.
ShaunMac is offline   Reply With Quote
Old 07-03-2007, 05:58 PM   #8981
turtle's Avatar
Do I need the carbon-fibre piece that goes on the other side of the spur gear, or can i just screw the spur gear straight to the hub?
turtle is offline   Reply With Quote
Old 07-03-2007, 08:28 PM   #8982
Scott B's Avatar
Trader Rating: 42 (100%+)
I believe my LHS had some in stock, both the kits and single CVD bones. Speedworld Raceway in California (916) 783-8864 ask for Billy. They will be closed tomorrow but will be open Thursday, 12-7 I believe are there hours.
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks, Protoform...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 07-03-2007, 08:42 PM   #8983
Trader Rating: 194 (99%+)
It is not a must
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 07-03-2007, 08:43 PM   #8984
Hi Guys
Thanks very much
108/28 works. I ran it yesterday.
www.donatelife.net
Old 07-03-2007, 09:54 PM   #8985
turtle's Avatar
I see you can buy a special motor mount for brushless motors. Do you need to use one these when using a brushless motor (eg Novak 13.5SS), or can you just use the original motor mounts?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
