Old 06-24-2007, 11:28 AM   #8896
sk1pp3r's Avatar
Send a message via MSN to sk1pp3r
Originally Posted by karlo511 View Post
http://www.fastener-express.com/inde...S&Category=218
the fastener-express ones match pretty well....
Karlo, thats a good find, they are really cheap, think I'm about to get some, that way shipping should be a little less than from HK.
sk1pp3r is offline   Reply With Quote
Old 06-24-2007, 01:44 PM   #8897
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by dorick View Post
Hey guys i just finished building my cyclone.. i do have a few questions though, how tight do you make your ball diffs? i set mine so that i can't turn the gear while holding the axles, however now that the car's done i can hold on to the wheels and turn the gear without too much force.. i assume its slipping too much? How tight should it be? and whats the easiest way to tighten it? another thing is how do you change the toe setting? finally i'm running it with a gtb with a spektrum pro reciever and i'm having a hell of a time fitting things on the chassis, i ended up stacking the receiver on the servo.. i assume thats a bad thing.. any suggestions? sorry for noob questions.. thanks!
needs to be tighter im shure, if u run it, punch it and if u hear squeeling then there too loose
toe is just done by the turnbuckles, use the lil tool it comes with and tunr it till there where u want them
and thats fine, ppl do that with there cars for room! another thing u can do u crack off one of the servo ears and put some double sided tape on it and screw the one side thats faceing the bumper in, then u can get that much more room... or shoo goo it, or strong double sided tape the whole servo on..
BlackedOutREVO is offline   Reply With Quote
Old 06-24-2007, 01:51 PM   #8898
and guys
i want to try out a oneway... i LOVE lots and lots of steering, and my spool just doesnt get me there, i have done EVERYTHING there is, i can put down not bad lap times (like .8 above the expert times) but would like to try out the one way, i mean i have it already rom the kit, mite as well
so i put in the center oneway pulley and front and i go out side it just spins out no matter what! i can get off the gas EVER so slightly where its hardly slowing down and spins out
so now i know u have to change the set up, i think theres to much wieght transfer to the front? causing it to spin
what would u change to run a ow front, and center, insted of a spool
Old 06-24-2007, 03:14 PM   #8899
fjm9898's Avatar
well going out side and running it on the drive way it 10 time different then at a track. so if you usually run at a track and then just test it outside on a different surface they your going to get very different results.
to take away some steering gained from the oneway you can add a thicker sway bar in the front. change the roll center of the front. change springs. change pivot blocks. there are 100 things you can do
Originally Posted by BlackedOutREVO View Post
and guys
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-24-2007, 04:45 PM   #8900
Default diffs
Just got my Cyclone to the track for the first time. I'm very happy with it so far. Took very little to get it the way I wanted and seemed to be as fast as anything I have driven. Plus I didn't break anything which was an expensive problem with my Xray. Since I'm a pretty decent driver it's good to know again that I can go to the track without breaking something.
Now I have a question about diffs. Tower has a Differential Cup Joint Set for $30. Or you can get the Alum ones for $22. The complete diff is $38. Why in the world are the plastic diffs so expensive? Also is there a difference between the regular cyclone plastic diff and the cyclone s? The cyclone s parts are like $7 and they look the same...
porschejim911 is offline   Reply With Quote
Old 06-24-2007, 06:24 PM   #8901
Trader Rating: 198 (100%+)
The Cyclone diff if delrin. The CycloneS is molded plastic. The S diffs are more likely to break than the Delrin. Delrin cost more as a material to start with.
Blacked out Revo, it probably is not that the car needs a oneway for more steering and for you to be as fast as the fast guys. If you are not getting the steering from a spool then you are, 1 over diving the car. Or 2 the setup is wrong.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 06-24-2007, 06:26 PM   #8902
it did the same at the track the first time i tried, i got mad and put the spool back in to drive... now i wanta truely try
but ok, i will have to try some things out
thanks
Old 06-24-2007, 06:36 PM   #8903
Tower describes both parts as nylon construction. The expensive one is HB70715. Is that supposed to be delrin? It's also black and I thought delrin was about always white.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 06-24-2007, 06:56 PM   #8904
Delrin can have color added to it during the production process.
I have both the Cyclone and the S. The Cyclone S diffs will break easier than the delrin.
www.donatelife.net
Old 06-24-2007, 06:59 PM   #8905
Thanks. I was confused by the tower description then. Anybody use the Alloy? Since they are cheaper is that the better way to go?
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 06-24-2007, 07:05 PM   #8906
Are they both the same other than the materials? With the S being so much cheaper they might be the way to go even if they are a little less durable.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 06-24-2007, 07:05 PM   #8907
If you go with the alloy. Then you have blades to worry about. If the bone cross pin wears thru the blade. It will then wear a groove into the alloy. At $10 per blade set. It is expensive. I use the 3 racing diff. It has blue blades that work well. I have found if you heat them up in the center. And squeeze them just a little. They will last much longer. They want to squish out after a while. I do rotate them also to get the most out of them. I run a diff in the rear and spool in the front. The 3racing blades are 2 pair for $5.
www.donatelife.net
Old 06-24-2007, 07:10 PM   #8908
The diffs are the same design. Just the material. To be honest, the material on the S looks very much like the pro4 diff material. I have ran mod with the Pro4 and never broke a diff outdrive.
www.donatelife.net
Old 06-24-2007, 08:13 PM   #8909
Hey guys i was wondering if there is any good setup for asphalt with the stock configuration? I'm running the original black cyclone so i have a one-way up front.. most of the setups are for spools, i haven't had time to grab a spool yet so i want to set it up for the one-way for now.thanks!
dorick is offline   Reply With Quote
Old 06-24-2007, 09:38 PM   #8910
mangoman's Avatar
Nah the cyclone S diffs are a lot softer than the pro 4 ones. If im not mistaken the pro 4 diffs were made of that composite stuff they use on the rest of the car.
Yeah im thinking i will go with the delrin ones, im so cheap that by the time i change the blades theyve worn down into the diff cups . If you go with the delrin or plastic diffs dont forget to get the retaining clips for them, i dont think come in the packet.
BTW last weekend my car was just wheel spinning everywhere, turned the punch down to zero on the car and even tried gearing it up but i was still getting massive wheel spin through the corners and the back of the car kept spinning out through corners, im sure i didnt have the drift tires on
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
