Old 06-19-2007, 01:03 PM   #8821
You guys are both saying the same thing but misunderstanding each other. Yes a bigger pinion = higher top end, slower acceleration. A smaller pinion is the opposite. A bigger spur with the same size pinion means lower top end faster acceleration and a smaller spur with the same pinion means higher top end.
Yub, yub, cmdr! is offline   Reply With Quote
Old 06-19-2007, 01:15 PM   #8822
edward Haywood's Avatar
Default aluminum blue parts
Surikarn edition Cyclone parts....and aluminum hubs & knuckles anyone know where I can find these
Mtx-4.....Rolling baby/Blue Diamond /West Chester/
Magneto X-Woodawson/FX/Nitro forever/
edward Haywood is offline   Reply With Quote
Old 06-19-2007, 01:35 PM   #8823
mangoman's Avatar
Originally Posted by Elboogie View Post
Actually lying down the shocks gives you more lateral grip. If you want increased steering, change your pivot block in the front. i run on carpet so I use a 0 degree in the front because I don't need the steering. the higher you go up with the pivot block in the front, the more steering that you will get.
My IMPRESSION is that if you are running on carpet (high grip foam, never raced rubber on carpet) you should be stiffening your springs to take away steering while pivot blocks effect your handling through the corner (is that what you mean by lateral grip?), but i find most people tend to play with the rear pivot block and not the front.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 06-19-2007, 02:41 PM   #8824
Elboogie's Avatar
I got the information from hpiracing.com. If you go to the Pro4 manual, it will show you the effect on changing your pivot blocks. I know I messed with the pivot blocks in the front and when I went from 0 degree to the 2.5 degree (used mostly on asphalt) I got way too much steering. the Pro4 manual shows that the higher number pivot block in the front increases your steering. That is where I got the information from and testing it out, it seems to be true. And yes you should be stiffening your springs. If you want a very good set-up book, check on teamxray website and look at the set up book that they have in PDF form, It is a great reference.
CYCLONE WCE
Jaco / Airtronics
Much More / Team Orion
"Drive Hard or Go Home"
Elboogie is offline   Reply With Quote
Old 06-19-2007, 02:42 PM   #8825
Elboogie's Avatar
I got the pinion and the spur backwards. Like I said I never really change my spur so I do agree with you. Thanks for the correction because I don't want to give out info that I may not be sure on.
CYCLONE WCE
Jaco / Airtronics
Old 06-19-2007, 03:17 PM   #8826
ICEMAN's Avatar
Yub and El- im Not or Never said anything about GEAR ratio, just that a LARGER SPUR with the same RATIO of a smaller spur&pinion will STILL give the car better Torque than a smaller SPUR. The End
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 06-19-2007, 03:22 PM   #8827
Thraex's Avatar
Just to make some things clear, Mangoman and Elboogie, you are both right.
Like Elboogie said, you get more steering by using the 2.5 degrees instead of 0 degrees, but you should realize that it's because the wheelbase gets smaller (the arms are more swepped back).
Like Mangoman said is true, it changes the characteristic of the steering and that's what the front inboard toe (out) is intended for (if your just looking for some steering there are other/better ways to accomplish this).
The more degrees you use the smaller the wheelbase gets when the suspension gets compressed.
On the track this means that you get more steering turn in and less turn out the more degrees you use.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 06-19-2007, 03:40 PM   #8828
barber's Avatar
products
where to get p-dub products from.
BARBER SHOP RACING.
Hara Cyclone Edition,MAMBA 7700KV,Spectrum,
Mazdaspeed 6 Painted By McGoo Creations,
JR Z1,Orion 4300Mah,Ib 4200Mah,Ice,Rp,Trinity.
Race Prepaired & Driven By TEAM DRIVER (BARBER)
barber is offline   Reply With Quote
Old 06-19-2007, 03:56 PM   #8829
fjm9898's Avatar
anyone have a zero degree pivot block they wanna sell me?
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-19-2007, 04:48 PM   #8830
ICEMAN's Avatar
Paul is updating the wedsite, but www.nexusracing.net has everything i think,
Old 06-19-2007, 07:33 PM   #8831
Default setup help
Could somebody shoot me a setup for the Hara edition cyclone ? I need it for a bumpy carpet track with lots of tight turns . Short hair ozite the old stuff . I will be running brushless 13.5 on it thanks . Foam tires are required to be ran . Thanks in advance .
Matt Bayless is offline   Reply With Quote
Old 06-20-2007, 10:31 AM   #8832
Trader Rating: 22 (100%+)
Originally Posted by Myhre View Post
All the bulkheads are aluminum. My thought is that he had a friend with a S version and probably sold, or gave the drivetrain parts to him before getting rid of it. I didn't know what to look for when I picked it up from him off of ebay so I didn't realize it was missing almost $200 worth of parts.
So I want to run a spool, I'm just not sure where to get it from
Where is the best place to get the updated parts from?
You can get the V3 spool from www.stormerhobbies.com or www.speedtechrc.com Stormer doesn't have pictures but has more in stock Speedtech has all the items listed in pictures so you can look there for info.
Anemic_SluG is offline   Reply With Quote
Old 06-20-2007, 02:41 PM   #8833
Default anyone know where I can find these
still looking for Surikarn edition Cyclone parts....and blue aluminum hubs & knuckles
Old 06-20-2007, 07:59 PM   #8834
fjm9898's Avatar
those new WCE cvd bones are POS as well. i ran two runs today. and i come off the track each time with the hole for the pin ripped out. and the last run i only tapped our 180 corner going like 5mph while off throttle. i must say in the two weeks i have had this car i am very upset with the quality of parts. i have blow two verson 2 universals three HD steel universals and today two WCE cvds. and i am not even hitting anything hard at all. i am not the top sponsored guy but i am no means a bad driver. i just finished up that last qualifier witht eh ripped bone and set then 2nd fastest time. i broke less parts on my pro4 in the almost 3 years i had it. and in 3 days of running i have broken 7 dog bones. i even modded my spool by widening the outdrives a bit so i could fit the pin cushion blades on it. and those bones are breaking before the blades get smashed. i guess ill have to find a way to get the xray spring steel stuff to work on this car?
Old 06-20-2007, 08:01 PM   #8835
fjm9898's Avatar
look at the stores in in japan and places like that. i havent seen may places with the blue parts. try precision rc and rc model. places like that. m,aybe even trying 3racing's website
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
