Old 06-18-2007, 06:56 AM   #8806
Sounds like your car was for carpet
Yub, yub, cmdr! is offline   Reply With Quote
Old 06-18-2007, 01:54 PM   #8807
Originally Posted by fjm9898 View Post
ill just have to try it. i cant get any corner speed with the car on this super grip track
geez i cant find those #61095 mid cvd bones anywhere. and need them fast! nats is only 3 weeks away! i might have to grab some from TIR. they also have the 2 pairs of hole which is nice
FJM Speedtechrc.com has them in stock. That's where I get all my cyclone stuff
DOTMAN is offline   Reply With Quote
Old 06-18-2007, 01:57 PM   #8808
Originally Posted by ICEMAN View Post
Losi123 - the Pulleys work great and I have had not problem running them in 16, 17 or 18 set-ups, it does cahnge your final drive to a much better level. Belt tension is not an issue.
But the 3racing pulleys will not make the Final drive in the 3.6's , you divide the center pulley, by the diff pulleys to get your F-drive
Stock is 39/6=2.4375
39/17=2.294
39/18=2.166
You use the stock belt with the 17 and 18T pulleys? My belts feel tight withthe stock 16T
Old 06-18-2007, 03:13 PM   #8809
g_mabry's Avatar
Originally Posted by Myhre View Post
All the bulkheads are aluminum. My thought is that he had a friend with a S version and probably sold, or gave the drivetrain parts to him before getting rid of it. I didn't know what to look for when I picked it up from him off of ebay so I didn't realize it was missing almost $200 worth of parts.
So I want to run a spool, I'm just not sure where to get it from
Where is the best place to get the updated parts from?
Stormer Hobbies has the version 3 spool in stock.
g_mabry is offline   Reply With Quote
Old 06-18-2007, 03:15 PM   #8810
g_mabry's Avatar
Oh, part # 61086
Old 06-18-2007, 03:30 PM   #8811
speedtechrc.com has them in stock too
Old 06-18-2007, 03:38 PM   #8812
fjm9898's Avatar
does anyone here have the zero degree pivot block that they dont want/need. i just dont feel like spending 15 for a new one. i want a purple one if you have one.
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-18-2007, 07:06 PM   #8813
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by BlackedOutREVO View Post
guys how do u keep those blades that go on the end of the rear drive shaft pins from coming off? is there a fix besides dont hit stuff?
BlackedOutREVO is offline   Reply With Quote
Old 06-18-2007, 08:21 PM   #8814
ICEMAN's Avatar
DOTMAN- yes i run the stock belts. have only moved my adjusted back one notch and they are loose for MOD.
I break in all my bearing and belts for a good 3 to 4 hours with a silver can on the motor run in to ge the bearing and belts good and Seated and free everything up.
I have also not had any problem witht he EXCEL low Fric. belts. but only run them in Stock and 19t.
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 06-19-2007, 02:06 AM   #8815
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone tell me if it is normal to have side to side slop/play in these parts:
1. Rear diff pulley it self is moving side to side in between the diff out drives.
2. Front bearings that hold the spool go side to side in the bulk heads
3. centre layshaft bearing also goings side to side in the bulkheads.
LOSI123 is offline   Reply With Quote
Old 06-19-2007, 02:43 AM   #8816
A Ilievski's Avatar
Trader Rating: 39 (100%+)
yes to question 1
Not sure about 2
And with 3 you adjust the pullies side to side so thers no movement.
A Ilievski is offline   Reply With Quote
Old 06-19-2007, 03:43 AM   #8817
BrainTeased's Avatar
you can shim the front spool to eliminate some of the side to side play. I shim it so that i have very minimal play to ensure i do not have any binding or excussive side to side play.
with the center shaft i also use the pulleys on each end to adjust the amount of play i desire again i adjust it so that i have minimal play to ensure that theres no binding and excessive play.
BrainTeased is offline   Reply With Quote
Old 06-19-2007, 04:58 AM   #8818
mangoman's Avatar
There are shims for this, the play shouldnt be excessive and i thought the manual has these shims listed.
There is a lot of play in there you can set the centre pulleys apart but i have a cyclone s which came with a shim and i use that so the left centre pulley doesnt sit so close to the motor mount.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 06-19-2007, 11:46 AM   #8819
Elboogie's Avatar
Originally Posted by mangoman View Post
lieing your shocks down will give you more steering....
Actually lying down the shocks gives you more lateral grip. If you want increased steering, change your pivot block in the front. i run on carpet so I use a 0 degree in the front because I don't need the steering. the higher you go up with the pivot block in the front, the more steering that you will get.
CYCLONE WCE
Jaco / Airtronics
Much More / Team Orion
"Drive Hard or Go Home"
Elboogie is offline   Reply With Quote
Old 06-19-2007, 11:51 AM   #8820
Elboogie's Avatar
El- Sorry bro, but you do, your backwards. if im wrong, the last 20 years of R/C racing , i have been WAY off.
You may be right Ice. I know that when i am going down a straight and my car doesn't reach max speed by the time I get to the end of the straightaway, I will go to a smaller pinion because it will spool up faster and get me to my top speed at the middle of the straight instead of by the end.
here's a question. I don't normally change my spur, I use the 100 tooth. Am I confusing this with the pinions? In other words when you go to a smaller pinion, doesn't that give youmore torque and the larger the pinion the more top end you get?
I always have my car geared right so something is working. lol.
CYCLONE WCE
Jaco / Airtronics
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
