Old 06-14-2007, 04:48 PM   #8761
so file the alloy motor mount?
Yub, yub, cmdr! is offline   Reply With Quote
Old 06-14-2007, 10:16 PM   #8762
mangoman's Avatar
You probably shouldnt. We are talking about the middle mount which goes behind the spur/top deck and using a bigger spur. Best to use the carbon middle mount as its easier to file lightly.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 06-14-2007, 10:52 PM   #8763
Cyclone Charlie's Avatar
Grr, I bought a 31T pinion. Too small! Won't reach the Spur 100T.
Does that mean that the Cyclone is not suited to running motors below 11T? I have an 11x2T Team Checkpoint. What pinion should I run with the stock 100T spur? Anyone run Checkpoint with the Cyclone?
Thanks!
Why do you want to run such a hot motor?
You would need a 108 tooth spur gear to use a 31 tooth pinion gear, and you don't need to file anything. Your roll-out might be okay for your 11x2.
106/32 or a 106/34 is perfect for a stock or 19T brushed motor.
Take that 100t spur gear you have and go hide it somewhere, it's useless unless you go brushless and run a motor with a low KV.
Cyclone Charlie is offline   Reply With Quote
Old 06-15-2007, 05:03 AM   #8764
Default Brushless motor mount
Has anyone run the new brushless motor mount. I know it moves the layshaft 2mm higher allowing the use of bigger spurs, but what i am wondering is, does it allow the motor to move more towards the rear of the car so I can achieve a mesh with smaller pinions and bigger spurs? It looks as if it does in pictures, but I wld like someone to confirm before I buy one.
At the moment I have to change between 96, 100, 105 and 110 spurs depending on wether I'm racing stock brushed, stock brushless, 19t or mod, and itrs a bit of a pain. Its not a huge job to change them, but would be much better if it didn't need done all the time.
vroomtshh is offline   Reply With Quote
Old 06-15-2007, 03:44 PM   #8765
For some reason, it's the only motor I have on hand. Unless someone wants to take a brand new Team Checkpoint 11T off my hands...
Old 06-15-2007, 04:47 PM   #8766
Sorry for all the questions guys, but will 31/108 and 37/108 fit in the Cyclone? Those are what I am considering running for the 11T and the CO27.
Old 06-15-2007, 05:08 PM   #8767
I've got a 106/32 and have enough room to 108 without the gear sticking out of the bottom of the chassis.
You'd probably be okay, try it and see if you get a heat issue!
Old 06-16-2007, 10:50 PM   #8768
fjm9898's Avatar
what are some good ways to take some grip out of the car? we have a very high grip asphalt track and i have gone down to 0 degree tow black in the front but by the end of the day the traction still comes up more so i still need to take some grip out. i have 30 wt. and pink springs in the front. i have the roll centers on the camber plates at 2mm and 1.5mm spacers under the tow blocks. no kick up or dive front and rear
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-16-2007, 11:02 PM   #8769
bmmer701's Avatar
Trader Rating: 17 (100%+)
when i ran my 9x1 checkpoint i'm using 32/108. i guess 37/108 will fit because i've tried using 41/106 with a 23t motor
bmmer701 is offline   Reply With Quote
Old 06-16-2007, 11:02 PM   #8770
Are you going to SIR tommorrow?
If you want I can come down and you can check out my set-up. I also saw your post on SIR's thread. I've got some stock black spare v2 bones. I switched to the steel ones and have 3 of the originals. Let me know?
Old 06-16-2007, 11:50 PM   #8771
fjm9898's Avatar
yea ill be at sir tomorrow.
i have some more bones now, just getting a new spool. right now i am trying to get my mip shinny cvds to work on my worn out spool. just need to file a bit more back and they should work... with blades... woot.. haha that will be nice to be able to use blades. but who knows i might need some more bones sooner or later... haha
i have a few more things to change on my setup to help free it up form more. but i might be willing to barrow your 0 block until mine gets here.
Old 06-17-2007, 02:31 AM   #8772
mangoman's Avatar
fjm9898, a spool will settle the car down quite a bit and also take away steering. You may also want to use a heavier oil if you are finding the car too twitchy, I like to use 40wt.
www.smaracing.org
Old 06-17-2007, 01:06 PM   #8773
fjm9898's Avatar
anyone know where to get the worlds kit dog bones? for cheap
part #61095 they are the mid cvd bones.
i have a mid cvd kit for my pro4 so all i need is the dog bones.
Old 06-17-2007, 01:14 PM   #8774
Ballsie's Avatar
If you decide to buy the full kit then these look amazing ...
http://www.precisionrc.com/nv/car/pr...oduct_id=53043
Ballsie is offline   Reply With Quote
Old 06-17-2007, 01:26 PM   #8775
fjm9898's Avatar
yea i already saw those. i really only need the bones. no need to spend extra money on stuff i dont need.
i know TIR makes CVD bones by at $16 per bone i am trying to find something a bit less expensive
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
