Old 06-14-2007, 10:14 AM   #8746
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
What is the ideal spur gear size for stock brushed to start with?
Mike Schumacher is offline   Reply With Quote
Old 06-14-2007, 10:29 AM   #8747
ICEMAN's Avatar
Spur size is your choice, But the on Going idea is that the LARGER the SPUR the more TORQUE it has over a smaller spur. So , with stock motors not being as strong as Mods. the lager spur would get you off the corner faster.
And to get the "REAL" good FDR you need to buy the New Brushless Bulk head for more movement of gear mesh.
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 06-14-2007, 10:50 AM   #8748
Cyclone Charlie's Avatar
Put a 106 spur and if you can get a 32 pinion to adjust, that would give you a perfect roll-out for a stock 27 turn motor. If there isn't enough adjustment, use a 34 pinion.
Cyclone Charlie is offline   Reply With Quote
Old 06-14-2007, 10:50 AM   #8749
Elboogie's Avatar
I thought that the larger the spur gear, the more topend you got. I thought that if you went to a smaller spur gear that that creates more torque.
Kinda like the same idea when you start cutting your motor. the smaller the comm the more torque you get. i could be wrong though.
CYCLONE WCE
Jaco / Airtronics
Much More / Team Orion
"Drive Hard or Go Home"
Elboogie is offline   Reply With Quote
Old 06-14-2007, 10:55 AM   #8750
I think you got it backwards. Larger spur means the pinion has to go around more times for the spur to go around once. So less rpm from the motor gets to the ground. Small spur will have higher top speed but motor has to work harder to get there because it has less leverage I guess you could say.
porschejim911 is offline   Reply With Quote
Old 06-14-2007, 11:20 AM   #8751
ICEMAN's Avatar
El- Sorry bro, but you do, your backwards. if im wrong, the last 20 years of R/C racing , i have been WAY off.
Old 06-14-2007, 12:14 PM   #8752
Misunderstood.
How do you get those ball ends off anyways? ^_^
Yub, yub, cmdr! is offline   Reply With Quote
Old 06-14-2007, 01:32 PM   #8753
ICEMAN's Avatar
Drill a 3mm hole in the Ball cup and unscrew the whole ball stud, instead of unsnapping it every time
Old 06-14-2007, 02:56 PM   #8754
mangoman's Avatar
Yeah thats the best thing to do, otherwise i use long nosed pliers to grip the ball cup on the arm and twist it off.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 06-14-2007, 03:02 PM   #8755
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
DOES anybody know the set ups from the Reedy race for hara, thad and other team guys?
bigb11 is offline   Reply With Quote
Old 06-14-2007, 03:02 PM   #8756
mangoman's Avatar
fjm9898, i think there were comments about it a couple of weeks back.
Personally i wouldnt bother playing with the mounting positions just stick to your normal settings. Its probably not gunna make that much of a difference unless you are a top driver, otherwise everyone would be using the different mounting positions.
www.smaracing.org
Old 06-14-2007, 03:33 PM   #8757
Grr, I bought a 31T pinion. Too small! Won't reach the Spur 100T.
Does that mean that the Cyclone is not suited to running motors below 11T? I have an 11x2T Team Checkpoint. What pinion should I run with the stock 100T spur? Anyone run Checkpoint with the Cyclone?
Thanks!
Old 06-14-2007, 03:44 PM   #8758
mangoman's Avatar
Buy a bigger spur, 108 is meant to be the max for 64 pitch. Although you can squeeze in a bigger spur if you lightly file down parts and dont mind it sticking out slightly under the chassis.
www.smaracing.org
Old 06-14-2007, 04:27 PM   #8759
AngryAsian's Avatar
Which car do you have?
If you have the original, a little filing on the CF plate will help it clear the spur. On the alloy middle braces, I think it's fine.
A 110 will fit and sit either flush or just out of the chassis. I run a 3.5R with a 110/25 combo with no issues. Given that I get to the track like once a month if I'm lucky and that our track is outdoors and surrounded by trees.. it would be easy to surmise that spur gets ripped to shreds.
(My car runs on crash-o-hol)
However - it's running great! It getting more chewed up from the pinion wearing than anything else..
AngryAsian is offline   Reply With Quote
Old 06-14-2007, 04:38 PM   #8760
barber's Avatar
Exclamation Foams on a cyclone
guys have you tried electric foams on your cyclone.
barber is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
