Old 06-11-2007, 07:24 AM   #8701
How many holes of the body posts should I trim to ensure compatibility with most bodies?
Yub, yub, cmdr! is offline   Reply With Quote
Old 06-11-2007, 08:10 AM   #8702
Elboogie's Avatar
Originally Posted by Skill View Post
To work out FDR it's:
(teeth on spur/teeth on pinion)*internal ratio of car
the internal ratio of the cyclone is 2.4375
call the number of teeth on the pinion x:
therefore we have 4 = (100/x)*2.4375
100/x = 1.64
x = 100/1.64 = 60.9 = 61....seems like you'd want a smaller spur
If you don't want to do the calculation you can go to rcuniverse and use their rollout calculator
http://www.rcuniverse.com/community/gearwizard.cfm
CYCLONE WCE
Jaco / Airtronics
Much More / Team Orion
"Drive Hard or Go Home"
Elboogie is offline   Reply With Quote
Old 06-11-2007, 11:30 AM   #8703
Looks real hard to get near 4. Even with an 88 spur and 44 pinion it's only 4.875.
100/x = 1.64
porschejim911 is offline   Reply With Quote
Old 06-11-2007, 11:42 AM   #8704
Skill's Avatar
Yes, I believe some people have been using the 3racing belt pullies which come in 15, 16, 17 (i think) anyway whatever number of teeth they offer I'm sure theres one bigger than the standard which lowers the internal ratio helping you get a bit lower.
Skill is offline   Reply With Quote
Old 06-11-2007, 01:04 PM   #8705
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by fjm9898 View Post
haha i figured... anyone have the spring rate chart for those lol.
Shock Absorber Springs
Size Colour Comp./ Ratio
Hara Yellow 12.89lb/ 230g
Hara White 13.98lb/ 250g
Hara Black 15.11lb/ 270g
Hot Bodies Blue 15.3lb/ 273g
Hara Purple 16.24lb/ 290g
Hot Bodies Silver 16.9lb/ 302g
Hara Red 17.36lb/ 310g
Hot Bodies Pink 18.0lb/320g
Hot Bodies Gold 19.0lb/340g
Hot Bodies White 20.3lb/363g
Hot Bodies Yellow 21.7lb/388g
Hot Bodies Red 22.4lb/400g
2-Bad is offline   Reply With Quote
Old 06-11-2007, 01:13 PM   #8706
mangoman's Avatar
If you are like me and your roof a bit too much, then you dont want to trim the front posts too short as they will get ground down. I tend to cut mine off so that there are at least two mounting hole above the current one.
You will probably find the mounting of the rear posts will vary a lot more, i had one case where the rear posts were slightly up the rear window.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 06-11-2007, 04:09 PM   #8707
fjm9898's Avatar
thanks 2-bad
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-11-2007, 05:27 PM   #8708
barber's Avatar
Originally Posted by mangoman View Post
Yeah i only use the HD Steel Uni's in the front of the car, for that reason. Also try and get a p-dub bumper for the front that will help prevent the unis from getting bent. If you get a p-dub bumper though make sure the wheels dont rub on the bumper as they are a little wider (you may have to trim a bit back).
where would i get the hd steel uni's from,also the bumper.
thanks
barber is offline   Reply With Quote
Old 06-11-2007, 06:07 PM   #8709
bmr
Trader Rating: 27 (100%+)
Anyone have the part numbers for the pivot block spacers?
bmr is offline   Reply With Quote
Old 06-11-2007, 06:12 PM   #8710
bmr
Originally Posted by porschejim911 View Post
Little help?
If it helps you any, I am running a 96/40 using rubber tires and a 13.5.
Old 06-11-2007, 06:23 PM   #8711
g_mabry's Avatar
HPI part # 75144
g_mabry is offline   Reply With Quote
Old 06-11-2007, 06:31 PM   #8712
g_mabry's Avatar
For the rear front and front rear, you can use washers. Take Off offers them I know from o.5mm to 3mm.
Old 06-11-2007, 06:32 PM   #8713
fjm9898's Avatar
hey my hara ed. has 3 places for the e-clips on the shock shaft so you can either have the piston in a lower our higher position. whats the difference. the stock manual doesnt have any information.
i also have a bunch of pro4 pistons. in a andy moore setup i have he says he has 3 holes is that the small 3 hole piston that is in the pro4 complete set? i would think the #1 with the two big holes would be better. (trying to go off a xray setup for our local track and they have all 4 holes open on their piston so trying to get as close to that with our pistons.)
Old 06-11-2007, 06:32 PM   #8714
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
try to find a 83 spur , thats what i use in my cyclone to get into the high 3's
Old 06-11-2007, 06:35 PM   #8715
What kind do you use? I usually get PRS but the smallest I have seen is 88.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
