Old 05-29-2007, 11:04 AM   #8536
g_mabry's Avatar
Originally Posted by Marcos.J
83/50 for a 4.04 fdr on my car it was a 83/51 for 3.96FDR
The smallest spur I am able to find is 88T. Where did you find a 83T?
g_mabry is offline   Reply With Quote
Old 05-29-2007, 11:14 AM   #8537
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
i got it from a oval car from back in the day, I think i still have it somewhere, i dont have that cyclone anymore but i may still have the spur
Old 05-29-2007, 12:27 PM   #8538
down to 82t http://www.microtechracing.com//prod...pe=X&Name=64DP
Not sure if they ship worldwide though. Just contact and ask
Team Durango, ORCA, MuchMore, Sanwa, Protoform, Tonisport, MR33, Roche, Custom Blitz Bodyshells
Elliott Harper is offline   Reply With Quote
Old 05-29-2007, 12:37 PM   #8539
Super Moderator
Marcos.J's Avatar
here you go down to 76t 64pitch and they are located in the U.S.
http://www.precisionracingsystems.com/products/11
Old 05-29-2007, 12:54 PM   #8540
Elboogie's Avatar
Originally Posted by fjm9898
and does anyone know here hara and andy get those cool lil carbon fiber transponder holders.
The transponder mounts are lexan with a carbon fiber decal on them. You can get the carbon fiber decal sheet from XXX. I have done the same on my cyclone.
CYCLONE WCE
Jaco / Airtronics
Much More / Team Orion
"Drive Hard or Go Home"
Elboogie is offline   Reply With Quote
Old 05-29-2007, 01:21 PM   #8541
Elboogie's Avatar
Originally Posted by Captain Harlock
One other question, guys:
Where can I find Square's Pro4 aluminum steering knuckles, blocks and rear upright?
They're out of stock at speedtech, so.....
Thanks.
Harlock you can get them at Rcmart.com and RC-Mushroom.com. both are in China and I have ordered them and they work great. If you replace the steering blocks and C hubs make sure that you buy extra suspension arms.
CYCLONE WCE
Jaco / Airtronics
Old 05-29-2007, 01:35 PM   #8542
g_mabry's Avatar
Old 05-29-2007, 04:41 PM   #8543
ROV
ROV's Avatar
G'day cyclone fans...
I'm looking for the tech reason why we use one way centre....
I run a andy moore on rubber, on a sotra tight asphalt track with a one way fnt diff, and only use 20% drag brake on 3 corners ther rest i can roll off power.and i have aggressive driving style....if i try any more brake than that, yep arss end comes round.
Question should i take centre one way out, or leave in.and why ????
PS always looking for more turn in, any recomndations for this set up...
Now i have a good chasie set up, and lovin my cyclone, but lookin for more...
CHEERS.
TELL THEM ROV'S HERE AND HE'S RUNNIN WHEELS THAT ARE READY TO RACE !!!
CEO TRASH TALK TOURING HOME OF WA'S CHEAP TRASH PISSTAKES
AM PSYCLONE,HOTBODIES D4,NOVAK,LRP,HACKER,MEGA,EFLIGHT.JR,KOPRO,HITECH, SPEKTRUM,TRAKPOWER,OS,CDC,SWASHDRIVE JET,ZENOHA,WEMOTECH DUCTED,LIPO4GO,LOSI,KOKOM,CDC,5IVE,8IGHT,XXCR,LST,CASTLE
ROV is offline   Reply With Quote
Old 05-29-2007, 08:18 PM   #8544
Wing Chun's Avatar
Hi ROV
I asked this same question on the TRF thread about 8 months ago and Bender was able to give me some great advice, I was amazed in the difference that the car handled between changes.
Here is what Bender said
When you have both the centre and front one-ways in, you get maximum turn-in from the car, plus maximum drive train efficiency, however brakes are practically non-existant - ie: you'll spin the rear round as soon as you touch them.
If you use a spool up front them you should always run the locked centre pulley. If you run a spool with the centre one-way pulley then you'll have no brakes, therefore losing all the advantage of running a spool in the first place.
If you run a diff up front you should also run the locked centre pulley - because at least you have brakes. If you run a front diff with a centre one-way then again you have no braking, plus you'll also have poor mid/exit corner steering.
In summary, my recommendations on combination are:
Front one-way with centre one-way : maximum turn in + efficiency + speed - no good if you need brakes or can't drive smoothly.
Front one-way with locked centre pulley: a bit less turn-in than above but otherwise similar. When I ran the MSX I always used both one-ways together.
Front spool with centre locked pulley : maximum mid/exit corner steering, strong brakes, but poor efficiency and hard on the drivetrain components.
Front diff with centre locked pulley: good brakes, easier to drive, but generally pretty poor steering everywhere - easiest on the car in terms of drivetrain wear.
Now this guy know's his stuff, and I have used it all.
I used this on my MRE/MSX and now my Cyclone,
As far as Turn in goes, I added 1.5 shims under my pivot blocks and what a difference it made, do you use them at all?
Hope this helps
Addam
Wing Chun is offline   Reply With Quote
Old 05-30-2007, 01:53 AM   #8545
rampal's Avatar
Send a message via MSN to rampal
Hi Cyclone owners:
I'm looking for the sway bars holders of the Cyclone, as they have a set-screw on them and are similar to the ones on the 415MSX (that doesn't and thus the sway bar moves a lot within the free space, specially if they are the thin ones)... can someone provide me the ref. number of them (or from the plastic tree that have them in)??
Thanks a lot,
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 05-30-2007, 03:03 AM   #8546
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Originally Posted by Wing Chun
Hi Barber
I sent you a few, 2 of them are from Simon Feigl that he sent me. The one for low grip bumpy is the one I used so thank you Simon
It is one of the best alround setups I have ever used on any car that I have raced.
Here is a link to some of Simons setups
http://www.rcracer.com.au/forum/view...4511&start=220
Addam
Glad you like it mate.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 05-30-2007, 04:53 AM   #8547
Thraex's Avatar
Originally Posted by rampal
Hi Cyclone owners:
Thanks a lot,
al
The partnumber in the manual is: 70741.
It probably is a rack of plastic parts since the parts (plastic piece in front and behind the swaybar) has the numbers '1' and '2' standing next to it.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 05-30-2007, 06:13 AM   #8548
rampal's Avatar
perfect. Thanks!
cheers,
al
Old 05-30-2007, 11:37 AM   #8549
ROV
ROV's Avatar
Cheers wing chun.
Sounds Good
And no i have not yet use shims,, should i use them all round or fnt or rear.
But i'm always keen to give it all a go,
so i take it that pro4 shims will work cayse i can borrow a set of them and give them a whirl...
Old 05-30-2007, 12:04 PM   #8550
Elboogie's Avatar
Hope this helps
Addam
Wing Chun, do you use any shims under the front and rear blocks as well as the pivot blocks, or are you only spacing the pivot blocks themselves?
CYCLONE WCE
Jaco / Airtronics
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
