Old 05-23-2007, 08:51 PM   #8491
Trader Rating: 194 (99%+)
Originally Posted by Yub, yub, cmdr!
On my black version Cyclone, the diff pulley itself wobbles quite a bit no matter how much I tighten the differential itself. I mean, it's not slipping at all, the diff functions perfectly. But the pulley wobbles a lot.
How can I fix this?
This is normal for any ball diff. Just run the car.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 05-24-2007, 07:45 AM   #8492
mangoman's Avatar
Tightening a diff wont stop the wobble if you tighten the diff to the point where the outdrives hit the pulley (which shouldnt be possible) then you will effectively be creating a spool.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 05-24-2007, 08:00 AM   #8493
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
How can I fix this?
dont worry about it as long as the diff is not slipping its not going to hurt anything, mine has always been like that
Old 05-24-2007, 07:24 PM   #8494
hey guys i'm running a novak GTB 5.5r with my cyclone, what spur and pinion would be optimal? I'll be running on asphalt thanks!
dorick is offline   Reply With Quote
Old 05-25-2007, 06:09 AM   #8495
Hello,
Just for fun, I made an "RDX-isation" on my Cyclone.
More infos on www.overrc.com. This site is in french, but you can use a translation tool.
Best regards,
Georges.
Georges is offline   Reply With Quote
Old 05-25-2007, 11:38 AM   #8496
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Originally Posted by Georges
Hello,
Best regards,
Georges.
cool did you feel any different?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 05-26-2007, 02:33 AM   #8497
Hello,
The feeling on the track is not the same, because the weight distribution and the polar inertie (not sure of this term in english) are different. My conclusions are more directivity and less traction. I decide to not use this configuration in competition for the moment (asphalt and carpet with rubber tires).
Georges-
Old 05-26-2007, 09:04 AM   #8498
Mitropoulos Jim's Avatar
Hi all,
What's your opinion on this new motor mount set which allows the use of bigger spur gear?
http://www.precisionrc.com/nv/car/pr...code=news_HBBL
It raises the center shaft and so the spur gear by 2mm.
In the package there are two 2mm washers to put between the upper part of the rear bulkheads and middle chassis.
Has anyone used it?
Dimitris Mitropoulos
rcdim.blogspot.gr
www.the-painter.gr
Mitropoulos Jim is offline   Reply With Quote
Old 05-26-2007, 07:38 PM   #8499
fjm9898's Avatar
hey i am looking into getting a cyclone and i have a few questions
what are the upgrades the new purple and blue cars have of the original black car.
also i currently have a pro4. what parts can i bring over that will fit on the cyclone.
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 05-26-2007, 08:39 PM   #8500
Super Moderator
Marcos.J's Avatar
Originally Posted by Mitropoulos Jim
Hi all,
Has anyone used it?
you dont really need it you can run a 110 spur on the cyclone with out any mods and can run up to a 13.0 FDR range
Old 05-27-2007, 01:41 PM   #8501
fjm9898's Avatar
anyone help me out?
Old 05-27-2007, 01:48 PM   #8502
Super Moderator
Marcos.J's Avatar
there is not that much difference between the black versions and the blue and purple version, also with the pro4 you can use all the suspencion parts
Old 05-27-2007, 02:03 PM   #8503
fjm9898's Avatar
ok so really it was just a color difference... just wanted to make sure before i got get a older one that i am not already in the hole performance wise
is there an option chassis for asphalt or is the car ready out fo the box to hit the pavement.
also do the dog bones from the pro4 fit the cyclone... i have a pair of shinny cvds i would like to use on the cyclone cuz i herd the cyclone stock ones will bent with a oneway in there.
and i take it the rear hubs are the same. so i can transfer over my aluminum stuff.
Old 05-27-2007, 02:24 PM   #8504
Super Moderator
Marcos.J's Avatar
they are basically the same not that much difference, the kit is ready to go for asphalt i have a great set up if you need it ,for carpet i recommend the BMI kit!!! its a must if you are running carpet/foam
Old 05-27-2007, 02:24 PM   #8505
Super Moderator
Marcos.J's Avatar
dogbones will not fit the cyclone but the the rear hubs will
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
