Old 05-21-2007, 05:09 PM   #8461
Did you guys get a piece of purple anodized non-machined aluminum that looks suspiciously like a tie bar, but is never mentioned in the manual? It has two holes in it and is a bit narrower than the top plate.
Yub, yub, cmdr! is offline   Reply With Quote
Old 05-21-2007, 05:22 PM   #8462
Adam - Just unscrew the lower shock eyelet about 2 turns from the top of the thread, this should give you enough shock length to have a massive amount of droop.
Also gents i have found that on shitty unprepared tracks if you run an excessive amount of droop the car can actually be much much smoother to drive, the tracks we have in Australia tend to have very little traction and be very dirty, so limiting the droop too much can tend to make the car react unpredicatably.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-21-2007, 05:58 PM   #8463
Trader Rating: 193 (99%+)
Sounds like the suspension mount shim. You will want to start with 1.5mm all around. The Pro4 shims are the same. The Pro4 shims come with some that are a different width also. I cut those down and used them for the inner arm mount.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 05-21-2007, 06:25 PM   #8464
Wing Chun's Avatar
Originally Posted by Cyclone Charlie
I'm at a loss here on the droop thing? Why would you want to run 3mm of droop? That would put your center of gravity way up high and put a hole bunch of ground clearance in there for the chassis.
You are also limited on the amount the arms will travel downward by the overall length of your shocks.
All of the set-up sheets that I've seen that use the spacing that you put in, still run 5-6 on the droop settings.
Hi Charlie
The droop set up 5mm front and 3 mm back was used by Simon Fiegl here on a bumpy low grip track with lots of success. Over here as Besercoe stated the tracks are rather bumpy and low on grip.
I did set the car up 5mm front and 5mm back and this seems okay.
I have spent a lot of time playing with droop and this is where i have had the best results rather than springs and sway bar ajustments.
On my MRE I changed the droop from 3mm to 5mm front and back and went a full second faster and also recorded my fastest lap and race time. I drove the same but the car had so much more grip and turn in.
Thanks For all your replies and its so good to get feedback here on the droop issue.
Addam
Wing Chun is offline   Reply With Quote
Old 05-21-2007, 06:31 PM   #8465
Wing Chun's Avatar
Thanks Bradd(Besercoe) and bjspinner
That did the trick.
Do you have any good set ups you can send me for our shitty/bumpy tracks
to
addampga@bigpond.net.au
Thanks guy's
Addam
Old 05-21-2007, 07:01 PM   #8466
How come it's never mentioned in the manual?
Old 05-21-2007, 07:04 PM   #8467
So... it gives caster up front and anti-squat rear?
Old 05-21-2007, 07:54 PM   #8468
bmr
Trader Rating: 27 (100%+)
bmr
Do you have the cyclone or the cyclone S?
Only the cyclone S has a front diff, unless you changed from the one-way to a diff on the regular cyclone.
The cyclone S diffs are different than the regular cyclone diffs.
It is a regular cyclone, I bought it used and a diff came with it. I'll look at it again. maybe I didn't have a bearing seated all of the way, or it is an S diff. How can I tell for sure? It is back out, running spool now.
bmr is offline   Reply With Quote
Old 05-21-2007, 11:32 PM   #8469
mangoman's Avatar
Yeah they should be shims to go under the pivot blocks. You will need to get round shims to go under the FR RF blocks.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 05-22-2007, 01:31 AM   #8470
Wing Chun's Avatar
Hey Mango (Martin)
How did you go at tamworth?
Addam
Old 05-22-2007, 01:58 AM   #8471
NickM's Avatar
G'day all,
I'm trying to sort out my WCE prior to the upcoming Challenge Cup event in a couple of weeks. I've been running mod and breaking MIP CVDs left and right - literally. First the left went, then the right...
(Besercoe - it turns out it was a three-wheel drive problem I was having with the car. I appreciate your diagnostic help all the same).
So. Clearly I need to convert to the HD universal dogbones, even if it does mean a slight reduction in purple bling (note to self: buy more bling-bling purple bolts & screws to compensate. Investigate powdercoating the factory springs to matching purple. Send slightly abusive yet heartfelt and tear-jerking email to Trinity begging them to release a CO27 stock motor in purple).
I (well, mangoman) put in an RC Champ order, but HPI Japan are out of stock. Bummer. Looking at Tower, but the part numbers don't match what mangoman tells me I need
Can some kind person tell me what I need to buy and where I can order said items?
thanks in advance,
Nick
TRF 416 | Corally Φ | TOP Scythe | F103GT
NickM is offline   Reply With Quote
Old 05-22-2007, 02:17 AM   #8472
xray racer's Avatar
Trader Rating: 22 (100%+)
Originally Posted by NickM
G'day all,
thanks in advance,
Nick
Nick,
Try this website, i've ordered from there before and they are generally pretty good:
http://shopping.rcmodel.hk/
or speedtechrc.com maybe???
Hope you get they im time!
Cheers,
Robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 05-22-2007, 02:44 AM   #8473
NickM's Avatar
Robbie! Dude!!! speedtechrc.com have all the bits
Tower don't.
Legendary advice mate, thank you
Old 05-22-2007, 02:46 AM   #8474
xray racer's Avatar
No probs!
Hope you get em all in time!...
I may have to place an order myself soon lol
Cheers mate,
Robbie
Robbie Lloyd
Old 05-22-2007, 03:16 AM   #8475
NickM's Avatar
Ahh crap, no axles in stock
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
