Old 05-19-2007, 04:25 PM   #8446
protc3's Avatar
if you are running a diff in the front,make sure that you built them with the 2 bearings and not with the shims.the shims are too thin and the outdrive will hop over the shim and make the outdrive run eccentric and create a chatter.i have seen this happen before to my buddy who built the diff as the instructions said to.you need to have the 2 bearings.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-19-2007, 04:32 PM   #8447
fathead's Avatar
Check or replace your hub bearings also, one of them could have gotten damaged.
Slavich Design
fathead is offline   Reply With Quote
Old 05-20-2007, 10:13 AM   #8448
jag88's Avatar
What parts of the CVD did you replace ?
jag88 is offline   Reply With Quote
Old 05-20-2007, 03:03 PM   #8449
Also check that the belt tensioners are set the same at each side of the car. Sorry if thats obvious, but I've seen people running them wrong
vroomtshh is offline   Reply With Quote
Old 05-20-2007, 05:47 PM   #8450
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
I have listed my Cyclone on Ebay if anyone is interested the auction number is: 230132174688
Thanks Willy
Hobbytown USA Oshkosh
www.revolutionraceway.com
HVFracingwilly is offline   Reply With Quote
Old 05-21-2007, 01:07 AM   #8451
mangoman's Avatar
Originally Posted by Yub, yub, cmdr!
How do the clamp type wheel hubs work? Do I tighten them A LOT so that they don't fall off? And is excessive play here normal?
Dont crank them up tight otherwise the hex hub can crack
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 05-21-2007, 04:55 AM   #8452
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Traitor!
Snowy!
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 05-21-2007, 08:36 AM   #8453
Wing Chun's Avatar
Hey guy's
Here is one for the book's.
I set up my new chassis on my worlds and added 1.5 mm spacers under the blocks. Now when I went to set up the droop I could not get 3 mm of droop due to the arm not being able to drop far enough down, the best I could get was 4.5mm of droop. Have ever any of you guy's encountered this and If so, what did you do to obtain less droop. I set the car up and un screwed my droop screws, but to obtain a even and consistant even amount of droop on both sides the droop screw has to sit on the chassis. In this case the srew to have 3mm of droop is no where near the chassis.
Any help or comment's would be great here on this one as I know just how important droop is in Modified.
Thanks Guy's
Addam
Wing Chun is offline   Reply With Quote
Old 05-21-2007, 08:48 AM   #8454
Originally Posted by Wing Chun
Hey guy's
Here is one for the book's. I set up my new chassis on my worlds and added 1.5 mm spacers under the blocks. Now when I went to set up the droop I could not get 3 mm of droop due to the arm not being able to drop far enough down, the best I could get was 4.5mm of droop. Have ever any of you guys encountered this. If so what did you do to obtain less droop. I set the car up and un screwed my droop screws, but to obtain a even and consistant even amount of droop on both sides the droop screw has to sit on the chassis. In this case the srew to have 3mm of droop is no where near the chassis.
Any help or coments would be great here on this one as I know just how important droop is in Modified.
Thanks Guy's
Addam
Most fill in the downstop settings at the droop section....
Rob Janssen
Rob Janssen is offline   Reply With Quote
Old 05-21-2007, 08:58 AM   #8455
Wing Chun's Avatar
Hi Rob
Do you mean a longer droop screw?
Thanks addam
Old 05-21-2007, 01:49 PM   #8456
ShaunMac's Avatar
Why are you trying to run so much droop?
Try running 5mm front/rear on the droop gauge with ride height around 5mm also. This is a good starting point.
ShaunMac is offline   Reply With Quote
Old 05-21-2007, 02:12 PM   #8457
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Hi Rob
Thanks addam
no he means most ppl dont use the spacers, just droop it
BlackedOutREVO is offline   Reply With Quote
Old 05-21-2007, 02:19 PM   #8458
Cyclone Charlie's Avatar
I'm at a loss here on the droop thing? Why would you want to run 3mm of droop? That would put your center of gravity way up high and put a hole bunch of ground clearance in there for the chassis.
You are also limited on the amount the arms will travel downward by the overall length of your shocks.
All of the set-up sheets that I've seen that use the spacing that you put in, still run 5-6 on the droop settings.
Cyclone Charlie is offline   Reply With Quote
Old 05-21-2007, 03:43 PM   #8459
protc3's Avatar
your droop adjustment is used to control weight transfer to the front and rear of the car during acceleration and deceleration.the more up travel over ride height that you have,the more weight transfer you will have.for instance,if you set your car to 2.5mm of uptravel or droop,the car will transfer weight forward until the screws hit the chassis and stop its upward travel.once the screws touch,the weight tranfer to the opposite end of the car is stopped and will hold that specific amount of weight over that end of the car until the car levels out.the more weight you allow to transfer,the more traction you will get to that end of the car.if you run less uptravel in the front,this will not allow as much weight to transfer to the rear of the car during acceleration and it will keep more weight towards the nose and in effect will increase on power steering.less in the rear will take away off power steering.you need to find the happy medium.i run 2.0-2.5mm front and rear uptravel on my car and it works great for me.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-21-2007, 04:13 PM   #8460
Trader Rating: 22 (100%+)
Hey guy's
Thanks Guy's
Addam
you need to make the length of the shocks longer, if you run on a bumpy track you increase ride height and decrease droop.
unscrew the eyelet on the bottom of the shock but make sure the shocks are the same length.
bjspinner is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
