Old 05-15-2007, 08:23 PM   #8401
Hi guys. I was assembling my Cyclone today.
But I hit into some snags!
1) I got two diff pulleys of the same type, where the recessed holes for the balls are square! And one of them is supposed to be for the one way...
2) the one way has 3 screw holes instead of four as depicted in the manual. Is this normal?
3) What oil should I run inside the one way, and how do I put it in?
Yub, yub, cmdr! is offline   Reply With Quote
Old 05-15-2007, 10:24 PM   #8402
Cyclone Charlie's Avatar
You have the 2-piece pulleys that are wide and have to be glued together, right? One of them should have a smaller center hole than the other.
Your one-way has 3 mounting holes right?
If you answered yes to both questions, you can use the pulley with larger center hole on the front one-way and the one with the smaller center hole on the rear diff. Hot bodies has some weird stuff going on with the one-ways.
By all rights the part numbers for those pulleys should be A495 for the rear and A496 for the front one-way, which are old part numbers and HPI says that the A496 pulley is discontinued. there are newer pulleys out that are narrower and the part numbers for those are 61050 for the rear, and 61051 for the front one way. Unfortunately the 61051 won't fit the 3 hole 0ne-way.
It sounds like you got the same stuff that I got, they're old kits.
You should probably do what I did and get a couple of spare A496 pulleys if you can find them?
Use the white silicone grease on the diff.
Cyclone Charlie is offline   Reply With Quote
Old 05-15-2007, 11:17 PM   #8403
sbs
sbs's Avatar
Originally Posted by bigb11
question do you have to run sway bars outdoors? if so which ones.
I use the 1.2mm front and back (rubber tires )
Soren B. Sorensen
Team-manager
Empty Pocket RC-Team
Serpent S411 / Powered by EPRCT Motor Management
sbs is offline   Reply With Quote
Old 05-15-2007, 11:21 PM   #8404
RC MARKET's Avatar
Also F use 1.4mm , R use 1.2mm
if no traction F use 1.2mm , R don't use !
This basic setup
RC MARKET is offline   Reply With Quote
Old 05-15-2007, 11:22 PM   #8405
RC MARKET's Avatar
Front one way use Seppent one way lube
Old 05-16-2007, 08:40 AM   #8406
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
The holes for the diff balls are SQUARE! Can it still work?
By looks, it looks like I have the spool pulleys...
yes
Old 05-16-2007, 08:41 AM   #8407
Old 05-16-2007, 08:50 AM   #8408
Stew Noble's Avatar
Square holes hold the lube for the balls in the pulley for longer
// S N F //
Stew Noble is offline   Reply With Quote
Old 05-16-2007, 10:26 AM   #8409
Wing Chun's Avatar
Hey Guy's
Can one of you wonderful gents please tell me what would the difference between 2mm and 4 mm of ackerman make on the steering please on the cyclone. At the moment I have 4mm but if I was to change to 2mm what diference would it make.
Thanks in Advance
Addam
Wing Chun is offline   Reply With Quote
Old 05-16-2007, 10:40 AM   #8410
Super Moderator
Marcos.J's Avatar
Originally Posted by TRFMAD
Hey Guy's
Thanks in Advance
Addam
if you are running one-way use 4mm if using spool use 2mm
Old 05-16-2007, 10:48 AM   #8411
RC MARKET's Avatar
Hey Guy's
Thanks in Advance
Addam
4mm can smaller steering to turn !
Old 05-16-2007, 10:50 AM   #8412
Is part 70733 included in the kit? you know, the thing that bolts to the spur gear which bolts to the gear hub?
Thanks!
David
Old 05-16-2007, 12:19 PM   #8413
Actually, the square ones don't fit. The ball is too big to go into them.
Gar, I hope Hot Bodies helps me out. So far the kit's been a pain. The drivetrain parts are ALL different from the manual.
Old 05-16-2007, 12:30 PM   #8414
Yub Yub
Go to the Hot Bodies sight and download the manual there. It has the right manual for the kit that you have.
The 70733 comes with the kit. It's a carbon fiber part.
Also the balls are a little tight but snap into place, but move freely.
Old 05-16-2007, 12:44 PM   #8415
Into the square holes?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
