Old 05-11-2007, 10:01 AM   #8326
stuey's Avatar
has anybody got a link for the editable setup sheet
cheers
stuey is offline   Reply With Quote
Old 05-11-2007, 11:26 AM   #8327
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
cheers
http://www.gearchart.com/setup/setup...lone_blank.pdf
Old 05-11-2007, 12:24 PM   #8328
What do you mean, sparingly with the Loctite? Doesn't blue loctite come off easily?
For example, where would be a place that I absolutely must not loctite?
Yub, yub, cmdr! is offline   Reply With Quote
Old 05-11-2007, 01:26 PM   #8329
rc-zombies's Avatar
cheers
if you want the WCE version.. it will cost you...
Old 05-11-2007, 04:15 PM   #8330
Hi,
Does The HotBodies Cyclone S option part - #HB70725 CENTRE PULLEY (16T) - substitute this standard part - #HB61052 - Hot Bodies Cyclone S 16T Pulley - ?
Can anyone explain how this option part work?
regards
nuno
nmberga is offline   Reply With Quote
Old 05-11-2007, 04:41 PM   #8331
ShrekNZ's Avatar
Firstly too much can be a real problem one of our local guys borrowed my stud lock to use on his blocks and I suspect he used a little too much and got it under the countersink as well he nearly snapped a driver trying to get it undone - it was really funny watching the panic - locktite is just a version of CA glue afterall. Personally I try to not use Locktite at all. I think it is also designed for metal threads rather than plastic as well for instance I would not suggest using in king pins.
ShrekNZ is offline   Reply With Quote
Old 05-11-2007, 05:32 PM   #8332
mangoman's Avatar
The Cyclone parts are carbon graphite not plastic. If anything you can put a touch of the black grease (the one in the kit with the red cap) on the screw to help it go in. Even i havent ever stripped the thread on a carbon graphite part.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 05-11-2007, 05:51 PM   #8333
So i was reading the Hara guide(a pain cuz its in japanese) I noticed he didn't sand down the sides and just CA glued the chassis, is sanding necessary? Also he used a dremel to take away parts of the carbon fibre near the belt, I don't have a dremel, any other ways i can do it? Or is it really necessary? Thanks guys
dorick is offline   Reply With Quote
Old 05-11-2007, 06:24 PM   #8334
2-Bad's Avatar
Trader Rating: 24 (100%+)
Here's the translated version... but it's only marginally better...
Hara Build Tips Translated
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-11-2007, 06:37 PM   #8335
mangoman's Avatar
You dont have to bother sanding down the side but its better for the chassis if you round of the bottom edge.
You do need to file down the battery slots and also the slots where the tape goes through (or at least the side of the tape slots where the tape wraps around ie. the bottom of the chassis on the edge closest to where the batteries sit, otherwise the tape will tear on the sharp carbon fibre edge in crashes)
www.smaracing.org
Old 05-11-2007, 08:49 PM   #8336
Cyclone Charlie's Avatar
Using locktite sparingly means you only want it to be on the metal threaded areas and not running to places it shouldn't. I accidently used to much on the CV's and after it dried the CV wouldn't pivot. You only locktite the areas that are labeled to use it in the assembly manual. You also never use locktite on anything other than metal to metal fasteners.
Cyclone Charlie is offline   Reply With Quote
Old 05-11-2007, 08:50 PM   #8337
Do you use just normal sandpaper to sand the battery slots and chassis?
Old 05-11-2007, 09:18 PM   #8338
A Ilievski's Avatar
Trader Rating: 39 (100%+)
use a file for the slots
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 05-11-2007, 10:24 PM   #8339
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
will there be a new version anytime soon?
cHckbOY5 is offline   Reply With Quote
Old 05-12-2007, 01:39 AM   #8340
RC MARKET's Avatar
not have !
RC MARKET is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
