Old 05-05-2007, 06:32 PM   #8266
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Ok guys I am really confused with how people are listing drop on setup sheets.
I was checking out the setup sheet from andy moore from the worlds. It list ride as 5mm and droop as 5.5mm.
Now when it is listed as 5.5mm for droop does that mean 5.5 mm of uptravel. So when you lift the rear of the car and slide a ride height gauge under the chassis it should read 10.5 mm (5mm ride height plus 5.5mm droop)
or
Is it 5.5 on a standard droop gauge.
or
is .5 mm above ride height of 5mm
I am a little confused as I am primarily a foam carpet guy and you never run more of 1mm or so of uptravel/droop above ride height.
J.Gonzalez is offline   Reply With Quote
Old 05-05-2007, 09:42 PM   #8267
mangoman's Avatar
It should be 5.5 on a standard droop gauge.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 05-06-2007, 12:44 AM   #8268
We use the HPI droop gauge to measure droop. The droop on his worlds setup sheet is done this way.
Team Durango, ORCA, MuchMore, Sanwa, Protoform, Tonisport, MR33, Roche, Custom Blitz Bodyshells
Elliott Harper is offline   Reply With Quote
Old 05-06-2007, 02:08 PM   #8269
Is there a battery strap or any way to mount a pack without using tape?
Or a way to mount stick packs?
Thanks!
David
Yub, yub, cmdr! is offline   Reply With Quote
Old 05-06-2007, 02:50 PM   #8270
2-Bad's Avatar
Trader Rating: 24 (100%+)
Dave,
I've heard you can fit an X-ray battery strap with some modifications from one of there "annually released" cars (don't know which one), but I've never attempted this and don't know the procedure. Also these might be useful as well if you are contemplating this task.
Are you having trouble with tape? or just don't like it??
Thanks!
David
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-06-2007, 03:32 PM   #8271
Ha, no, I do not own the vehicle yet!
Well, I will soon. But I was interested in having a strap for the convenience.
By the way, the WCE and the black one do not differ in DESIGN except in color/shock towers, right?
Old 05-06-2007, 04:36 PM   #8272
Should be here by this Friday.
Hm, I wonder why HB doesn't make a strap?
Old 05-06-2007, 04:43 PM   #8273
ShaunMac's Avatar
That is correct. That's the way droop is measured on the HB set-up sheets.
This picture shows 5mm droop in the rear.
ShaunMac is offline   Reply With Quote
Old 05-06-2007, 05:26 PM   #8274
2-Bad's Avatar
Once again I don't know for sure, but I'd suspect it would create tweak issues...
I thought the same thing having never used tape before owning Clones, but as long as you use quality tape and file the tape slots in the chassis well, tape is fine to use. Have never lost a pack yet...
Old 05-06-2007, 07:50 PM   #8275
bxpitbull's Avatar
I'm going to hunt down some HPI Pro 2 straps. I think with a lilmodding, they will work just fine.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 05-06-2007, 07:59 PM   #8276
fast-ho-cars's Avatar
does anyone know if the Xray T2 C-hub fit on a Cyclone, mainly if the hinge pin holes are the the same?
fast-ho-cars is offline   Reply With Quote
Old 05-07-2007, 04:47 PM   #8277
Default spares
Hey, what is the deal on spare parts for the cyclones?
I just purchased an andy more version and am having problems sourcing spare parts for my car. I guess I should have looked into the spares availability first.
I am beginning to think that i made a mistake, switching from xary to a hotbodies.
skink is offline   Reply With Quote
Old 05-07-2007, 05:24 PM   #8278
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
its "never a mistake to drive a hotbodies car"
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 05-07-2007, 06:13 PM   #8279
have you checked Tower Hobbies, StormerHobbies, SpeedtechRC, etc, etc,
also check the listings for HPI Pro4 also. i found that Xray front steering knuckles work on a Cyclone. also some from Kysoho cars.
the best deal for parts now is to just go ahead and get another kit, Stormer still has the Cyclone for $249.99. do the math...can't beat that
sort of like in the day some TC3 parts worked on a XXX-S and vice versa. front c-hubs, f-knuckles and rear hubs.
did you have a Xray T2 or later car? do you if front c-hub or rear hubs will work? Cyclones have a 2.5MM hinge pin on the outside were the hubs mount and and 3MM on the inside were the A-arms mount to the pivot blocks.
i like some of the Xray hop-up aluminum hubs
Old 05-07-2007, 06:34 PM   #8280
Not anymore...
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
