Old 04-30-2007, 04:58 PM   #8161
bxpitbull's Avatar
Default Um, no
Um.......no. Just saying peace. I have a relationship with the supreme one, but since you are conscious, you can pray for yourself.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 04-30-2007, 05:38 PM   #8162
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Originally Posted by yyhayyim
My buddy just got the new low traction arms. The car had awesome sterring and traction. It was just like driving a dialed carpet car...
Where can I get these? Thanks!
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 04-30-2007, 06:04 PM   #8163
ROV
ROV's Avatar
Looking to get the mod motor mount for the WCE cyclone..
Can anyone tell me the supplier..
Cheers
TELL THEM ROV'S HERE AND HE'S RUNNIN WHEELS THAT ARE READY TO RACE !!!
CEO TRASH TALK TOURING HOME OF WA'S CHEAP TRASH PISSTAKES
AM PSYCLONE,HOTBODIES D4,NOVAK,LRP,HACKER,MEGA,EFLIGHT.JR,KOPRO,HITECH, SPEKTRUM,TRAKPOWER,OS,CDC,SWASHDRIVE JET,ZENOHA,WEMOTECH DUCTED,LIPO4GO,LOSI,KOKOM,CDC,5IVE,8IGHT,XXCR,LST,CASTLE
ROV is offline   Reply With Quote
Old 04-30-2007, 07:09 PM   #8164
Trader Rating: 194 (99%+)
I believe these are the Cyclone S arms. Plastic is not as stiff.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-30-2007, 08:01 PM   #8165
Scooby Horton's Avatar
Originally Posted by jag88
I've been using the Kyosho diff hardware from their Stallion. It's bullet proof.
You will have to drill out the halfs due to the larger screw dia. and will have to grind about 1mm off the thread end so that it doesn't jam up the axle blade. It also requires a 1.5mm washer under the nut retainer.
The Kyosho part #'s are:
TF120---- Diff Screw (with two nuts)
BRG100--- Thrust Brg (Balls/washers)
UM124---- Spring (I think original HB spring may work)
TF113---- Nut Retainer ( this is a full tree of parts that has to bought just for the nut retainer)
I believe this to be the ultimate fix (unless you want to go with the Xray hardware). It's about 20 bucks in parts and like I said it's bullet proof AND there's a slot in the screw head just the like old one which allows for easy adjustments.
I haven't tried this with plastic diffs.
You the man!
D&K Hobbies
Trinty
B2designs
BMI
Oddy Racing
IRS
Spektrum
Epic
Scooby Horton is offline   Reply With Quote
Old 04-30-2007, 11:30 PM   #8166
Skill's Avatar
HPI released a low traction arms set for the Pro 4 about 2 or 3 years back. Not sure if they are still in production, but they were extremely cheap, $10 or 6 for a full set (yes 2 front and 2 rear).
Skill is offline   Reply With Quote
Old 05-01-2007, 02:34 AM   #8167
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Low traction arms are still available in the market. It flexes more but breaks easily compared to the carbon composite.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 05-01-2007, 02:34 AM   #8168
31420 - HIGH TRACTION SUSPENSION ARMS
try champ international
omoser is offline   Reply With Quote
Old 05-01-2007, 02:36 AM   #8169
Cheers
champ should have them (link )
HTH
Old 05-01-2007, 06:31 AM   #8170
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
Horizon hobby has them. Check for part numbers and stock status...that's where we picked them up from. They are a bit softer/more flex, and give the car much better rear traction and front steering...and they are not weaker than the regular arms...because they are a bit softer, they can take hits a bit better. This already has been discussed and tested. Its a great tuning option and must have for those who run Cyclones on asphalt. Try them out and you'll notice considerable traction gains in your rides...
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-01-2007, 07:25 AM   #8171
Cheers
HBS61298 Black Motor Mount
HBS61329 Purple Motor Mount
HBS61360 Black Purple Mount
They will be available soon from your local supplier. Just tell them the number you want.
Tony Vega is offline   Reply With Quote
Old 05-01-2007, 08:57 AM   #8172
bxpitbull's Avatar
Default Back to the diff again
Running my Cyclone, after 15 minutes or so, freshly built rear diff loosens everytime. Built per the instructions, allowed to sit while threadlock dries and I even use 1000wt diff oil! What gives?!?!?!
Old 05-01-2007, 09:12 AM   #8173
yyhayyim's Avatar
BXPITBULL: that sucks...that's the only reason why I gave up on Cyclones. I just cant belive HB/HPI cant come up with a better diff design. Its pretty cheap on their part. I know some have not had these issues, but many poeple have reported those pesky screws breaking, nuts getting loose, and outright melting or slipping, and how dirty they get- to the point they have to be rebuilt after every race or so for them to work nicely. I personally have had all these issues, and nothing is more frustrating. I have built them according to all the tricks in the book, and the bes I've had lasted a few weeks by the time they got extremly dirty, even with the dust covers, or just staretd to snap, or get loose, etc. Its easy: if you have a great diff design, people should NOT have to be buyin other manufaturers parts and experimenting and tweaking to finally getting your product to work. HB has refined and inproved their bones, spools, cups, chassis, etc, but they have failed to work on this issue, and it really sucks...
I've gone back to Xray and Schumacher, where at least these issues are very rare.
Old 05-01-2007, 09:57 AM   #8174
bxpitbull's Avatar
Drives me "nuts". Considering this has been the only drawback, I am considering this "flaw" to be minimal...providing someone can give me an alternative to solving this dilema. The car is an absolute rocket and barring this small problem, I am looking forward to crushing nitro cats for the entire summer. Mangoman, marcosJ, someone please let me in on your secret.
Old 05-01-2007, 10:42 AM   #8175
RC MARKET's Avatar
Cheers
Spur gear only bigger 108T to 110T only !
RC MARKET is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
