Old 04-25-2007, 01:22 AM   #8101
Thraex's Avatar
It changes your roll center. You're probably best reading the following link: http://home.scarlet.be/~be067749/58/ , go to suspension>roll center.
Another thing you can change with it is the anti-dive/kick-up (front) and anti-squat (rear).
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 04-25-2007, 03:20 PM   #8102
bxpitbull's Avatar
Default Why are......
Why are the metal outdrives w/blades cheaper than the composite outdrives?
BUMP, ahem TTT
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 04-26-2007, 12:14 AM   #8103
Originally Posted by Thraex
For those who are having problems with snapping diff screws, I haven't broken anyone so far. I'm using the titanium one from HB, but the one from Edit will also work. Another thing I always do is loosening the diff screw at the end of a race/practise day, so there isn't a constant pressure on the screw (only when you use it).
I did many diff screws, i followed peoples advice here, drilled out the short side of the diff with a 3mm drill, and placed a 1mm suspension shim under the diff nut. No more problems to date.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-26-2007, 11:07 AM   #8104
RC MARKET's Avatar
yes me too !
RC MARKET is offline   Reply With Quote
Old 04-26-2007, 05:19 PM   #8105
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I have been running the Cyclone for almost a year now and I have broken maybe 3 screws (2 in 1 day really pissed me off!). But... on the whole, I don't really see a problem with the diffs the way that they are as long as you know how to build them in the first place, and know how much tension to give them. The main problem is that people tighten them up too much. You need to give them a little bit of slip otherwise it will snap.
Also... its very important to break them in, particularly by hand. Andy showed me step-by-step how he builds his diffs and by simply breaking the diff in by hand, you really shouldn't have a problem (I haven't broken one in around 3 months, and I haven't had them loosening off too). The main thing is that the diff feels really free, yet also has a very strong action. When you build your diff, build it loose and tighten it up in the car. That'll help prevent you to not overtighten.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 04-26-2007, 05:21 PM   #8106
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
i only broke one and it was due to someone hitting my car at the rear tire
Old 04-26-2007, 05:59 PM   #8107
fast-ho-cars's Avatar
BUMP, ahem TTT
are you talking about the rear diff? My Cyclone (blk ed.) rear diff is machined Delrin or something like that. it's not composite like the ones i had on my Pro4.
fast-ho-cars is offline   Reply With Quote
Old 04-26-2007, 07:47 PM   #8108
protc3's Avatar
the plastic outdrives are machined Acetel(delrin) with machined aluminum retainer clips.they are a more expensive part to make.they are more difficult to make and Acetel is more expensive than aluminum.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-26-2007, 08:47 PM   #8109
F. Alonso's Avatar
Sounds like a hard impact!
Simon Feigl
Old 04-26-2007, 08:48 PM   #8110
Super Moderator
Marcos.J's Avatar
yes it was someone forgot to brake
Old 04-26-2007, 09:58 PM   #8111
Trader Rating: 193 (99%+)
The Cyclone S diff outdrives are about $5.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-26-2007, 11:33 PM   #8112
ROV
ROV's Avatar
Gday my andy moore cyclone, when i hit a bump it seems to slip diff
for a few seconds untill you back off and turn a bit,cant tell if its fnt or back.got one way in fnt..
then it's like nothing happend.....and i can't find the problem yet if it would just fully break i will find out what it is.but i dont want it to (KODAK) develop..
any suggestions????
TELL THEM ROV'S HERE AND HE'S RUNNIN WHEELS THAT ARE READY TO RACE !!!
CEO TRASH TALK TOURING HOME OF WA'S CHEAP TRASH PISSTAKES
AM PSYCLONE,HOTBODIES D4,NOVAK,LRP,HACKER,MEGA,EFLIGHT.JR,KOPRO,HITECH, SPEKTRUM,TRAKPOWER,OS,CDC,SWASHDRIVE JET,ZENOHA,WEMOTECH DUCTED,LIPO4GO,LOSI,KOKOM,CDC,5IVE,8IGHT,XXCR,LST,CASTLE
ROV is offline   Reply With Quote
Old 04-27-2007, 12:33 AM   #8113
Skill's Avatar
Try cleaning out and re-oiling your one-way diff. One-way bearings can be quite delicate and only need the smallest bit of grit/dirt on the rollers and it can cause them to slip. Maybe is it just slipping when it takes a lot of stick but under normal driving conditions its ok.
Skill is offline   Reply With Quote
Old 04-27-2007, 04:13 AM   #8114
ROV
ROV's Avatar
Cheers done that and found bad fnt bearing 10 x 15x4mm....
and cleaned out one way....
hope that was it....
Cheers unlesss this has happen to any one else???
Old 04-27-2007, 04:29 AM   #8115
mangoman's Avatar
Yeah they are also a pretty soft plastic relative to the other outdrives.
Probably suitable for stock but id be worried about using it in other classes
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
