Hot Bodies Cyclone
#8026
Originally Posted by TRFMAD
Thanks 2-bad
I have just noticed a problem with the antena rubing on the belt. The reciever is not to close to the belt but the wire comes out right were the belts are. I have tried to put it under and over belt but still rubs. Can you guys advice me on the best way to avoyed the belt.
I have just rebuilt the center pulley and it is much better.
Addam
Addam
#8027
Thanks 2-bad
Addam
Addam
#8029
I have my receiver mounted the other way around, so the antenna wire exits the receiver on the outside of the car, and then route it back around, this way you have a bit more freedom on the height of the wire by the belt. My wire goes above the belt.
#8030
Any one try using the 4800 Li-Po in the Cyclone? will it fit?
#8031
The WCE pdf file has been posted on the Euro HB website.
http://www.hbeurope.com/pdfs/setups/...yclone_WCE.pdf
I'll try to make an editable version soon..
pm me your email address and I'll send soon when finished..
#8032
Yes the 4800 Li-po does fit in the Cyclone with no modifications needed.
#8033
yeh my spektrum wire comes out the top of the case
how many ppl here run stock class with a one way up front?
#8035
#8036
Hi guys new to this forum. I have a WCE edition on its way. I really wanted a Surikarn edition but couldn't find one. well untill now, if anyones interested there is a used one on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...1567&rd=1&rd=1
#8037
Just took the car for 2 pack run to try it out at the local track. First impressions,
1/much more steer than the MRE
2/ much less under steer than the MRE
3/ Much better mid corner control than the MRE
4/I think the car is a real winner.
I am running the same setup as the standard setup from the box.
The gold coast track is wide and very fast, so I will be running at Meakin Park in a few week's which is a lot tighter and much more technical. I will talk to 2-bad who is a member a Meakin and get some final tips from him, I hope. I may just sneak up and keep looking over his shoulder when he is not looking.
But end result I love the car.
TomB here in OZ painted the shell of Rhienards car, It will have to do,
Addam
Addam
#8039
I'm backkkkkk
Still rocking the Pro4, but couldnt help but take cheehtae up on the deal on a once used Cyclone. Going 48 pitch. Stuck an 81t spur. Dropping a 3.5 in it. Based on the 3.5 in the Pro4, FD 9.23. Motor is now breaking 110 degrees. Figured I would do something similiar for the Cyclone and drop a 20T pinion givng me FD 9.87. What should I expect? I run against nitros, wide open track, longer straights. Set-ups.....81T leaves me a gnats hair of space, can I go larger???
#8040
Originally Posted by mangoman
Post the picture in the TRF thread and see if you get any comments
Thats my story of how I changed to Cyclone
Addam
Hey what did you guy's race before Cyclone and what made you change ?
