Old 04-17-2007, 01:00 PM   #7996
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by chris_blakey
is this the same as the much more anti wear grease?
I have the Much More stuff as well, but prefer the Tamiya as it is thicker/stickier (technical talk here ) IMO. It does attract dust/dirt to the area, but does not seem to effect the anti-wear properties of either the outdrives or the dogbone pins. Nor does it seem to affect the handling of the car either. If you keep reapplying it the wear is very, very low...
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-17-2007, 01:10 PM   #7997
cheers, will give it a go when i get a new spool!!
chris_blakey is offline   Reply With Quote
Old 04-17-2007, 02:19 PM   #7998
bxpitbull's Avatar
Default ?????
Originally Posted by Marcos.J
try this set up !! the springs are 13 lbs if you dont have tamiya springs
Nice set-up. Thought you said you were running 10.75 FD? Is this a set-up for a shorter track?
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 04-17-2007, 02:23 PM   #7999
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
actually its a typo on the set up that FDR is with the 3.5 not the 4.5
Old 04-17-2007, 06:05 PM   #8000
Originally Posted by Thraex
Did someone tried to grind out the original spool (included in the hara/surikarn kits) so that it can accept blades from the rear, or makes this the spool too weak? The spools seems to wear pretty fast, so I'm wondering if this mod is a good one.
i suggest you out try the version 3 spool : hb cyclone version 3 spool
i used to use the version of the spool that's included with the hara/surikarn editions. these can wear out quite fast (even with aw grease). after switching to the ver 3 spool, i've stuck with that. they last much longer, have replaceable outdrives that have 2 slots in them instead of 1 (meaning that they can last twice as long and is cheaper than replacing one whole spool when the slot in the outdrives wear out).
sidewaysdriver6 is offline   Reply With Quote
Old 04-17-2007, 08:37 PM   #8001
RC MARKET's Avatar
Std Ver. 3 or 3 racing Spool
http://rcmarket.com.hk/index.php?cPath=51_98_118
RC MARKET is offline   Reply With Quote
Old 04-17-2007, 09:47 PM   #8002
ROV
ROV's Avatar
WOW Thank shaun,marcos,pitbull,,,,Just what i was after that should keep me busy 4 a few days,,, looks like another test and tune day tommorro,,,,So i b ready 4 racin sunday.....CHEERS to all who put in... il try them all 1 by 1
PS
Iv'e seen a quick referance page 1 guy has at the club its like a xcell spread sheet....if eg power understeer= do this....oversteer= dothat or this or this....
Can't remember what he said it was ..but looks bloody helpfull page its got a hole file with it but just this one page will help,,,he keeps promising a copy but not yet...Anyone know what im on about,,i dont,,,any help...
TELL THEM ROV'S HERE AND HE'S RUNNIN WHEELS THAT ARE READY TO RACE !!!
CEO TRASH TALK TOURING HOME OF WA'S CHEAP TRASH PISSTAKES
AM PSYCLONE,HOTBODIES D4,NOVAK,LRP,HACKER,MEGA,EFLIGHT.JR,KOPRO,HITECH, SPEKTRUM,TRAKPOWER,OS,CDC,SWASHDRIVE JET,ZENOHA,WEMOTECH DUCTED,LIPO4GO,LOSI,KOKOM,CDC,5IVE,8IGHT,XXCR,LST,CASTLE
ROV is offline   Reply With Quote
Old 04-18-2007, 01:11 AM   #8003
Wing Chun's Avatar
Here is one I have
Corner Section Entry Mid corner Exit
Situation Oversteer Understeer Oversteer Understeer Oversteer Understeer
Change Front Rear Front Rear Front Rear Front Rear Front Rear Front Rear
Tires and Inserts Ha (1) So (2) So (1) Ha (2) Ha So So Ha Ha (2) So (1) So (2) Ha (1)
Springs Ha (1) So (2) So (1) Ha (2) Ha So So Ha Ha (2) So (1) So (2) Ha (1)
Camber De (1) In (2) De (1) In (2) De In De In De (2) In (1) De (2) In (1)
Ride Height Ra Lo Lo Ra Ra Lo Lo Ra Ra Lo Lo Ra
Droop De In In De De In In De
Anti-Roll Bars Ha (1) So (2) So (1) Ha (2) Ha So So Ha Ha (2) So (1) So (2) Ha (1)
Toe De (1) In (2) In (1) De (2) De De In In In (2) In (1) De (2) De (1)
Shock Positon <> (1) >< (2) >< (1) <> (2) <> >< >< <> <> (2) >< (1) >< (2) <> (1)
Shock Oil In (1) De (2) De (1) In (2) De (2) De (1) In (2) In (1)
Wheelbase Lengthen Shorten Lengthen Shorten Lengthen Shorten
Castor In De De In De (2) In
Anti-Squat De In De In De In
Kick-up (Anti-Dive) In De In De In De
Roll Center Ra (1) Lo (2) Lo (1) Ra (2) Lo Ra Ra Lo Ra (2) Lo (1) Lo (2) Ra (1)
Change Notes Key Additional Notes
Ha Harder
Tires and Inserts Try to use same combo, F/R So Softer
Springs Try to have same spring stiffness when pushing down on car. In Increase
Camber Upper limit 2deg -ve, more at rear than front De Decrease
Ride Height No Large Differences, never more than 1mm <> Out
Droop Very Powerful adjustment, starting point of 1.5F, and 2R >< In
Anti-Roll Bars Always run a sway bar, can run springs softer. Ra Raise
Toe 0 to -0.5 F, 2 to 3 R Lo Lower
Shock Positon (1) Adjust 1st
Shock Oil 40-60wt R, 60wt F as starting point (2) Adjust 2nd
Wheelbase aim to achieve 50/50 weight split
Castor Low grip - more castor
Anti-Squat Fine tune, on rear only
Kick-up (Anti-Dive) Some kick-up = stable car, good on-power steering
Roll Center Try to keep similar F-R
Oh dear that did not work I have PMed you
Addam
Wing Chun is offline   Reply With Quote
Old 04-18-2007, 01:19 AM   #8004
Wing Chun's Avatar
Hi
Tryhard has the crib sheet on excel on his website, here is the link
http://www.thard.co.uk/
I hope this helps
Addam
Old 04-18-2007, 02:26 AM   #8005
ROV
ROV's Avatar
CHEERS TRFMAD now just kicking myself 4 not comming here sooner....
In one day my biggest questions have been answerd
Warm fuzzy feelings allround.........
Old 04-18-2007, 03:15 AM   #8006
protc3's Avatar
Originally Posted by rc-zombies
looking good...
with the added 3mm of wheelbase... will it use the stock belts?
eta on availability?
it will use the stock belts.we moved the rear arms back to achieve the increases wheelbase.they are in stock now for those interested.thanks for looking buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-18-2007, 07:47 AM   #8007
bxpitbull's Avatar
Default Right on.
Just getting busy, praticing. My 3.5 is ripping up spur gears like it's no one's business. Case in point, went outside, slapped down the Pro4, not one minute into the run, ca-CHUNK then whirrrrrrrrrrrrrrr! As much as I hate 48p (makes my Pro4 too TC3 like), I have to use em. Will I encounter this going with the larger (108T) on the Cyclone or should I start looking for suitable 48P ratios? Oh yea, it will be a 3.5 going in there!
Old 04-18-2007, 08:28 AM   #8008
Super Moderator
Marcos.J's Avatar
i ran the 108 and 110 spur with no problems ,and yes the 110 spur will work
Old 04-18-2007, 11:42 AM   #8009
For carpet, most people run two diffs, right?
Yub, yub, cmdr! is offline   Reply With Quote
Old 04-18-2007, 11:46 AM   #8010
Trader Rating: 38 (100%+)
Yes, I would say nearly all.
or8ital is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
