Old 04-03-2007, 10:53 AM   #7816
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by stephen hilton
nope there cheap and nasty purple aluminium i think there really smooth but because the grub screw is so small its easilly rounded causing the pin to fall out and wrecking a hub and bone .and in the uk no shop has any!!!!! and i have a nationial on sunday! does anyone know if the steel ones chatter?
almost all cvds will chatter if you turn the wheels to full lock! i cut my endpoints down to eliminate most of the chatter,
Old 04-03-2007, 11:10 AM   #7817
Trader Rating: 46 (100%+)
Reading about which spool set up is confusing.
I have an original black cyclone that I want to run the spool set up. What is your recommendations and part #'s stuff I need to have?
thanks
Yellowtaro is offline   Reply With Quote
Old 04-03-2007, 11:17 AM   #7818
Super Moderator
Marcos.J's Avatar
thanks
here is a really good spool set up
Old 04-03-2007, 11:58 AM   #7819
oops!! I meant to say which type of spool to get for my original cyclone and what are the part numbers?
Thanks Marco J!
Old 04-03-2007, 12:58 PM   #7820
Super Moderator
Marcos.J's Avatar
Thanks Marco J!
my bad i used the BMI spool
Old 04-03-2007, 01:37 PM   #7821
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Marcos, is that for carpet or asphalt?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 04-03-2007, 01:37 PM   #7822
Skill's Avatar
I'm pretty sure the shop where I work has an MIP rebuild kit.
Try giving them a ring, 01302367676, it should be in a nice big box with a load of miscellaneous HPI parts.
Skill is offline   Reply With Quote
Old 04-03-2007, 01:39 PM   #7823
stephen hilton's Avatar
ygpm
stephen hilton is offline   Reply With Quote
Old 04-03-2007, 02:06 PM   #7824
Super Moderator
Marcos.J's Avatar
Snowy.
asphalt but it should work for carpet with rubber tires
Old 04-03-2007, 04:24 PM   #7825
I checked on BMI website but did not see it....Can you give me the link to it? Thanks.
Also, is the steel drive shaft (PN 61398) compatible with the axle that comes with the original cyclone? Does this shaft compatible with all version of the spool? Thanks.
Old 04-03-2007, 06:48 PM   #7826
Super Moderator
Marcos.J's Avatar
you might have to call BMI and talk to Jason
Old 04-03-2007, 11:50 PM   #7827
Cyclone Charlie's Avatar
Just in case anyone wants to know. I just got some steel 61043 front dogbones and they are the exact same as the aluminum 70710's that come with the Cyclone kit from Stormers Hobbies. The steel 61044 rear dogbones look exactly like the front ones, kind of weird, different part numbers, same part?
I found out though that the diff pulley part numbers are now A495 for the rear and A496 for the 3 screw front one-way. I can't seem to find anyone that has the A496. does anyone else know?
I've searched every shop I can think of.
Cyclone Charlie is offline   Reply With Quote
Old 04-04-2007, 05:32 AM   #7828
academygaz's Avatar
www.brockmodels.com
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 04-04-2007, 07:28 AM   #7829
pookat's Avatar
Default Erm... National????
If you live in the UK I hope you don't have a National on Sunday..
I'm not ready!!!!
pookat is offline   Reply With Quote
Old 04-04-2007, 07:49 AM   #7830
academygaz's Avatar
Schumacher BTCC at Stafford this weekend.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
