Old 03-28-2007, 02:47 PM   #7771
protc3's Avatar
hey stephen,
you wont need brakes in stock.i actually use roll throttle when i do run stock.all of the cars chatter with a spool when you turn the wheel to lock.you dont need that much steering.adjust the push out of the car and you will find the car to be really smoothe in the corners.a spool is the way to go buddy.once you get the car the way you like it you will never run a one way.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-28-2007, 02:49 PM   #7772
Trader Rating: 38 (100%+)
chatter on the track or on a stand? chatter off the ground is normal.
or8ital is offline   Reply With Quote
Old 03-28-2007, 02:53 PM   #7773
protc3's Avatar
it will still chatter on the ground if you turn the wheels to extreme angles.as the cvd's break in it is less noticable.key is to get the car to turn without oversteer.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-28-2007, 03:00 PM   #7774
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
and grease in them helps A TON!!! i figured that one out lol, after everyone told me that it helped soo much, but the chatter still did bother me also, why do they chatter in the air, theres no strian on them, and they would spin at the same speed as a diff so???
BlackedOutREVO is offline   Reply With Quote
Old 03-28-2007, 03:06 PM   #7775
protc3's Avatar
the cvd's do not rotate smoothly at full lock because they are not true cvd's.there is only 1 cross pin and there is limited movement.when your wheels are at full lock,so is the axle and cvd.when they are at full lock,every point during the rotation the the pin crosses the inside angle of the cvd,it deflects a slight bit and this is what the chatter is.if you keep it from fully locking,there will be no deflection.you just need to keep it from reaching its locking point
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-28-2007, 03:12 PM   #7776
so thats why grease helps then... hmmm thanks for the info man!
Old 03-28-2007, 03:58 PM   #7777
2-Bad's Avatar
Trader Rating: 24 (100%+)
The Losi "LCD" is the only one I know of that is a true CVD (there maybe more) and does not vibrate at it's extreme endpoints. But the most important point is not having the "most steering throw" in your car, but (as Protc3 said) getting the steering out of minimal steering throw (greater corner speed and reduce tire wear).
So just ignore the vibration at the endpoints cos you should not be setting your car up with this much reach in the first place.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-28-2007, 07:43 PM   #7778
Team Speedy's Avatar
Trader Rating: 42 (100%+)
Anybody know of some hobby shop(s) within the USA, besides Stormer, Speedtech, Tower that have the following parts in stock? (Prefer to stay within USA, unless shipping is "reasonable" for out of this country.)
  • Front Ball diff
  • Locked layshaft pin/rod
  • 16 tooth alum. pulley
I checked all the sites listed above and am looking for a one stop deal. I know tower has everything but the layshaft. I want to snag all it in one shopping trip and was hoping maybe someone knows of a shop around here that has what I need.
And to think of it before, I had one of these cars back in late Aug. and I regret selling it. At least this time I got to assemble it!
RcAmerica | Xray | Hudy |
Team Speedy is offline   Reply With Quote
Old 03-28-2007, 07:55 PM   #7779
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
Dont worry it is in good hands and still kicking ass, If you wanted to buy it back it could be negotiated.
Hobbytown USA Oshkosh
www.revolutionraceway.com
HVFracingwilly is offline   Reply With Quote
Old 03-28-2007, 08:01 PM   #7780
You wish!
Old 03-29-2007, 01:04 AM   #7781
stephen hilton's Avatar
cheers guys lookes like i have some work to do!
stephen hilton is offline   Reply With Quote
Old 03-29-2007, 07:52 AM   #7782
Trader Rating: 2 (75%+)
hey guys
ive been looking around online and havent been able to find a delrin spool or ball diff for my cyclone, does anyone know where I could find these?
thanks guys
-randy
JDMmonkeybear is offline   Reply With Quote
Old 03-29-2007, 08:16 AM   #7783
Hey guys,
Been trying to get the spur for my cyclone and no luck, what other spur can I use that will fit the cyclone? thank you.
Ramyuras is offline   Reply With Quote
Old 03-29-2007, 08:19 AM   #7784
Originally Posted by Ramyuras
Hey guys,
any 64 dp spur will fit as long as its smaller than 108 as this size sticks out of the chassis
Old 03-29-2007, 08:21 AM   #7785
mangoman's Avatar
Im lazy so im quite partial to using an 81T (48 pitch) spur.
The pinion effectively matches the rollout when you use rubber tires :P
I think you will struggle to get higher than 35mm rollout though if that is what you require.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
