Old 03-19-2007, 08:43 AM   #7681
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Originally Posted by hpiaustin
i purchased a new cyclone, what springs are you guys using
corally or the xray springs
thanks
for asphalt (tamiya and schumacher) for carpet (x-ray)
Old 03-19-2007, 09:02 AM   #7682
jaz
Originally Posted by BlackedOutREVO
so there is not one drive shaft to help me out? thats kinda jacked up.. i got like 3 runs in and blew it! man thats really no good
I think his point was just that you're bound to bend/break drive shafts if you keep hitting the boards. The only way to assure they don't break is to not hit anything. Certain shafts are definitely stronger than others though...
jaz is offline   Reply With Quote
Old 03-19-2007, 03:46 PM   #7683
stuey's Avatar
thanks
the only springs to use are hotbodies (hpi) or hara springs i wouldn't bother with anything else for the main reason these are consistant and the same length
stuey is offline   Reply With Quote
Old 03-19-2007, 07:25 PM   #7684
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
i havent even takin it to a track yet! im running on dusty as heck tar...... in open road, havent hit one thing
when i turn the car start to really shake and make a loud noise.. only in the front, is this spool chatter, or is something built wrong?
BlackedOutREVO is offline   Reply With Quote
Old 03-19-2007, 07:35 PM   #7685
Trader Rating: 194 (99%+)
Sounds like you had full EPA. When you turned the wheel the tire locked on the shock. You need to turn down your EPA on your radio.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 03-19-2007, 07:55 PM   #7686
yeh, but full crank and me turning the wheels with no motor on spins just as free, then with a motor giving power to them it does this, would this be why im breaking the shafts? around the pin hole where the pin for the axel goes into the shaft
Old 03-19-2007, 08:51 PM   #7687
2-Bad's Avatar
Trader Rating: 24 (100%+)
YES!!!!
Turn your endpoints down... my car is around 18degs deflection from centre. This should be appeal steering for anyone with a half decent set-up.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-19-2007, 08:53 PM   #7688
jaz
Originally Posted by 2-Bad
YES!!!!
Yeah, definitely crank the EPAs down. Should help you a lot.
Old 03-19-2007, 08:57 PM   #7689
ok i will! thanks a ton guys!!!! just saved me a ton of money lol
Old 03-19-2007, 09:03 PM   #7690
SpeedySST's Avatar
Default Fitting 4200's
Hey guys, I have an original chassis Cyclone and 4200's dont seem to fit very well. Is there another chassis out with larger battery slots or should I just get out my file? Thanks for your help!!
Team Durango DETC410 / SpeedPassion / Fantom Racing / Aston Martin Racing
SpeedySST is offline   Reply With Quote
Old 03-19-2007, 09:07 PM   #7691
jaz
File down the battery slots. You should do this anyway so that the sharp corners don't damage your cells. If I'm not mistaken, the Cyclone manual even instructs you to file them down.
Old 03-19-2007, 09:08 PM   #7692
jaz
Oh, and don't forget to seal the battery slots with CA after you file them down. Don't want to short your batteries on the chassis.
Old 03-19-2007, 09:10 PM   #7693
SpeedySST's Avatar
Thanks for the info. Getting the file out...
Old 03-19-2007, 09:36 PM   #7694
from the durability standpoint you may want to consider using the ver.2 universal drive shaft set instead of the mip cvds, but with the steel shafts (P/N #61398). that's what i use, they work very well, and definitely last longer than the ver.2 aluminum shafts or the aluminum shafts on the mip cvds .
i use a spool in front, no chatter problems after i put a bit of aw grease in the cups of the wheel axles (i.e. where the shafts "join" to the wheel axles). as mentioned above adjusting your epa will help.
sidewaysdriver6 is offline   Reply With Quote
Old 03-19-2007, 10:13 PM   #7695
are those on tower hobbies???? i cant find them anywhere....... sorry lol
and what grease???? white, black, or that lil tube???
thanks!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
