Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-10-2007, 03:38 AM   #7561
stephen hilton's Avatar
Originally Posted by MARKANO
Differences between the following bodies??
1. Ride Accord B
2. Ride Stratus 3
3. Moore Mazda
4. Moore Stratus
leave all those and get a p f mazdaspeed6
stephen hilton is offline   Reply With Quote
Old 03-10-2007, 05:12 AM   #7562
cheehtae's Avatar
Has anyone has the same problem with their rear diff? it's kinda like not set or really press together.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 03-10-2007, 05:22 AM   #7563
Super Moderator
Marcos.J's Avatar
Trader Rating: 65 (100%+)
Send a message via AIM to Marcos.J
the rear pulley will have a little play ( wable)
Old 03-10-2007, 07:13 AM   #7564
cheehtae's Avatar
TY, just on my other TC's it's really tight.
Old 03-10-2007, 08:26 AM   #7565
dodgeguy's Avatar
This is common with any ball diff. The balls suspened the diff gear. You do not want the diff gear/pully to rub on the rings. When the diff gear spins it will straighten out on its own. Now if the gear itself is not flat. That is a bad gear.
**SNO CAMEL RACING**Team RCAMERICA**XRAY**HUDY**JACO**PROTOFORM**KO PROPO**
THE EMPIRE
dodgeguy is offline   Reply With Quote
Old 03-10-2007, 10:03 AM   #7566
Originally Posted by Droopz
Yes please. I have heaps of stick packs that I really want to use on the Cyclone. Thanks for the setup guide too.
here's a list of the items you'd need to get :
1) P/N 73512 (hpi pro 4 stick pack holder), qty : 1 set
(this is a set of various parts, each marked with numbers. you'll only need the parts marked 4 (2pcs), 6(1pc), 7(2pcs) and 8(1pc) from this set. i'll refer to these as 73512-4, 73512-6, 73512-7 and 73512-8 respectively)
2) P/N Z082 (flat head screw m3 x 8mm), qty : 2
3) P/N Z352 (button head screw m3 x 8mm), qty : 4
4) P/N Z224 (washer m3 x 6mm), qty : 4
5) P/N Z305 (screw post m3 x 8mm), qty : 2
pics :
underside view
top view
top with battery clip view
steps :
1) cut out P/N 73512-7 (2pcs) from the set. dremel/file away the little "tooth" at the bottom of this part, so that it can sit flat.
2) attach the 2 pcs of P/N 73512-7 to the chassis, using P/N Z082 screws and using the existing unused holes along the centre line of the chassis, as in positions as shown in the "top view" pic.
Impt note : note the direction of the P/N 73512-7. this is the opposite way of how it's mounted on pro 4. this is to prevent the stick pack of getting in the way of the pinion and spur gear on the cyclone.
3) cut out P/N 73512-8 from the set.
4) put your stick pack on the chassis, and push the left side of the stick pack flush against the 2 pcs of P/N 73512-7 installed in step 2.
now place P/N 73512-8 flush against the right side of the stick pack, in the position as shown in the "top view" pic. mark out on the chassis the location of the 2 holes for mounting P/N 73512-8. the 2 holes must be located at a safe distance away from the side-by-side battery slots of the chassis.
5) remove the stick pack, remove P/N 73512-8, and drill the 2 holes marked out in step 4, using a 3mm diameter drill bit. make sure the bit is the type for drilling metal and is sharp (use a new drill bit if you can).
you'll need to clamp down/secure the chassis properly when drilling, to prevent any warpage of the chassis. i also use a vacuum and point it towards the drilling to suck away the cf dust.
along each hole (which will be very close to the side edge of the chassis), parallel to the battery slots, i use a needle file to file a slot from the side edge of the chassis, inwards towards the hole. this creates a "u-shaped" notch along the side edge of the chassis. this is to ease the positioning and mounting of P/N 73512-8 later on.
if you use CA glue to seal the edges of the cf chassis you'll probably want to seal these 2 notches too.
i'm not sure if the description of the notches make it hard to visualize, but i hope you can make out the 2 notches in the "underside view" pic above.
6) place the left side of the stick pack flush against the 2 pcs of P/N 73512-7, and then adjust and mount P/N 73512-8 using the P/N Z352 screws and P/N Z224 washers, as in the "underside view".
7) Cut out P/N 73512-6 and the 2 pcs of P/N 73512-4 from the set. dremel/file away the little "tooth" at the bottom of P/N 73512-4. screw in P/N Z305 screw posts into the 2pcs of P/N 73512-4, and then mount the 2 pcs of P/N 73512-4 onto the chassis using the existing slots in the chassis, and using P/N Z352 screws and P/N Z224 washers. with a stick pack on the chassis, adjust the positions of P/N 73512-4 until they hold P/N 73512-6 well, and then tighten the 2 pcs of P/N 73512-4 into location.
at the end of this you should see what you see in the "top view with battery clip" pic.
that's it! the above instructions may seem like quite a lot of work but it's actually a pretty simple straight-forward change. main thing is to be careful with the drilling. the disadvantage is that there will be 4 button head screws on the bottom of the chassis. but i have my ride height set pretty high and run on pretty smooth concrete ground so this isn't an issue for me. if you have access to machining equipment that can make accurate countersunk holes into a cf chassis that would be a great way to solve that.
anyway hth and good luck ! if you have any questions just post back.
sidewaysdriver6 is offline   Reply With Quote
Old 03-10-2007, 12:12 PM   #7567
Drcy's Avatar
Default Hop Up pulleys for the Cyco
I need some help,
3Racing produces different central pulleys (16/17/18) for the Cyclone.
I bought the kit with this 3 different central pulleys, but :
1st - I only get the original 16T to fit with the Excel Belt???? Does somebody know how (or with which belt) I manage to change from 16T to 18T (does exist another belt for it)?????
2nd - Different pulleys means different ratio, in this case
2.4375 (std Cyclone internal ratio)
39/17 = 2.2941
39/18 = 2.1666
are different ratios related with the Track size??
means smaller track (more technical) requires smaller internal ratio???
thanks for any help in clarifying this
Pedro
Drcy is offline   Reply With Quote
Old 03-10-2007, 12:17 PM   #7568
Drcy's Avatar
Default ROD Ends
I have some problems with the Cyclone original Rod Ends grtting play what affects mainly my steering.
Do you guys have found a good substitution??
thanks
Cy
Old 03-10-2007, 02:47 PM   #7569
RC MARKET's Avatar
Originally Posted by Drcy
I need some help,
39/17 = 2.2941
39/18 = 2.1666
Pedro
Yes 3Racing 17T fit to use excel belt !
RC MARKET is offline   Reply With Quote
Old 03-10-2007, 02:50 PM   #7570
RC MARKET's Avatar
& 3 Racing new product 5 cell 2.5mm main classis after onsale !
Old 03-10-2007, 06:02 PM   #7571
Vicko's Avatar
can anyone tell me the part # for the new style 6 degree streeing block
for the cyclone I have the old ones with the white paper, but I thinks the new 1 comes with orange papers
Vicko is offline   Reply With Quote
Old 03-10-2007, 06:21 PM   #7572
dawgmeat's Avatar
Send a message via Yahoo to dawgmeat
The past 2 weekend I've busted about 5 steerings blocks...... it's just driving me nutz because I went about 3 months without breaking anything, I remeber someone saying the T2 castor blocks & steering arms fit the cyclone well I gave it the ole' college try and they work but since I had to use Team Tamale I had to remove 2mm from the steering to keep the ackerman the same just out the pics
dawgmeat is offline   Reply With Quote
Old 03-10-2007, 10:18 PM   #7573
joey's Avatar
Trader Rating: 33 (100%+)
Send a message via AIM to joey
i got a black cyclone it should be here any day now..
can someone help me i need to know what parts to get before i start building.. i know i need a front diff.. anything else you can think of while im at it?
thanks..
=Majs Hobby Shop=
-Joe Wright-
joey is offline   Reply With Quote
Old 03-10-2007, 10:25 PM   #7574
got a link of the picture, or even one mounted on a car?
Feral Racing Batteries
Windsor Hobby and Racing Centre
unit 21/64 Drummond St
South Windsor
Ph. 02 4577 3166
Besercoe is offline   Reply With Quote
Old 03-11-2007, 12:59 AM   #7575
RC MARKET's Avatar
please wait moment !
Forum Jump
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
