Originally Posted by Droopz
Hey all. I just ordered a Cyclone (non Alan Moore Ed.) from Stormer and had a few (very) basic questions I hope you guys can help me with.
- Firstly, have anyone of you guys had any success in setting up your HB's for drifting?
- I might be completely wrong, but somewhere I read that Hot Bodies were somehow affiliated with HPI Is this really the case?
- Does the Cyclone support the use of 'standard' long battery packs at all?
- What else do I need to know to preparer myself for running the cyclone?
i have my cyclone set up for drifting, it works very well, you can take a look at my setup here :
cyclone drifting setup
oh if you don't have an account on that forum you may not be able to see the post, but anyway here's the setup i used :
Setup for Cyclone (Standard/Surikarn/Hara Editions) :
Ground Types
Ground Type 1 : Unsheltered MSCP Concrete Ground (e.g. Serangoon MSCP Top Level, Simei MSCP Top Level etc.)
Ground Type 2 : Sheltered MSCP Concrete Ground & Void Deck (e.g. Bukit Batok MSCP, Serangoon & Simei MSCP 2nd Level etc.)
Electronics
Transmitter : Nomadio React
Receiver : Nomadio V2 Transceiver
Servo : Futaba S3050 Digital (High-Torque) Servo
ESC : Futaba MC330CR
Steering EPA - Left : 82%
Steering EPA - Right : 82%
Steering Dual Rate : 83%
Steering Exponential : -27%
Throttle EPA : 100%
Throttle Exponential : -10%
Brake EPA : 80%
Brake Exponential : -10%
Car (Cyclone) Front
Toe-out : Approx. 1.5 degrees (Pivot Block : 1.5 degrees)
Camber : 0 degrees
Castor : Stock
Ride Height : approx. 8.5-9.0mm (with battery on car)
Droop : 2mm
Ackerman : Stock
Shocks : Stock
Shock Mount Position - Top : 4th hole counting from centre of chassis
Shock Mount Position - Bottom : 1st hole counting from centre of chassis
Shock Springs : Yellow
Shock - Adjustable Gap : 7.5mm
Shock - Oil Weight : 0 (No Oil) (Just put a little shock oil around the O-ring where the metal shaft passes through in the shock)
Belt Tension : Groove on bearing holder faces the front
Version 3 Solid Axle
Universal Drive Shaft Set - use the steel dogbones, they're much more durable than the aluminum ones
Rear
Toe-out : 0 degrees
Camber : 0 degrees
Castor : Stock
Droop : 2mm
Shocks : Stock
Shock Mount Position - Top : 2nd hole counting from centre of chassis
Shock Mount Position - Bottom : 2nd hole counting from centre of chassis
Shock Springs : Blue
Shock - Adjustable Gap : 5mm for Ground Type 1; 4mm for Ground Type 2
Belt Tension : Groove on bearing holder faces the back
Version 3 Solid Axle, with Non-universal regular steel dogbones and wheel axles
Wheels : PVC, with SGDrifters brand rims
Motor : Tamiya Super Stock TZ
Gearing : 96T Spur (Stock) and 40T Pinion : Gear Ratio is (96/40)x2.4375 = 5.85:1
Remarks :
NA
(note that this setup is using pvc tyres, running on reasonably smooth concrete ground)
the cyclone in the standard config only supports side by side battery packs. but i have modified the chassis a little to use stick packs (using the pro4 stick pack holders :
if you want i can post some closeup pics of what i did to have the stick pack there. it's pretty simple change.
