Old 03-05-2007, 08:03 PM   #7471
Trader Rating: 194 (99%+)
Is it me or do I need to cut the suspension mount shims in half to use them on the front rear brace? And the rear front brace? I have noticed different mm shims on setup sheets.
I noticed Speedtech has 2 different part numbers for the diff pully and oneway pully. Does anyone know why?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 03-05-2007, 10:09 PM   #7472
rc-zombies's Avatar
the suspension shims are actually different thickness of washers like these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGPC4&P=7
the diff and oneway pulleys are drilled out and mounted differently.
Old 03-06-2007, 05:04 PM   #7473
That seems a like a little to much isolation of stress to one point. A shim that is full width of the mount that touches the chassis would be best.
I will say that for a car of this caliber. The instructions were not good at all with setup help. For exapmle the suspenion mount roll cenetr adjustment.
www.donatelife.net
Old 03-06-2007, 06:12 PM   #7474
Hi Dodgeguy,
I'm not too sure if i understood you correctly, but i think you want to shim the suspension mounts. It isnt possible to have a shim that runs the full length of the mount because of the belt that passes under the mount thru the little gap. Aluminium shims exist already for the pivot blocks, but aluminium washers appear to be the best shim for the front rear and rear front suspension mounts.
jimbobmahua is offline   Reply With Quote
Old 03-06-2007, 06:28 PM   #7475
cheehtae's Avatar
Trader Rating: 15 (100%+)
or you can try this:http://www2.towerhobbies.com/cgi-bin...?&I=LXPFC3&P=Z
if that's what I think you would need, though it's not purple.Also I think you can only use this for rear rear and front front only, cuz like what Jimbowamba(LOL)mentioned placing it in the ft rear and rear front would hit the belt.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 03-06-2007, 06:30 PM   #7476
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Originally Posted by wannabee
what spur are you guys running on the rug (stock)???
100 spur
Old 03-06-2007, 06:31 PM   #7477
wannabee's Avatar
wannabee is offline   Reply With Quote
Old 03-06-2007, 06:31 PM   #7478
jaz
108
jaz is offline   Reply With Quote
Old 03-06-2007, 06:32 PM   #7479
I know that a shim full length will not fit. Only shim the part that contacts the chassis. So it would be 2 shims. One on each side of the mount. My cyclone came with a 2mmx2 and .5mmx2. They will only work with the 2.5 and 3.0 mount.
www.donatelife.net
Old 03-06-2007, 06:33 PM   #7480
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
108 Spur is what I run for stock.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 03-06-2007, 06:38 PM   #7481
cheehtae's Avatar
It won't? never thought about that. I thought twas the hole in the mount (not the one that screws to chassis) that has different degrees<not very sure though.
Old 03-06-2007, 06:40 PM   #7482
I just use regular shims for the suspension mounts, like ones used for the camber links. But if your running carpet foam you dont need any shims, the car is much better without shimming.
Old 03-06-2007, 06:50 PM   #7483
I am going to be running rubber tire outdoor. So I will probably want to raise the mounts up some. I have also noticed on some setup sheets show a .5mm to a 2mm spacer on the susp mounts front or rear.
www.donatelife.net
Old 03-06-2007, 06:51 PM   #7484
Super Moderator
Marcos.J's Avatar
try 1.5 mm f and r, Jason from BMI has a killer setup for rubber tire /asphalt
Old 03-06-2007, 06:51 PM   #7485
wannabee's Avatar
Thanks guys!!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
