Old 03-02-2007, 11:35 PM   #7441
Trader Rating: 48 (100%+)
what if using stock chassis? Will the 4800 fit?
Yellowtaro is offline   Reply With Quote
Old 03-03-2007, 12:23 AM   #7442
Skill's Avatar
Yes, no mofications whatsoever are required to fit the 4800. My dad has been running one in his car for a few meetings now, and the only thing he's done is put a bit of tape around the battery the other way round as well as the normal way around, just to try and stop it sliding out. So far he's had no problems with it coming loose. I do know of people who just tape it in the normal way and have been fine.
Skill is offline   Reply With Quote
Old 03-04-2007, 02:26 AM   #7443
Capt.Micro's Avatar
Originally Posted by RMF-888
what battery strap will fit to cyclone kit?or is it better to use battey tape?
If you are willing to drill a couple of holes in your chassis, the X-ray T2 battery strap will work. I made a fk05 strap fit on my BMI chassis but the T2 strap is narrower and should work better.
Kevin Colgan
Team South Shore Hobby
BackBreaker Racing
Long Island Raceway
Capt.Micro is offline   Reply With Quote
Old 03-04-2007, 03:52 AM   #7444
RMF-888's Avatar
Send a message via Yahoo to RMF-888
tnx.maybe ill be using battery tape.
RMF-888 is offline   Reply With Quote
Old 03-04-2007, 05:30 AM   #7445
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
For me, tape strap is always better than battery holder. That way, its much lighter and it should stick properly also depends on type of tape you use.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 03-04-2007, 06:33 AM   #7446
Originally Posted by Grindog001
On the surikarn and hara kits, is the cutting of the chassis still required under the front diff like hara shows on the above guide? It says on the guide that it is not always needed!
Excuse my ignorance but that one kind of shocked me...taking a dremel to a brand new kit. Is that done so some other mod will fit?
Disaster is offline   Reply With Quote
Old 03-04-2007, 06:41 AM   #7447
protc3's Avatar
its no longer needed.on the black cyclone the cutout under the front diff was small and your belt would slightly rub the chassis.the newer kits such as the hara,surikarn and worlds kit do not require that.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-04-2007, 06:59 AM   #7448
I bought the kit on sale at Stormers. Is it required for that one?
Cyclone kit at Stormers
Old 03-04-2007, 07:21 AM   #7449
protc3's Avatar
your belt will slightly rub the chassis on that kit.all you need to do is bevel the rear edge of the pocket with a small round file.just enough so the belt doesnt rub.the car works awesome
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-04-2007, 07:35 AM   #7450
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
scroll down THIS PAGE and see hara bevel the chassis so the belt dosent rub waht jason was taliking about
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-04-2007, 02:06 PM   #7451
cheehtae's Avatar
Trader Rating: 15 (100%+)
been building my black chassis since yesterday, I manage to use my Tamiya thrust bearings for the diff and steel dogbones. I will try and use the hard arms and suspension stuff from my TA05 and see if it will go well.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 03-04-2007, 02:22 PM   #7452
jaz
Actually, it appears that Hot Bodies has updated their chassis design on the black kit as well. On the original black Cyclone kits, both cutouts for the front and rear diff pulleys were the same size. I just received a new black Cyclone kit from Stormer last week, and the front pulley cutout is about twice the size of the cutout for the rear. So, if your kit is like mine, you won't have to do any special dremeling to the chassis.
jaz is offline   Reply With Quote
Old 03-04-2007, 03:12 PM   #7453
Trader Rating: 198 (100%+)
I got an updated chassis also with my Stormer kit also. No belt rub on mine.
Does anyone know where setup sheets for the cyclone are? I know there is a starting setup in the book. But what are others starting with?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 03-04-2007, 03:44 PM   #7454
jaz
Check www.cyclonedepot.com. There are several setup sheets on there including a blank one to use for your own setup.
Old 03-04-2007, 03:46 PM   #7455
Just checked mine as well. Front slot is larger than what is shown on the Hara build page. Looks like new kits don't need chassis work.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
